[Ovmsdev] sprintf / crashes
Wed Jan 2 04:37:40 HKT 2013
Mark,
transparent chunk splitting seems to be non-trivial, so I split my data
transfers. Everything's working fine again, so I'll merge into the
master next if you don't object.
Btw, AT+CIPSEND? gave me 1460 bytes, so that's supposed to be the size
limit we should keep in mind until we find a better solution.
@Nikolay: please note, that's the total size that can be sent within one
net_msg_start() ... net_msg_send(), the buffer size (net_scratchpad)
further limits a single MSG line to currently 199 bytes max.
Am 31.12.2012 16:23, schrieb Michael Balzer:
> Mark,
> I think I found my link dropping problem: scanning a diag log I took,
> I found out CIPSEND will fail with a plain "ERROR" if the data size
> exceeds about 1500 bytes. I guess that's either the SIM908 buffer size
> or the max network packet size. I thought the SIM908 would handle
> dividing data into packets as needed. The SIM908 manual mentions the
> max packet size depends on network status and should be queried by
> "AT+CIPSEND?". After the overrun net_state_activity() will not
> recognize "ERROR" to terminate the pending msg, so will run into the
> timeout and start a network re-init.
> My battery status data exceeds 1500 bytes on first run and later on if
> enough cells need updates. I'll think about how to split up data
> packets into multiple CIPSENDs. Would be nice if the net functions
> take care of this transparently.
> A secondary issue turned up from the diag log: the SIM908 crashed in
> the middle of a CIPSEND command while the module continued to run
> normally. The module still thought it's in NET_STATE_READY, so did not
> re-initalize the modem. The connection could then be established on
> the next CIPSTART, but the complete INIT stuff had not been done. So
> it seems independant SIM908 resets need to be handled as well, and
> they can occur anytime. I'll see if I can solve that too.
> Am 30.12.2012 15:42, schrieb Michael Balzer:
>> I hesitate to merge into the master because I currently have link /
>> connectivity problems, especially during driving. I introduced a GPS
>> logging to optimize my antenna positions and managed to get some
>> really nice tracks three days ago, so I don't think this is related
>> to my changes... but I'm not 100% sure. I tried different antenna
>> positions and another GSM network, but the connection keeps dropping
>> when moving the car, and GPS position updates need minutes. Could be
>> weather conditions ...or some tricky race condition bug?
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130101/ea31b729/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130101/ea31b729/attachment.vcf>
