[Ovmsdev] Ampera remote start/stop function
Michael Jochum
mikeljo at me.com
Mon Feb 25 08:34:10 HKT 2013
Hi,
puh.... over 200000 Lines of Logs is a lot.......
I am working to clean. This means remove ids that do not change.
Try to compare with my Logs from my Car (Volt, German Version, this mean km, C°, 24h, ...., no Onstar)
I can confirm that there are a lot of overruns. But i think we can work with it.
Call you tell us what outside and cabin temperature was?
i think it is a good idea to repeat the work. But then set some filters to the interface to prevent overruns.
But this happen later when we find some relevant stuff.
Bye
Am 22.02.2013 um 20:13 schrieb rgjones at sbcglobal.net:
> Hello Folks,
> I just captured CAN data during onstar commands for remote start/stop lock/unlock.
> Below are my notes. Where should I send the log file?
> Richard
> San Diego
> 2013 Volt #119292
> Fri Feb 22, 2013 10am PST
> VIN: 1g1re6e49du119292
> Car plugged in, locked, finished charging (green led blinking)
> walk up to car
> fob - unlock
> open passenger door - get in
> close passenger door.
> 10:41
> start android onstar app
> request status update (push refresh icon on app)
> 10:43 - app shows doing refresh
> see CAN activity
> 10:44 app finally updates - 120V battery fully charged 36 mile ev range 152 fuel range Oil life remaining 86% odo 3955 miles
> 10:45 can updates stop
> onstart remote door lock
> 1052 - sent lock cmd
> 1052 locked - lots of can
> 1053 remote start sent. failed as key in vehicle 1054
> 1054 remote unlock 1054 done
> 1055 leave via passenger door, close it.
> keyfob lock 1055
> leave key out of range of the car
> 1055 remote start req
> 1056 app says "cabin temp being set for optimal comfort"
> lots of CAN
> Dash still off, but orange engine light is on.
> 1057 send cancel engine start.
> 1057 - engine light off - app says done
> -rw-r--r-- 1 root root 17471412 2013-02-22 10:59 volt_130222_1_CAN_log.txt
> walk up to car
> fob - unlock
> 10:41
> see CAN activity
> keyfob lock 1055
> lots of CAN
> gzip volt_130222_1_CAN_log.txt
> tattler:~# tail volt_130222_1_CAN_log.txt
> 10:58:02.055852 S. id=0x000001c4 dat=0xca:0x62:0xc1:0x10:0x04:0x00:0x03:0xfe
> 10:58:02.057282 S. id=0x000001c5 dat=0x2c:0x03:0x2c:0x03:0x2e:0x01
> 10:58:02.058671 S. id=0x000001f4 dat=0x00:0x00:0x00:0x00:0x00:0x00
> 10:58:02.060073 S. id=0x00000287 dat=0xc1:0x00
> 10:58:02.062044 S. id=0x000002c3 dat=0x06:0x5b:0x06:0xa0:0x06:0xa0:0xca:0x00
> 10:58:02.062468 S. id=0x000000bc dat=0x37:0x00:0x00:0x40:0x00:0x00:0x00:0x00
> 10:58:02.062785 S. id=0x000000aa dat=0x2c:0x03:0x2c:0x03:0x04:0x53:0xfb:0x00
> 10:58:02.063088 S. id=0x000000c9 dat=0x00:0x00:0x00:0x27:0x00:0x10:0x08:0x00
> 10:58:02.063392 S. id=0x000001ed dat=0x01:0x90:0x00:0x00:0x00:0x00:0x18:0x01
> 10:58:02.063691 S. id=0x000001ef dat=0x00:0x00:0x00:0x00
> -rw-r--r-- 1 root root 1888643 2013-02-22 10:59 volt_130222_1_CAN_log.txt.gz
> --- On Sat, 2/16/13, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Subject: Re: [Ovmsdev] Ampera remote start/stop function
> To: "OVMS Developers" <ovmsdev at lists.teslaclub.hk>
> Date: Saturday, February 16, 2013, 12:03 AM
> Rens,
> The car-side technical discussion is going on here:
> http://gm-volt.com/forum/showthread.php?12958-CAN-bus-reading-remote-viewing-of-charge-state
> We're after pretty much the same things as the DashDaq people, so there is a lot of overlap.
> From the App, it is no problem. We can use HomeLink for testing at the moment, and implement something properly when we know it is feasible.
> The problem is that we need CAN bus dumps while OnStar / KeyFob pre-heat and remote start/stop is commanded. For that, we need someone with a Volt in the USA and CAN-USB logger to help us try to find the commands.
> On 16 Feb, 2013, at 7:56 AM, Rens Meijer <r.meijer at atlantis-it.nl> wrote:
>> Hello,
>> Last week I received the OVMS V2 module to monitor my Ampera. I already had an OVMS V1 module to monitor the Tesla Roadster, so it works nicely from 1 app.
>> In winter I like the remote start/stop function of the Ampera to pre-heat the car.
>> I found this Youtube that in the US it is possible with the OnStar system to remote start/stop the car. See at 2.21 in the movie.
>> http://www.youtube.com/watch?v=IOJMVbQnNIU&sns=em
>> Has somebody already made a CAN bus log during the remote start/stop by using the remote control? If you are able to find the sequence, how easy would it be to configure the current home buttons in the app to implement the start/stop function?
>> I would like to hear your thoughts on this?
>> Best Regards,
>> Rens
> -----Inline Attachment Follows-----
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130225/8bed57fe/attachment.html>
