[Ovmsdev] Nissan Leaf
    Robert Sharpe
    robert.sharpe at evergreen-consulting.co.uk
    Sat Dec 21 22:38:04 HKT 2013
Hi Mark,
Sorry it has taken a while to get back to you.  I only have access to LeafSpy via my wife's work phone and she has been out most of the week.
I only just realised that logging could probably be done through the OVMS :-( so will try that in the next few days as well.
Anyway, attached is sample LeafSpy Elm Trace.  Before I do lots of testing using this method can you confirm that this is useful.
Rob
---- On Wed, 18 Dec 2013 01:57:50 +0100 Mark Webb-Johnson<mark at webb-johnson.net> wrote ----
Nikki,
Thanks for this.
Firstly, I'm glad the firmware is connecting back to the server ok. I broke that a few months ago (this new module meant I had to reorganise some low-level crypto stuff to make room), and am glad it is fixed again.
For the SOC, I'm really just guessing. Supposedly message 0x5b3 on car can bus has GIDs in B6bit0 and B7 - I just divided that by 3 to get a rough approximation of SOC, but it is obviously not working. I think this one shouldn't be too hard, but I don't have any CAN bus dumps of what the 0x5b3 message looks like. If I can see a dump, with matching known SOC / GIDs, then I am sure we can get this right. That said, active polling (which is what leafspy uses) seems to be a better way of getting this, as it gets us true GIDs off the EV can bus.
Glad about the parking indicator. I work off the parking brake for that one, and it is an important status flag for quite a few things.
I'm working on the polling mechanism at the moment. It is very similar to the OBDII VIN number polling mechanism we already have, and my recent work on the common vehicle.{h,c} polling code should make this relatively easy.
On 18 Dec, 2013, at 6:22 am, Nikki Gordon-Bloomfield <nikki at aminorjourney.com> wrote:
So here’s what I’ve learned from the alpha code so far…
1) It’s recording the parking status accurately, as far as I can tell. within a few minutes of parking, it’s noting that on the app screen.
2) It’s certainly sending me alerts as you might expect for low SOC warnings.
3) But sadly SOC isn’t working correctly with my car. For some reason, SOC is jumping all over the shop, with 22% SOC seemingly a favourite place for the OVMS code. On my quick trip just now to the shops, I noted it went from 76% SOC (which I think was fairly accurate given the number of bars I had) down to 22% when I parked up.
Coming back, I got no update and ended up having to do a hard reboot to get the system to wake up.
I haven’t been able to get any logs yet because I don’t have a splitter for the ODBII system. I’ll get that sorted later this week/early next.
Nikki.
On 17 Dec 2013, at 20:06, Nikki Gordon-Bloomfield <nikki at aminorjourney.com> wrote:
Okay guys.
I’ve done a couple of quick tests with the new beta software.
First up, it installs (Which is good, of course) Second up: I was able to drive around the block and see some SOC reports. What did appear to happen is that SOC dropped and then went back up again. I had values from 27% SOC down to 14% SOC to Empty and back up to 22% SOC.  I’d guesstimate my real SOC was nearer 45%.  (Although I didn’t check with LEAFSpy)
Of course, I need to check the other bits and bobs too — Park/Drive status seems to work with the car on — but with the module rebooted, it forgets what was previously on. This is a problem I believe with the LEAF CAN bus, which turns itself off when parked. I’m guessing we’ll need to figure out a way to wake up CAN and then switch back off again? (That said,I think it’s supposed to stay on when charging… and I’m currently charging)
I’ll play a little more tomorrow and throughout the rest of the week. I’ll also try and get some decent logs if I can.
Nikki.
On 17 Dec 2013, at 14:16, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
Attached is a first-run at Nissan Leaf support, with a few values read from the bus passively:
Speed
Headlight status
Park / Drive status
SOC
I’ve also pushed this to github (along with a large number of other small changes).
The Nissan Leaf support is proving really hard for me. I don’t have the car, or much CAN bus data, and the public documentation is contradictory and incomplete. End result is that I am just guessing, and completely unable to test my guesses.
Anyway, please try it and let me know if any of those figures show up with any sense of accuracy at all.
Going forward, I really need some CAN bus dumps from a Nissan Leaf. Specifically:
Car idle
Car plugged in and charge started
Car charging
Charge interrupted
Driving
Driving as close to a constant speed of 10 kph as possible
Driving as close to a constant speed of 20 kph as possible
Driving as close to a constant speed of 30 kph as possible
Car parked, but on
Car parked, coming out of park into drive gear
Car stopped, coming out of drive gear into park
Car in park gear, then handbrake applied
For each of those, both with and without a T connector and LeafSpy running would be helpful.
I’m guessing the logs can be gotten from monitor-all mode with an OBDII adaptor. There is not too much data on the can bus and that should be fast enough.
If anyone can help with the above, please let me know.
<OVMS.X.production.zip>
OvmsDev mailing list
OvmsDev at lists.teslaclub.hk
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131221/e7e2b539/attachment.htm>
00978  00979 : [47 29]  Connect 2 ELM
00986  00987 : [47 29]  Connect 2 ELM
00990  00990 : [47 29]  Connect 2 ELM
01233  01233 : [47 29]  Service Start
01245  01245 : [47 29]  Service Start
01251  01251 : [47 29]  Service Start
01428  01428 : [47 29]  Service Start
01520  00022 : [00 29]  Wait 4 ELM  00
01620  00122 : [00 29]  Wait 4 ELM  00
01720  00222 : [00 29]  Wait 4 ELM  00
01820  00323 : [00 29]  Wait 4 ELM  00
01923  00425 : [00 29]  Wait 4 ELM  00
02090  00592 : [00 29]  Wait 4 ELM  00
02190  00692 : [00 29]  Wait 4 ELM  00
02288  00790 : [00 29]  Wait 4 ELM  00
02321  00824 : [00 29]  [0d]
02325  00827 : [00 29]  [0d] ELM327_v1.5 [0d]  [0d]
02328  00830 : [00 29] >
02346  00017 : [01 29] A
02350  00021 : [01 29] TE0 [0d]
02354  00025 : [01 29] OK [0d]  [0d] >
02388  00033 : [02 29]  Wait 4 ELM  02
02415  00060 : [02 29] O
02417  00063 : [02 29] K [0d]  [0d] >
02458  00040 : [03 29] E
02462  00043 : [03 29] LM327_v1.5 [0d]  [0d] >
02480  00018 : [04 29] O
02488  00026 : [04 29] K [0d]  [0d] >
02496  00006 : [05 29]  Wait 4 ELM  05
02533  00044 : [05 29] O
02535  00045 : [05 29] K
02537  00047 : [05 29]  [0d]  [0d] >
02578  00039 : [06 29] O
02580  00040 : [06 29] K [0d]  [0d] >
02598  00017 : [10 29]  Wait 4 ELM  10
02612  00031 : [10 29] O
02614  00034 : [10 29] K [0d]  [0d] >
02656  00040 : [11 29] O
02695  00080 : [11 29] K [0d]  [0d] >
02704  00007 : [12 29]  Wait 4 ELM  12
02738  00040 : [12 29] O
02740  00042 : [12 29] K [0d]  [0d] >
02761  00020 : [13 29] O
02764  00024 : [13 29] K [0d]  [0d] >
02809  00043 : [14 29]  Wait 4 Leaf 14 29
02822  00056 : [14 29] 7
02824  00058 : [14 29] 9A0250C0 [0d]
02905  00139 : [14 29]  Wait 4 Leaf 14 29
02989  00224 : [14 29]  [0d]
02992  00226 : [14 29] >
03007  00014 : [15 29]  Connected 15 29
03030  00038 : [15 29] 7
03034  00041 : [15 29] 9A101561814A
03036  00044 : [15 29] 4E3146 [0d]
03041  00048 : [15 29] 79A2141415A45305530
03043  00050 : [15 29]  [0d]
03072  00079 : [15 29] 7
03075  00082 : [15 29] 9A22303
03077  00084 : [15 29] 03632303900 [0d]
03104  00112 : [15 29]  Connected 15 29
03191  00198 : [15 29]  Connected 15 29
03284  00291 : [15 29] 7
03286  00294 : [15 29] 9A23000000
03289  00297 : [15 29] 00000000 [0d]
03295  00303 : [15 29]  Connected 15 29
03348  00355 : [15 29]  [0d]
03350  00357 : [15 29] >
00019  00019 : [16 29] O
00023  00023 : [16 29] K [0d]  [0d] >
00046  00022 : [17 29]  Connected 17 29
00072  00049 : [17 29] O
00081  00057 : [17 29] K [0d]  [0d] >
00121  00040 : [18 29] O
00124  00042 : [18 29] K
00126  00044 : [18 29]  [0d]  [0d] >
00145  00019 : [19 29]  Connected 19 29
00177  00051 : [19 29] 1
00186  00059 : [19 29] 3.
