[Ovmsdev] Ampera remote start/stop function
Sat Feb 16 16:03:15 HKT 2013
Rens,
The car-side technical discussion is going on here:
http://gm-volt.com/forum/showthread.php?12958-CAN-bus-reading-remote-viewing-of-charge-state
We're after pretty much the same things as the DashDaq people, so there is a lot of overlap.
From the App, it is no problem. We can use HomeLink for testing at the moment, and implement something properly when we know it is feasible.
The problem is that we need CAN bus dumps while OnStar / KeyFob pre-heat and remote start/stop is commanded. For that, we need someone with a Volt in the USA and CAN-USB logger to help us try to find the commands.
On 16 Feb, 2013, at 7:56 AM, Rens Meijer <r.meijer at atlantis-it.nl> wrote:
> Hello,
> Last week I received the OVMS V2 module to monitor my Ampera. I already had an OVMS V1 module to monitor the Tesla Roadster, so it works nicely from 1 app.
> In winter I like the remote start/stop function of the Ampera to pre-heat the car.
> I found this Youtube that in the US it is possible with the OnStar system to remote start/stop the car. See at 2.21 in the movie.
> http://www.youtube.com/watch?v=IOJMVbQnNIU&sns=em
> Has somebody already made a CAN bus log during the remote start/stop by using the remote control? If you are able to find the sequence, how easy would it be to configure the current home buttons in the app to implement the start/stop function?
> I would like to hear your thoughts on this?
> Best Regards,
> Rens
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130216/6c05a57d/attachment.html>
