[Ovmsdev] sprintf / crashes
Thu Jan 3 03:18:09 HKT 2013
Mark,
master merge done. Hm... maybe I should have increased the firmware
version on this... as we've got new functionality, to 2.2.1?
Following your suggestion I changed the DebugCrash msg to a more generic
and extendable format including the version information. Example entry:
MP-0 c32,0,6,6,*-OVM-DebugCrash,2013-01-02
18:33:48,0,2.1.1/RT2.5/V2,0,0000,20
Btw: I think the GPS logger could also become a standard function.
Besides producing nice tracks it's useful to test different antennas and
antenna positioning. Maybe the send rate needs more configurability, it
currently logs once per minute or every 5 seconds if streaming is enabled.
Am 02.01.2013 02:19, schrieb Mark Webb-Johnson:
> Michael,
> Not too surprising, and I think your approach is good. The main
> limiting factor we have is RAM, and doing any sort of big buffering at
> the framework level will be hard. I think it is better to limit at the
> module level (as you have done).
> It looks good for a master merge.
> Regards, Mark
> On 2 Jan, 2013, at 4:37 AM, Michael Balzer wrote:
>> Mark,
>> transparent chunk splitting seems to be non-trivial, so I split my
>> data transfers. Everything's working fine again, so I'll merge into
>> the master next if you don't object.
>> Btw, AT+CIPSEND? gave me 1460 bytes, so that's supposed to be the
>> size limit we should keep in mind until we find a better solution.
>> @Nikolay: please note, that's the total size that can be sent within
>> one net_msg_start() ... net_msg_send(), the buffer size
>> (net_scratchpad) further limits a single MSG line to currently 199
>> bytes max.
>> Am 31.12.2012 16:23, schrieb Michael Balzer:
>>> Mark,
>>> I think I found my link dropping problem: scanning a diag log I
>>> took, I found out CIPSEND will fail with a plain "ERROR" if the data
>>> size exceeds about 1500 bytes. I guess that's either the SIM908
>>> buffer size or the max network packet size. I thought the SIM908
>>> would handle dividing data into packets as needed. The SIM908 manual
>>> mentions the max packet size depends on network status and should be
>>> queried by "AT+CIPSEND?". After the overrun net_state_activity()
>>> will not recognize "ERROR" to terminate the pending msg, so will run
>>> into the timeout and start a network re-init.
>>> My battery status data exceeds 1500 bytes on first run and later on
>>> if enough cells need updates. I'll think about how to split up data
>>> packets into multiple CIPSENDs. Would be nice if the net functions
>>> take care of this transparently.
>>> A secondary issue turned up from the diag log: the SIM908 crashed in
>>> the middle of a CIPSEND command while the module continued to run
>>> normally. The module still thought it's in NET_STATE_READY, so did
>>> not re-initalize the modem. The connection could then be established
>>> on the next CIPSTART, but the complete INIT stuff had not been done.
>>> So it seems independant SIM908 resets need to be handled as well,
>>> and they can occur anytime. I'll see if I can solve that too.
>>> Am 30.12.2012 15:42, schrieb Michael Balzer:
>>>> I hesitate to merge into the master because I currently have link /
>>>> connectivity problems, especially during driving. I introduced a
>>>> GPS logging to optimize my antenna positions and managed to get
>>>> some really nice tracks three days ago, so I don't think this is
>>>> related to my changes... but I'm not 100% sure. I tried different
>>>> antenna positions and another GSM network, but the connection keeps
>>>> dropping when moving the car, and GPS position updates need
>>>> minutes. Could be weather conditions ...or some tricky race
>>>> condition bug?
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130102/55213eba/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130102/55213eba/attachment.vcf>