00188  00061 : [19 29] 3V [0d]  [0d] >
00230  00041 : [20 29] 7
00232  00044 : [20 29] BB102
00236  00047 : [20 29] 96101FFFFE9C6 [0d]
00238  00049 : [20 01] 7BB210288FFFFEE80FF [0d]
00246  00057 : [20 02]  Connected 20 02
00270  00081 : [20 02] 7
00274  00086 : [20 02] BB
00277  00088 : [20 02] 22FFFFFF070A2AF
00279  00090 : [20 02] 8 [0d]
00307  00118 : [20 03] 7
00310  00121 : [20 03] B
00311  00123 : [20 03] B2395D833A50392
00322  00133 : [20 03] 00 [0d]
00325  00136 : [20 04] 7
00364  00175 : [20 04] BB245C1C6D000B6D45 [0d]
00370  00182 : [20 05]  Connected 20 05
00386  00197 : [20 05] 7
00388  00199 : [20 05] BB250008A12180
00391  00202 : [20 05] 0001 [0d]
00471  00282 : [20 06]  Connected 20 06
00486  00298 : [20 06]  [0d]
00489  00300 : [20 06] >
00530  00039 : [21 06] 7
00533  00042 : [21 06] BB
00535  00045 : [21 06] 1010610402690A0
00537  00047 : [21 06] 2 [0d] 7BB21680A02680A0267 [0d]
00575  00084 : [21 02]  Connected 21 02
00577  00086 : [21 02] 7
00579  00088 : [21 02] BB220A0A00FFFFF
00581  00090 : [21 02] FFF [0d]
00672  00181 : [21 03]  Connected 21 03
00687  00197 : [21 03]  [0d]
00690  00200 : [21 03] >
00736  00044 : [22 03] 7
00739  00047 : [22 03] BB101A
00741  00050 : [22 03] 610604000000 [0d]
00745  00053 : [22 01] 7BB2100000000000000 [0d]
00772  00080 : [22 02]  Connected 22 02
00792  00101 : [22 02] 7
00796  00105 : [22 02] BB220002000
00799  00107 : [22 02] 0000000 [0d]
00802  00110 : [22 03] 7
00841  00150 : [22 03] B
00843  00152 : [22 03] B2300000200000
00845  00154 : [22 03] 0FF [0d]
00872  00180 : [22 04]  Connected 22 04
00956  00264 : [22 04]  Connected 22 04
01058  00366 : [22 04]  [0d]
01079  00387 : [22 04]  Connected 22 04
01081  00389 : [22 04] >
01124  00039 : [23 04] 7
01128  00042 : [23 04] BB10C661020FA
01130  00044 : [23 04] 60F97 [0d]
01134  00049 : [23 01] 7BB210FA30FA00F9E0F [0d]
01168  00083 : [23 02]  Connected 23 02
01192  00107 : [23 02] 7
01195  00110 : [23 02] BB229F0F
01199  00114 : [23 02] A20F9F0F9E [0d]
01202  00116 : [23 03] 7BB230F9F0F9E0F9B0F [0d]
01220  00135 : [23 04] 7
01224  00138 : [23 04] BB249E0F9B0F9
01226  00140 : [23 04] A0F9B [0d]
01258  00173 : [23 05] 7
01262  00176 : [23 05] BB250
01263  00178 : [23 05] F9A0F9B0F9D0F [0d]
01271  00185 : [23 06]  Connected 23 06
01286  00200 : [23 06] 0F9D0F9E0F98 [0d]
01289  00203 : [23 06] 7
01291  00205 : [23 06] BB269C
01306  00222 : [23 06] 7
01351  00266 : [23 06] BB270F9B0F9D0
01353  00268 : [23 06] F990F [0d]
01357  00271 : [23 06] 7
01360  00274 : [23 06] BB28980F9F0F9A0F9C [0d]
01363  00277 : [23 07] 7
01365  00279 : [23 07] BB290F9
01367  00281 : [23 07] E0FA00F9E0F [0d]
01375  00289 : [23 08]  Connected 23 08
01396  00311 : [23 08] 7
01400  00315 : [23 08] BB2A9F0F9E0F9C
01403  00317 : [23 08] 0F9E [0d]
01436  00351 : [23 09] 7
01448  00363 : [23 09] BB2
01451  00366 : [23 09] B0F9B0F9A0F9C0F
01455  00369 : [23 09]  [0d] 7BB2C9E
01458  00373 : [23 10] 0F9B0F
01461  00375 : [23 10] 9E0F9B [0d]
01475  00389 : [23 11]  Connected 23 11
01495  00411 : [23 11] 7
01499  00413 : [23 11] B
01501  00415 : [23 11] B2D0F9A0F9B0F9
01503  00417 : [23 11] E0F [0d]
01532  00448 : [23 12] 7
01548  00462 : [23 12] BB2E9F
01550  00464 : [23 12] 0FA60F9E0F98 [0d]
01552  00466 : [23 13] 7
01554  00469 : [23 13] BB2F0F9F0F9E0F9F0F [0d]
01584  00498 : [23 14]  Connected 23 14
01624  00538 : [23 14] 7
01626  00540 : [23 14] BB2
01628  00542 : [23 14] 09E0F9A0F9E0F9D
01630  00544 : [23 14]  [0d]
01645  00560 : [23 15] 7
01648  00564 : [23 15] BB210F9D0F9A0F9A0F [0d]
01654  00569 : [23 16] 7
01657  00571 : [23 16] 9A0F9E [0d]
01660  00574 : [23 16] BB22960F9A0F
01663  00577 : [23 16] 7
01666  00580 : [23 16] BB230F9E0
01668  00582 : [23 16] F9A0F9B0F [0d]
01679  00594 : [23 16]  Connected 23 16
01701  00615 : [23 16] 7
01704  00618 : [23 16] BB249A0F9B0F
01706  00620 : [23 16] 9B0F9B [0d]
01736  00652 : [23 17] 7
01740  00654 : [23 17] BB250F9B0F960
01742  00657 : [23 17] F9B0F [0d]
01775  00689 : [23 18] 7
01785  00699 : [23 18]  Connected 23 18
01787  00701 : [23 18] BB26960
01789  00703 : [23 18] F9A0F9A0F9A [0d]
01803  00717 : [23 19] 7BB270F
01807  00721 : [23 19] 9B0F
01809  00723 : [23 19] 960F9B0F [0d]
01822  00736 : [23 20] 7
01824  00738 : [23 20] BB289
01862  00776 : [23 20] 20F9F0FA20F9D [0d]
01868  00782 : [23 21] B
01870  00784 : [23 21] 7
01874  00788 : [23 21] BB290F9D0F9E0F9B0F [0d]
01876  00791 : [23 21] 7
01878  00793 : [23 21] B2A9A0F9F0F9C0F
01880  00795 : [23 21] 9E [0d]
01886  00800 : [23 21]  Connected 23 21
01907  00822 : [23 21] 7
01911  00826 : [23 21] BB2
01913  00827 : [23 21] B0FA10F9A0F9E96
01917  00831 : [23 21]  [0d]
01944  00859 : [23 22] 7
01948  00862 : [23 22] BB2C0295F2FFF
01950  00864 : [23 22] FFFFF [0d]
01986  00900 : [23 23]  Connected 23 23
02100  01014 : [23 23]  Connected 23 23
02235  01149 : [23 23]  [0d]
02242  01156 : [23 23]  Connected 23 23
02247  01161 : [23 23] >
02289  00041 : [24 23] O
02290  00043 : [24 23] K [0d]  [0d] >
02337  00045 : [25 23] 7
02339  00047 : [25 23] 9
02344  00053 : [25 23]  Connected 25 23
02347  00055 : [25 23] A0250C0 [0d]
02373  00081 : [25 23]  [0d]
02481  00189 : [25 23]  Connected 25 23
02494  00202 : [25 23] >
02545  00049 : [26 23]  Connected 26 23
02561  00065 : [26 23] 7
02563  00068 : [26 23] 9A0762124E00B
02567  00071 : [26 23] B0065 [0d]
02616  00120 : [26 23]  [0d]
02618  00122 : [26 23] >
02646  00027 : [27 23]  Connected 27 23
02662  00043 : [27 23] 7
02665  00047 : [27 23] 9A0762115D653
02667  00049 : [27 23] 26500 [0d]
02721  00102 : [27 23]  [0d]
02723  00104 : [27 23] >
02746  00023 : [28 23]  Connected 28 23
02764  00040 : [28 23] 7
02767  00044 : [28 23] 9A0562132A106
02769  00045 : [28 23] 0 [0d]
02801  00078 : [28 23]  [0d]
02805  00081 : [28 23] >
02844  00039 : [29 23] 7
02853  00047 : [29 23]  Connected 29 23
02854  00049 : [29 23] 9
02856  00050 : [29 23] A07621255000000
02858  00052 : [29 23] 00 [0d]
02880  00074 : [29 23]  [0d]
02884  00078 : [29 23] >
02923  00039 : [30 23] 7
02959  00074 : [30 23] 9A05
02961  00076 : [30 23] 62130480BA [0d]
02967  00082 : [30 23]  Connected 30 23
02985  00101 : [30 23]  [0d]
02988  00103 : [30 23] >
03009  00020 : [31 23] 7
03012  00023 : [31 23] 9A
03015  00027 : [31 23] 0762123400000A0A
03018  00029 : [31 23]  [0d]
03077  00088 : [31 23]  Connected 31 23
03086  00097 : [31 23]  [0d]
03111  00123 : [31 23] >
03152  00039 : [32 23] 7
03155  00051 : [32 23] 9A07621203005CFF
03166  00053 : [32 23] FF [0d]
03188  00077 : [32 23]  Connected 32 23
03309  00196 : [32 23]  Connected 32 23
03409  00296 : [32 23]  Connected 32 23
03411  00298 : [32 23]  [0d]
03426  00313 : [32 23] >
03469  00042 : [33 23] 7
03472  00045 : [33 23] 9A0762
03474  00047 : [33 23] 12050C40FFFF [0d]
03508  00081 : [33 23]  Connected 33 23
03530  00103 : [33 23]  [0d]
03532  00105 : [33 23] >
03549  00016 : [45 23] O
03590  00057 : [45 23] K [0d]  [0d] >
03608  00018 : [46 23]  Connected 46 23
03630  00039 : [46 23] 7
03633  00042 : [46 23] 9305621210
03635  00044 : [46 23] 0000 [0d]
03666  00075 : [46 23]  [0d]
03668  00077 : [46 23] >
03712  00043 : [47 23]  Connected 47 23
03714  00045 : [47 23] 79
03716  00047 : [47 23] 3056212300118 [0d]
03743  00074 : [47 23]  [0d]
03746  00077 : [47 23] >
03763  00016 : [58 23] O
03765  00019 : [58 23] K [0d]  [0d] >
03805  00038 : [59 23] O
03807  00040 : [59 23] K [0d]  [0d] >
03817  00009 : [60 23]  Connected 60 23
03846  00038 : [60 23] O
03848  00040 : [60 23] K [0d]  [0d] >
03893  00044 : [61 23] 7
03908  00059 : [61 23] 631082610
03916  00067 : [61 23]  Connected 61 23
03918  00069 : [61 23] 100000000 [0d] 76321
03932  00083 : [61 01] 00000001143600 [0d]
03949  00100 : [61 02]  [0d]
03951  00102 : [61 02] >
03990  00039 : [62 02] O
03993  00042 : [62 02] K [0d]
04029  00077 : [62 02]  [0d] >
04037  00007 : [63 02]  Connected 63 02
04070  00041 : [63 02] O
04073  00043 : [63 02] K [0d]  [0d] >
04090  00016 : [64 02] O
04093  00019 : [64 02] K [0d]  [0d] >
04138  00044 : [65 02]  Connected 65 02
04160  00075 : [65 02] 7
04171  00078 : [65 02] 65037
04173  00079 : [65 02] F2112 [0d]
04219  00125 : [65 02]  [0d]
04221  00127 : [65 02] >
04240  00018 : [66 02]  Connected 66 02
04285  00064 : [66 02] 7
04289  00068 : [66 02] 65100B611000
04292  00071 : [66 02] 000000 [0d]
04295  00073 : [66 02] 765210000000000FFFF [0d]
04338  00116 : [66 02]  Connected 66 02
04421  00199 : [66 02]  Connected 66 02
04512  00290 : [66 02]  [0d]
04519  00297 : [66 02]  Connected 66 02
04521  00299 : [66 02] >
00021  00021 : [16 02] O
00023  00023 : [16 02] K [0d]  [0d] >
00063  00039 : [17 02] O
00065  00041 : [17 02] K [0d]  [0d] >
00099  00033 : [18 02]  Connected 18 02
00165  00099 : [18 02] O
00167  00101 : [18 02] K [0d]  [0d] >
00199  00031 : [19 02]  Connected 19 02
00214  00047 : [19 02] 1
00217  00049 : [19 02] 3.1V [0d]  [0d] >
00258  00039 : [20 02] 7
00261  00042 : [20 02] B
00264  00045 : [20 02] B10296101FFFFE9
00266  00047 : [20 02] C6 [0d] 7BB210288FFFFF003FF [0d]
00304  00086 : [20 02]  Connected 20 02
00307  00088 : [20 02] 7
00309  00090 : [20 02] BB22FFFFFF070A
00311  00092 : [20 02] 2AF8 [0d]
00339  00120 : [20 03] 7
00341  00122 : [20 03] BB2395D93302038B00
00352  00133 : [20 03]  [0d]
00355  00137 : [20 04] 7
00357  00140 : [20 04] BB245C1C6D0
00361  00143 : [20 04] 00B6CCB [0d]
00385  00166 : [20 05] 7
00412  00193 : [20 05] B
00414  00195 : [20 05] B250008A1218
00416  00197 : [20 05] 00001 [0d]
00423  00204 : [20 06]  Connected 20 06
00438  00220 : [20 06]  [0d]
00442  00223 : [20 06] >
00515  00072 : [21 06] 7
00517  00074 : [21 06] B
00663  00221 : [21 06] B1010610402680
00672  00229 : [21 06] A02 [0d] 7BB21690A02680A0268 [0d] 7BB220A0A00FF
00782  00339 : [21 02] FFFFFF [0d]
00789  00346 : [21 03]  [0d]
00792  00350 : [21 03] >
00840  00047 : [22 03] 7
00844  00050 : [22 03] BB101A61060
00848  00054 : [22 03] 4000000 [0d]
00851  00057 : [22 01] 7BB2100000000000000 [0d]
00855  00062 : [22 02] 7
00861  00068 : [22 02] BB2200020000000
00864  00070 : [22 02] 000 [0d]
00897  00103 : [22 03] 7
00899  00105 : [22 03] BB2300
00902  00108 : [22 03] 0002000000FF [0d]
00957  00163 : [22 04]  [0d]
00959  00165 : [22 04] >
00999  00039 : [23 04] 7
01003  00043 : [23 04] B
01006  00046 : [23 04] B10C661020FA60F
01008  00048 : [23 04] 96 [0d] 7BB210F9E0F9F0F9A0F [0d]
01042  00083 : [23 02] 7
01046  00086 : [23 02] B
01048  00088 : [23 02] B229E0FA20F9E0
01050  00090 : [23 02] F9E [0d]
01078  00118 : [23 03] 7
01081  00121 : [23 03] BB230F
01084  00124 : [23 03] 9E0F9E0F9A0F [0d]
01121  00163 : [23 04] 7
01125  00165 : [23 04] BB249E0F9A0F9
01128  00169 : [23 04] A0F9A [0d]
01131  00171 : [23 05] 7
01133  00173 : [23 05] BB250F9A0F9A0F9
01135  00175 : [23 05] D0F [0d]
01160  00201 : [23 06] 7
01163  00203 : [23 06] BB269B0F9D
01167  00207 : [23 06] 0F980F98 [0d]
01199  00239 : [23 07] 7
01203  00243 : [23 07] BB270F9A0F9
01205  00245 : [23 07] D0F980F [0d]
01210  00250 : [23 08] 7
01211  00252 : [23 08] BB2898
01213  00254 : [23 08] 0F9A0F9A0F9B [0d]
01254  00295 : [23 09] 7
01257  00297 : [23 09] BB290F9E
01259  00299 : [23 09] 0F9F0F9E0F [0d]
01264  00304 : [23 10] 7
01266  00306 : [23 10] BB2
01270  00311 : [23 10] A9E0F9E0F9B0F9E
01274  00314 : [23 10]  [0d]
01305  00347 : [23 11] 7
01309  00349 : [23 11] BB2
01311  00351 : [23 11] B0F9A0F9A0F9B0F [0d]
01343  00383 : [23 12] 7
01347  00387 : [23 12] B
01349  00389 : [23 12] B2C9E0F9A0F9E0
01388  00429 : [23 12] F9A [0d]
01392  00433 : [23 13] 7
01394  00434 : [23 13] BB2D0F9A0F9A0F9E0F [0d] 7BB2
01397  00437 : [23 14] E9F0FA20
01399  00439 : [23 14] F9E0F98 [0d]
01425  00465 : [23 15] 7
01428  00468 : [23 15] BB2F0F9F0F9E
01430  00470 : [23 15] 0F9F0F [0d]
01460  00501 : [23 16] 7
01464  00504 : [23 16] BB209E0
01465  00506 : [23 16] F9A0F9E0F9D [0d]
01498  00539 : [23 17] 7
01501  00541 : [23 17] BB210F9D0
01504  00545 : [23 17] F9A0F9A0F [0d]
01507  00547 : [23 18] 7
01510  00551 : [23 18] BB22
01512  00553 : [23 18] 960F9A0F9A0F9E [0d]
01548  00589 : [23 19] 7
01553  00593 : [23 19] BB230F
01556  00601 : [23 19] 9E0F9A0F9B0F [0d]
01588  00628 : [23 20] 7
01591  00631 : [23 20] BB249A0F9B0F9B0F
01597  00637 : [23 20] 9B [0d]
01599  00639 : [23 21] 7BB250
01602  00643 : [23 21] F9B0F960F9B0F [0d]
01636  00676 : [23 22] 7
01639  00679 : [23 22] BB26960F9A0F9A0F9F [0d]
01673  00714 : [23 23] 7
01737  00777 : [23 23] B
01739  00779 : [23 23] B270F9B0F960F9B
01741  00781 : [23 23] 0F [0d]
01752  00792 : [23 24] 7
01754  00794 : [23 24] BB28920F9F0FA20F9D [0d] 7BB290F9D0F9E0F9B0F [0d]
01781  00822 : [23 26] 7
01784  00825 : [23 26] BB2A9A0F9F0F9C0F9E [0d]
01788  00828 : [23 27] 7BB2B0F9D0F9A0F9E95 [0d]
01823  00863 : [23 28] 7
01828  00868 : [23 28] BB2CDB95E2FFFFFFF
01830  00870 : [23 28] F [0d]
01887  00927 : [23 29]  [0d]
01889  00929 : [23 29] >
01929  00039 : [24 29] O
01935  00045 : [24 29] K
01937  00048 : [24 29]  [0d]  [0d] >
01988  00044 : [25 29] 7
01993  00049 : [25 29] 9A02
01995  00051 : [25 29] 50C0 [0d]
02050  00107 : [25 29]  [0d]
02052  00109 : [25 29] >
02092  00039 : [26 29] 7
02094  00042 : [26 29] 9A0762124E
02098  00045 : [26 29] 00BB0065 [0d]
02154  00102 : [26 29]  [0d]
02156  00104 : [26 29] >
02195  00038 : [27 29] 7
02198  00040 : [27 29] 9A0762115D
02233  00075 : [27 29] 65326500 [0d]
02258  00100 : [27 29]  [0d]
02261  00104 : [27 29] >
02307  00044 : [28 29] 7
02310  00047 : [28 29] 9A0562132A
02311  00049 : [28 29] 1060 [0d]
02368  00106 : [28 29]  [0d]
02372  00109 : [28 29] >
02412  00039 : [29 29] 7
02416  00043 : [29 29] 9
02418  00045 : [29 29] A07621255000000
02420  00047 : [29 29] 00 [0d]
02474  00102 : [29 29]  [0d]
02476  00104 : [29 29] >
02548  00070 : [30 29] 7
02550  00072 : [30 29] 9A0562130480B
02561  00083 : [30 29] A [0d]
02589  00111 : [30 29]  [0d]
02593  00115 : [30 29] >
02640  00047 : [31 29] 7
02643  00049 : [31 29] 9A07621
02644  00051 : [31 29] 23400000A0A [0d]
02699  00106 : [31 29]  [0d]
02703  00109 : [31 29] >
02742  00039 : [32 29] 7
02746  00042 : [32 29] 9A07621203005
02748  00044 : [32 29] CFFFF [0d]
02804  00100 : [32 29]  [0d]
02840  00136 : [32 29] >
02880  00040 : [33 29] 7
02884  00043 : [33 29] 9
02886  00045 : [33 29] A076212050C40F
02889  00048 : [33 29] FFF [0d]
02943  00102 : [33 29]  [0d]
02945  00104 : [33 29] >
02962  00015 : [45 29] O
02966  00019 : [45 29] K [0d]  [0d] >
03006  00039 : [46 29] 7
03008  00041 : [46 29] 93056
03010  00044 : [46 29] 212100000 [0d]
03063  00096 : [46 29]  [0d]
03066  00100 : [46 29] >
03105  00039 : [47 29] 7
03108  00042 : [47 29] 93056212300118
03111  00044 : [47 29]  [0d]
03171  00104 : [47 29]  [0d] >
03190  00019 : [58 29] O
03195  00023 : [58 29] K [0d]  [0d]
03197  00025 : [58 29] >
03235  00038 : [59 29] O
03237  00039 : [59 29] K
03240  00042 : [59 29]  [0d]  [0d] >
03280  00040 : [60 29] O
03283  00042 : [60 29] K [0d]  [0d] >
03322  00038 : [61 29] 7
03324  00040 : [61 29] 63108261010
03388  00104 : [61 29] 0000000 [0d] 7632100
03393  00109 : [61 01] 000001143600 [0d]
03395  00112 : [61 02]  [0d]
03398  00114 : [61 02] >
03438  00044 : [62 02] O
03445  00046 : [62 02] K [0d]  [0d] >
03492  00047 : [63 02] O
03495  00049 : [63 02] K
03497  00051 : [63 02]  [0d]  [0d] >
03533  00035 : [64 02] O
03547  00049 : [64 02] K [0d]  [0d] >
03622  00065 : [65 02] 7
03624  00068 : [65 02] 65037
03627  00072 : [65 02] F2112 [0d]
03682  00125 : [65 02]  [0d]
03707  00150 : [65 02] >
03778  00070 : [66 02] 7
03781  00073 : [66 02] 65100B611000000000 [0d]
03788  00080 : [66 02] 765210000000000FF
03799  00091 : [66 02] FF [0d]
03844  00137 : [66 02]  [0d]
03848  00141 : [66 02] >
00016  00016 : [16 02] O
00020  00020 : [16 02] K [0d]  [0d] >
00046  00025 : [17 02] O
00047  00027 : [17 02] K [0d]  [0d] >
00095  00046 : [18 02] O
00097  00049 : [18 02] K [0d]
00132  00083 : [18 02]  [0d] >
00179  00046 : [19 02] 1
00181  00048 : [19 02] 3.1V [0d]  [0d] >
00220  00038 : [20 02] 7
00223  00041 : [20 02] BB10296101F
00226  00045 : [20 02] FFFD23F [0d]
00230  00048 : [20 01] 7BB210288FFFFDD23FF [0d]
00260  00079 : [20 02] 7
00263  00081 : [20 02] BB22FFFFF
00265  00083 : [20 02] F070E2AF8 [0d]
00298  00116 : [20 03] 7
00301  00119 : [20 03] BB2395
00303  00122 : [20 03] B73302039300 [0d]
00308  00127 : [20 04] 7
00311  00130 : [20 04] BB245
00314  00132 : [20 04] C1C6D000B6C66 [0d]
00346  00164 : [20 05] 7
00349  00167 : [20 05] B
00353  00172 : [20 05] B250008A1218000
00356  00174 : [20 05] 01 [0d]
00412  00230 : [20 06]  [0d]
00414  00232 : [20 06] >
00454  00039 : [21 06] 7
00457  00043 : [21 06] BB10106104
00460  00046 : [21 06] 02680A02 [0d]
00463  00048 : [21 01] 7BB21690A02680A0267 [0d]
00494  00079 : [21 02] 7
00497  00083 : [21 02] BB220A0
00530  00116 : [21 02] A00FFFFFFFF [0d]
00556  00142 : [21 03]  [0d]
00559  00144 : [21 03] >
00578  00018 : [22 03] 7
00582  00022 : [22 03] BB10
00585  00026 : [22 03] 1A610604000000 [0d]
00589  00030 : [22 01] 7BB210000
00593  00033 : [22 01] 0000000000 [0d]
00628  00068 : [22 02] 7
00631  00072 : [22 02] B
00633  00073 : [22 02] B2200020000000
00636  00076 : [22 02] 000 [0d]
00675  00120 : [22 03] 7
00681  00121 : [22 03] BB2300
00683  00125 : [22 03] 0002000000FF [0d]
00734  00174 : [22 04]  [0d]
00736  00176 : [22 04] >
00776  00040 : [23 04] 7
00780  00044 : [23 04] BB10C661020FA60F96
00782  00046 : [23 04]  [0d] 7BB210F9E0
00791  00054 : [23 01] F9F0F9E0F [0d]
00820  00083 : [23 02] 7
00823  00087 : [23 02] BB229A0F
00826  00089 : [23 02] A20F9E0F9E [0d]
00856  00119 : [23 03] 7
00860  00123 : [23 03] BB2
00871  00137 : [23 03] 30F9E0F9E0F9A0F
00876  00139 : [23 03]  [0d]
00989  00252 : [23 04] 7
00990  00254 : [23 04] BB249E0F9
00992  00255 : [23 04] A0F9A0F9A [0d]
00999  00273 : [23 05] 7
01015  00282 : [23 05] BB250F9A0F9A0F9D0F [0d] 7BB269B0F980F9D0F98 [0d] 7BB270F9A0F9D0F980F [0d]
01041  00304 : [23 08] 7
01047  00310 : [23 08] BB28980F9A0F
01052  00316 : [23 08] 9A0F9B [0d]
01068  00331 : [23 09] 7
01075  00338 : [23 09] BB290F9
01079  00342 : [23 09] E0F9F0F9E0F [0d]
01085  00353 : [23 10] 7
01099  00362 : [23 10] BB2A9E0F9
01100  00364 : [23 10] A0F9B0F9E [0d]
01103  00366 : [23 11] 7
01120  00383 : [23 11] BB2B
01127  00393 : [23 11] 0F9A0F9A0F9B0F [0d]
01133  00396 : [23 12] 7
01136  00399 : [23 12] BB2C
01138  00401 : [23 12] 9E0F9A0F9E0F9A [0d]
01150  00414 : [23 13] 7
01153  00416 : [23 13] B
01154  00417 : [23 13] B2D0F9A0F9A0F9
01156  00419 : [23 13] E0F [0d]
01166  00430 : [23 14] 7
01169  00432 : [23 14] BB2E9
01171  00435 : [23 14] A0FA20F9E0F98 [0d]
01212  00475 : [23 15] 7
01261  00525 : [23 15] BB2F0F9F0F
01265  00529 : [23 15] 9E0F9F0F [0d]
01270  00533 : [23 16] 7
01272  00535 : [23 16] BB209E0F9A0F9D0F9D [0d] 7BB210F9D0
01275  00538 : [23 17] F9A0F9A0F [0d]
01302  00566 : [23 18] 7
01306  00569 : [23 18] BB22960F9A0
01308  00571 : [23 18] F9A0F9E [0d]
01339  00604 : [23 19] 7
01343  00607 : [23 19] BB230
01347  00610 : [23 19] F9E0F9A0F9B0F [0d]
01350  00613 : [23 20] 7
01353  00616 : [23 20] BB249A0
01354  00618 : [23 20] F9B0F9B0F9B [0d]
01386  00650 : [23 21] 7
01390  00653 : [23 21] BB250F9B0F960F
01392  00655 : [23 21] 9B0F [0d]
01424  00688 : [23 22] 7
01429  00692 : [23 22] BB
01432  00695 : [23 22] 26960F9A0F9A0F9
01444  00707 : [23 22] F [0d]
01452  00715 : [23 23] 7
01453  00717 : [23 23] BB270F9B0F960
01455  00718 : [23 23] F9B0F [0d]
01476  00742 : [23 24] 7
01481  00745 : [23 24] BB28920F9A0FA20F9D [0d]
01512  00775 : [23 25] 7
01515  00778 : [23 25] BB290F9D0F
01554  00817 : [23 25] 9E0F9A0F [0d]
01557  00820 : [23 26] 7
01559  00822 : [23 26] BB2A9A0F9F
01562  00826 : [23 26] 0F9C0F9A [0d] 7
01565  00828 : [23 27] BB2B0F
01567  00830 : [23 27] 9D0F9A0F9E95 [0d]
01607  00870 : [23 28] 7
01609  00873 : [23 28] BB2CDB9
01612  00875 : [23 28] 5DBFFFFFFFF [0d]
01667  00930 : [23 29]  [0d]
01679  00942 : [23 29] >
01720  00040 : [24 29] O
01723  00043 : [24 29] K [0d]  [0d] >
01776  00052 : [25 29] 7
01779  00055 : [25 29] 9A0250C0 [0d]
01811  00088 : [25 29]  [0d]
01814  00090 : [25 29] >
01853  00038 : [26 29] 7
01856  00042 : [26 29] 9A0762
01859  00044 : [26 29] 124E00BB0065 [0d]
01915  00100 : [26 29]  [0d]
01917  00103 : [26 29] >
01958  00039 : [27 29] 7
01960  00042 : [27 29] 9A0762
01962  00043 : [27 29] 115D65326500 [0d]
02019  00100 : [27 29]  [0d]
02022  00104 : [27 29] >
02067  00044 : [28 29] 7
02102  00078 : [28 29] 9A0562
02104  00080 : [28 29] 132A1060 [0d]
02128  00104 : [28 29]  [0d]
02131  00108 : [28 29] >
02171  00039 : [29 29] 7
02174  00041 : [29 29] 9A0762125
02176  00043 : [29 29] 500000000 [0d]
02223  00090 : [29 29]  [0d]
02225  00092 : [29 29] >
02264  00039 : [30 29] 7
02267  00041 : [30 29] 9A0562
02268  00043 : [30 29] 130480BA [0d]
02325  00100 : [30 29]  [0d]
02327  00102 : [30 29] >
02372  00043 : [31 29] 7
02374  00046 : [31 29] 9A0762
02376  00047 : [31 29] 123400000A0A [0d]
02433  00105 : [31 29]  [0d]
02436  00107 : [31 29] >
02474  00039 : [32 29] 7
02478  00041 : [32 29] 9A0762120300
02480  00044 : [32 29] 5CFFFF [0d]
02537  00100 : [32 29]  [0d]
02539  00102 : [32 29] >
02577  00038 : [33 29] 7
02582  00042 : [33 29] 9A076212050C
02584  00044 : [33 29] 40FFFF [0d]
02639  00099 : [33 29]  [0d]
02673  00134 : [33 29] >
02708  00035 : [45 29] O
02711  00037 : [45 29] K [0d]  [0d] >
02750  00037 : [46 29] 7
02753  00040 : [46 29] 9305621210
02755  00043 : [46 29] 0000 [0d]
02812  00099 : [46 29]  [0d]
02814  00101 : [46 29] >
02853  00038 : [47 29] 7
02856  00041 : [47 29] 9305621230
02858  00043 : [47 29] 0118 [0d]
02915  00101 : [47 29]  [0d]
02918  00103 : [47 29] >
02935  00016 : [58 29] O
02938  00019 : [58 29] K [0d]  [0d] >
02980  00040 : [59 29] O
02982  00042 : [59 29] K
02984  00045 : [59 29]  [0d]  [0d] >
03028  00042 : [60 29] O
03029  00044 : [60 29] K
03031  00045 : [60 29]  [0d]  [0d] >
03091  00060 : [61 29] 7
03095  00063 : [61 29] 6310826101000
03098  00066 : [61 29] 00000 [0d] 763210000
03100  00069 : [61 01] 0001143600 [0d]
03158  00126 : [61 02]  [0d]
03160  00129 : [61 02] >
03200  00039 : [62 02] O
03235  00074 : [62 02] K [0d]  [0d] >
03276  00040 : [63 02] O
03280  00043 : [63 02] K [0d]  [0d] >
03298  00017 : [64 02] O
03301  00020 : [64 02] K [0d]  [0d] >
03374  00071 : [65 02] 7
03377  00074 : [65 02] 65037F2112
03379  00076 : [65 02]  [0d]
03435  00133 : [65 02]  [0d]
03437  00135 : [65 02] >
03477  00038 : [66 02] 7
03478  00041 : [66 02] 65100B6
03482  00044 : [66 02] 11000000000 [0d]
03485  00046 : [66 02] 7
03488  00049 : [66 02] 65210000000000
03491  00052 : [66 02] FFFF [0d]
03552  00114 : [66 02]  [0d]
03555  00116 : [66 02] >
00017  00017 : [16 02] O
00021  00021 : [16 02] K [0d]  [0d] >
00059  00038 : [17 02] O
00061  00039 : [17 02] K [0d]  [0d] >
00101  00039 : [18 02] O
00103  00041 : [18 02] K [0d]  [0d] >
00151  00045 : [19 02] 1
00153  00047 : [19 02] 3.1V [0d]  [0d] >
00193  00041 : [20 02] 7
00197  00044 : [20 02] BB10296101FFF
00255  00101 : [20 02] FE4DD [0d]
00259  00105 : [20 01] 7BB210288FFFFEFA7FF [0d]
00262  00108 : [20 02] 7
00264  00111 : [20 02] BB22FFFFFF070E2AF8 [0d]
00274  00120 : [20 03] 7
00276  00122 : [20 03] BB2395
00278  00124 : [20 03] A732E8039000 [0d]
00284  00131 : [20 04] 7
00286  00132 : [20 04] BB245C1C6D0
00288  00134 : [20 04] 00B6C07 [0d]
00319  00166 : [20 05] 7
00323  00169 : [20 05] B
00327  00173 : [20 05] B250008A1218000
00329  00175 : [20 05] 05 [0d]
00383  00230 : [20 06]  [0d]
00386  00233 : [20 06] >
00427  00039 : [21 06] 7
00430  00042 : [21 06] BB10106104
00435  00047 : [21 06] 02690A02 [0d]
00437  00049 : [21 01] 7BB21680A02680A0268 [0d]
00466  00078 : [21 02] 7
00478  00090 : [21 02] BB220A0A
00480  00092 : [21 02] 00FFFFFFFF [0d]
00514  00127 : [21 03]  [0d]
00517  00129 : [21 03] >
00561  00043 : [22 03] 7
00563  00046 : [22 03] BB101A61060
00567  00049 : [22 03] 4000000 [0d]
00605  00087 : [22 01] 7BB2100000000000000 [0d]
00608  00090 : [22 02] 7
00610  00092 : [22 02] BB2200020000000000 [0d]
00620  00102 : [22 03] 7
00623  00106 : [22 03] BB2
00625  00107 : [22 03] 3000002000000FF
00628  00110 : [22 03]  [0d]
00689  00171 : [22 04]  [0d]
00715  00197 : [22 04] >
00819  00103 : [23 04] 7
00821  00105 : [23 04] BB10C661020FA60F96 [0d]
00824  00109 : [23 01] 7BB210F9E0F9F0F9A0F [0d]
00827  00111 : [23 02] 7BB229A0F9D0
00829  00114 : [23 02] F9E0F9E [0d]
00849  00134 : [23 03] 7
00852  00136 : [23 03] BB230F9E0
00855  00140 : [23 03] F9E0F9A0F [0d]
00889  00173 : [23 04] 7
00894  00179 : [23 04] BB249E0F9A0
00897  00181 : [23 04] F9A0F96 [0d]
00901  00185 : [23 05] 7
00903  00187 : [23 05] BB250F
00929  00214 : [23 05] 9A0F9A0F9D0F [0d]
00933  00217 : [23 06] 7
00935  00220 : [23 06] BB269B0
00938  00223 : [23 06] F980F9D0F98 [0d]
00970  00255 : [23 07] 7
00974  00259 : [23 07] BB2
01011  00296 : [23 07] 70F9A0F9D0F980F
01014  00298 : [23 07]  [0d]
01017  00301 : [23 08] 7
01019  00304 : [23 08] BB28980F9A0F9A0F9B [0d]
01045  00330 : [23 09] 7
01050  00334 : [23 09] BB290F9E0F9B0F
01052  00336 : [23 09] 9A0F [0d]
01055  00339 : [23 10] 7B
01059  00343 : [23 10] B2A9E0F9A0F9B0
01060  00345 : [23 10] F9E [0d]
01093  00377 : [23 11] 7
01095  00379 : [23 11] BB2B0F9A0F9
01097  00382 : [23 11] A0F9B0F [0d]
01126  00410 : [23 12] 7
01130  00414 : [23 12] B
01137  00421 : [23 12] B2C9E0F9A0F9E0
01141  00425 : [23 12] F9A [0d]
01149  00433 : [23 13] 7
01159  00447 : [23 13] BB2D0F9
01164  00449 : [23 13] A0F9A0F9E0F [0d]
01181  00465 : [23 14] 7
01186  00471 : [23 14] BB2E9A0FA20F9
01194  00478 : [23 14] E0F98 [0d]
01209  00494 : [23 15] 7
01216  00501 : [23 15] BB2F
01218  00502 : [23 15] 0F9F0F9E0F9A0F [0d]
01240  00524 : [23 16] 7
01242  00527 : [23 16] BB20
01336  00621 : [23 16] 9E0F9A0F990F94 [0d]
01341  00625 : [23 17] 7
01343  00627 : [23 17] BB210F990F970F970F [0d] 7BB22920F970F970F9B [0d] 7BB230F960F960F970F [0d]
01366  00650 : [23 20] 7
01369  00653 : [23 20] BB24920F970F97
01371  00655 : [23 20] 0F93 [0d]
01399  00684 : [23 21] 7
01402  00687 : [23 21] BB250F980
01405  00690 : [23 21] F920F930F [0d]
01409  00694 : [23 22] 7
01412  00696 : [23 22] BB26930F9
01416  00701 : [23 22] 20F920F97 [0d]
01451  00736 : [23 23] 7
01455  00739 : [23 23] BB
01457  00741 : [23 23] 270F930
01459  00743 : [23 23] F930F970F [0d]
01490  00774 : [23 24] 7
01501  00787 : [23 24] BB288
01504  00789 : [23 24] E0F970F990F99 [0d]
01508  00792 : [23 25] 7BB290F990F9B0F970F [0d]
01541  00825 : [23 26] 7
01544  00829 : [23 26] BB2
01546  00831 : [23 26] A970F9B0F930F96
01548  00832 : [23 26]  [0d]
01579  00864 : [23 27] 7
01584  00868 : [23 27] BB2B0F990F960F
01585  00870 : [23 27] 9B95 [0d]
01590  00875 : [23 28] 7
01626  00910 : [23 28] B
01628  00912 : [23 28] B2CB495DBFFFFF
01629  00914 : [23 28] FFF [0d]
01662  00946 : [23 29]  [0d]
01665  00949 : [23 29] >
01703  00037 : [24 29] O
01705  00039 : [24 29] K [0d]  [0d] >
01723  00017 : [25 29] 7
01728  00021 : [25 29] 9A0250C0 [0d]
01787  00080 : [25 29]  [0d]
01791  00084 : [25 29] >
01832  00051 : [26 29] 7
01845  00053 : [26 29] 9A0762
01874  00082 : [26 29] 124E00BB0065 [0d]
01896  00104 : [26 29]  [0d]
01898  00106 : [26 29] >
01973  00046 : [27 29] 79A0762115D65326500 [0d]
02028  00101 : [27 29]  [0d]
02031  00104 : [27 29] >
02071  00039 : [28 29] 7
02074  00042 : [28 29] 9A0562
02080  00050 : [28 29] 132A1060 [0d]
02141  00110 : [28 29]  [0d]
02147  00116 : [28 29] >
02188  00040 : [29 29] 7
02192  00043 : [29 29] 9A0762
02193  00045 : [29 29] 125500000000 [0d]
02249  00101 : [29 29]  [0d]
02299  00151 : [29 29] >
02352  00052 : [30 29] 7
02355  00054 : [30 29] 9A0562
02357  00056 : [30 29] 130480BA [0d]
02411  00110 : [30 29]  [0d]
02413  00112 : [30 29] >
02461  00047 : [31 29] 7
02462  00049 : [31 29] 9A076212340
02467  00054 : [31 29] 0000A0A [0d]
02526  00113 : [31 29]  [0d]
02529  00115 : [31 29] >
02569  00039 : [32 29] 7
02571  00042 : [32 29] 9A0
02574  00044 : [32 29] 7621203005CFFFF
02576  00046 : [32 29]  [0d]
02630  00100 : [32 29]  [0d]
02632  00102 : [32 29] >
02672  00039 : [33 29] 7
02677  00044 : [33 29] 9A0
02679  00046 : [33 29] 76212050C40FFFF
02681  00048 : [33 29]  [0d]
02735  00102 : [33 29]  [0d]
02737  00104 : [33 29] >
02754  00017 : [45 29] O
02756  00018 : [45 29] K [0d]  [0d] >
02795  00039 : [46 29] 7
02797  00041 : [46 29] 930
02800  00043 : [46 29] 56212100000 [0d]
02887  00130 : [46 29]  [0d]
02889  00132 : [46 29] >
02928  00039 : [47 29] 7
02933  00042 : [47 29] 9305621230011
02935  00044 : [47 29] 8 [0d]
02991  00100 : [47 29]  [0d]
02993  00102 : [47 29] >
03011  00017 : [58 29] O
03013  00019 : [58 29] K [0d]  [0d]
03016  00022 : [58 29] >
03064  00053 : [59 29] O
03071  00055 : [59 29] K
03089  00073 : [59 29]  [0d]  [0d] >
03130  00039 : [60 29] O
03135  00045 : [60 29] K
03141  00050 : [60 29]  [0d]  [0d] >
03218  00076 : [61 29] 7
03221  00079 : [61 29] 63108261010000000
03230  00088 : [61 29] 0 [0d] 7632100000001143600 [0d]
03283  00142 : [61 02]  [0d]
03286  00144 : [61 02] >
03345  00059 : [62 02] O
03348  00061 : [62 02] K [0d]  [0d] >
03387  00040 : [63 02] O
03391  00043 : [63 02] K [0d]  [0d] >
03413  00019 : [64 02] O
03416  00022 : [64 02] K [0d]  [0d]
03418  00024 : [64 02] >
03514  00095 : [65 02] 7
03516  00097 : [65 02] 65037F2112 [0d]
03542  00123 : [65 02]  [0d]
03544  00125 : [65 02] >
03583  00038 : [66 02] 7
03585  00040 : [66 02] 65100
03590  00046 : [66 02] B611000000000 [0d]
03593  00049 : [66 02] 7
03596  00051 : [66 02] 6521000000
03599  00054 : [66 02] 0000FFFF [0d]
03663  00118 : [66 02]  [0d]
03665  00120 : [66 02] >
00016  00017 : [16 02] O
00019  00019 : [16 02] K [0d]  [0d] >
00058  00037 : [17 02] O
00061  00041 : [17 02] K [0d]  [0d] >
00105  00042 : [18 02] K [0d]  [0d]
00107  00044 : [18 02] >
00152  00044 : [19 02] 1
00154  00046 : [19 02] 3.1V [0d]  [0d] >
00193  00038 : [20 02] 7
00196  00041 : [20 02] BB1029610
00199  00044 : [20 02] 1FFFFCD61 [0d]
00203  00047 : [20 01] 7BB
00205  00049 : [20 01] 210288FFFFDD5BFF [0d]
00237  00081 : [20 02] 7
00239  00083 : [20 02] BB22FFFF
00276  00120 : [20 02] FF07102AF8 [0d]
00279  00123 : [20 03] 7
00281  00125 : [20 03] BB2395D032D603
00283  00127 : [20 03] 8A00 [0d]
00310  00154 : [20 04] 7
00315  00159 : [20 04] B
00316  00161 : [20 04] B245C1C6D000B6
00319  00164 : [20 04] BA2 [0d] 7BB2
00324  00168 : [20 05] 500
00325  00170 : [20 05] 08A121800001 [0d]
00380  00224 : [20 06]  [0d]
00383  00227 : [20 06] >
00427  00043 : [21 06] 7
00430  00046 : [21 06] BB10
00434  00050 : [21 06] 10610402680A02 [0d]
00437  00053 : [21 01] 7BB21690A02680A0267 [0d]
00466  00084 : [21 02] 7
00470  00087 : [21 02] BB220A0A00FFFF
00472  00089 : [21 02] FFFF [0d]
00529  00145 : [21 03]  [0d]
00531  00147 : [21 03] >
00574  00043 : [22 03] 7
00581  00049 : [22 03] BB101A610604
00583  00051 : [22 03] 000000 [0d]
00585  00054 : [22 01] 7BB2100000000000000 [0d]
00615  00083 : [22 02] 7
00618  00086 : [22 02] BB2200020
00620  00088 : [22 02] 000000001 [0d]
00659  00127 : [22 03] 7
00661  00130 : [22 03] BB23070002
00663  00132 : [22 03] 000000FF [0d]
00690  00159 : [22 04]  [0d] >
00729  00038 : [23 04] 7
00733  00041 : [23 04] BB10C661020FA
00736  00044 : [23 04] 30F93 [0d]
00739  00047 : [23 01] 7BB210F9B0F970F960F [0d]
00770  00078 : [23 02] 7
00774  00082 : [23 02] B
00776  00084 : [23 02] B22960F990F9B0F9
00778  00086 : [23 02] B [0d]
00782  00091 : [23 03] 7
00784  00093 : [23 03] BB23
00790  00098 : [23 03] 0F960F960F920F [0d]
00826  00134 : [23 04] 7
00829  00137 : [23 04] BB24960F970F
00831  00139 : [23 04] 970F92 [0d]
00862  00170 : [23 05] 7
00866  00174 : [23 05] B
00868  00179 : [23 05] B250F920F970F99
00873  00182 : [23 05] 0F [0d]
00877  00185 : [23 06] 7
00879  00187 : [23 06] BB26970F
00881  00189 : [23 06] 940F940F94 [0d]
00911  00220 : [23 07] 7
00915  00223 : [23 07] BB270F920F990F
00917  00225 : [23 07] 940F [0d]
00994  00302 : [23 08] 7
00996  00304 : [23 08] BB289
00998  00306 : [23 08] 40F960F970F93 [0d]
01001  00309 : [23 09] 7BB290F9B0F970F960F [0d]
01006  00314 : [23 10] 7
01009  00317 : [23 10] B
01012  00320 : [23 10] B2A960F960F970F
01014  00322 : [23 10] 9B [0d]
01045  00353 : [23 11] 7
01049  00357 : [23 11] B
01051  00360 : [23 11] B2B0F970F970F97
01053  00362 : [23 11] 0F [0d]
01057  00365 : [23 12] 7
01061  00370 : [23 12] BB2C9B0F970F9
01064  00372 : [23 12] 60F92 [0d]
01097  00405 : [23 13] 7
01099  00407 : [23 13] BB2D0F97
01101  00409 : [23 13] 0F970F960F [0d]
01111  00420 : [23 14] 7
01114  00422 : [23 14] BB2E970
01119  00428 : [23 14] F9E0F9B0F94 [0d]
01153  00462 : [23 15] 7
01156  00465 : [23 15] BB2F0F9B0
01158  00467 : [23 15] F9B0F970F [0d]
01191  00499 : [23 16] 7
01194  00502 : [23 16] BB209B
01196  00505 : [23 16] 0F970F990F94 [0d]
01228  00536 : [23 17] 7
01267  00576 : [23 17] BB210F950F970
01269  00578 : [23 17] F970F [0d]
01272  00580 : [23 18] 7
01276  00584 : [23 18] BB22920
01278  00587 : [23 18] F970F920F96 [0d]
01282  00590 : [23 19] 7
01284  00592 : [23 19] BB2
01286  00594 : [23 19] 30F960F960F970F [0d]
01311  00620 : [23 20] 7
01317  00626 : [23 20] BB24920F970F97
01320  00628 : [23 20] 0F8E [0d]
01325  00633 : [23 21] 7
01328  00636 : [23 21] B
01331  00639 : [23 21] B250F9C0F8E0F9
01333  00641 : [23 21] 30F [0d]
01364  00674 : [23 22] 7
01367  00676 : [23 22] BB26930F97
01369  00678 : [23 22] 0F920F97 [0d]
01405  00713 : [23 23] 7BB270F930F930F970F [0d]
01420  00728 : [23 24] 7
01423  00733 : [23 24] BB288E0
01427  00735 : [23 24] F970F9E0F99 [0d]
01457  00765 : [23 25] 7
01460  00768 : [23 25] BB290F9
01463  00771 : [23 25] 90F9B0F970F [0d]
01494  00803 : [23 26] 7
01497  00806 : [23 26] BB2A
01499  00807 : [23 26] 970F9B0F930F96 [0d]
01565  00873 : [23 27] 7
01567  00875 : [23 27] BB2B0F99
01572  00880 : [23 27] 0F960F9B95 [0d]
01574  00882 : [23 28] 7BB2CDB95ABFFFFFFFF [0d]
01591  00900 : [23 29]  [0d]
01593  00902 : [23 29] >
01636  00040 : [24 29] O
01639  00044 : [24 29] K [0d]  [0d] >
01686  00045 : [25 29] 7
01690  00048 : [25 29] 9A0250C0
01692  00050 : [25 29]  [0d]
01721  00080 : [25 29]  [0d]
01725  00083 : [25 29] >
01765  00039 : [26 29] 7
01768  00042 : [26 29] 9A0762124E0
01770  00044 : [26 29] 0BB0065 [0d]
01827  00101 : [26 29]  [0d]
01829  00103 : [26 29] >
01869  00039 : [27 29] 7
01872  00042 : [27 29] 9A0762115D6
01873  00044 : [27 29] 5326500 [0d]
01905  00075 : [27 29]  [0d]
01907  00078 : [27 29] >
01929  00019 : [28 29] 7
01934  00026 : [28 29] 9A0562132A1060
01938  00029 : [28 29]  [0d]
01995  00085 : [28 29]  [0d]
01997  00087 : [28 29] >
02070  00072 : [29 29] 7
02073  00075 : [29 29] 9A076212
02075  00078 : [29 29] 5500000000 [0d]
02100  00102 : [29 29]  [0d]
02102  00105 : [29 29] >
02143  00040 : [30 29] 7
02145  00041 : [30 29] 9A05621
02147  00043 : [30 29] 30480BA [0d]
02178  00074 : [30 29]  [0d]
02182  00079 : [30 29] >
02237  00055 : [31 29] 7
02240  00057 : [31 29] 9A076212340
02242  00059 : [31 29] 0000A0A [0d]
02272  00088 : [31 29]  [0d]
02275  00091 : [31 29] >
02315  00039 : [32 29] 7
02317  00041 : [32 29] 9A076
02318  00043 : [32 29] 21203005CFFFF [0d]
02375  00099 : [32 29]  [0d]
02377  00101 : [32 29] >
02418  00040 : [33 29] 7
02420  00042 : [33 29] 9A076
02424  00046 : [33 29] 212050C40FFFF [0d]
02485  00107 : [33 29]  [0d]
02488  00110 : [33 29] >
02509  00020 : [45 29] O
02513  00024 : [45 29] K [0d]  [0d] >
02553  00040 : [46 29] 7
02648  00133 : [46 29] 93056212
02650  00135 : [46 29] 100000 [0d]
02659  00144 : [46 29]  [0d]
02661  00146 : [46 29] >
02705  00044 : [47 29] 7
02708  00046 : [47 29] 93056212300118 [0d]
02740  00079 : [47 29]  [0d]
02751  00089 : [47 29] >
02768  00017 : [58 29] O
02772  00020 : [58 29] K
02774  00022 : [58 29]  [0d]  [0d] >
02818  00044 : [59 29] O
02821  00047 : [59 29] K [0d]  [0d] >
02860  00037 : [60 29] O
02862  00039 : [60 29] K [0d]  [0d] >
02906  00043 : [61 29] 7
02908  00045 : [61 29] 631
02912  00049 : [61 29] 082610100000000
02920  00057 : [61 29]  [0d] 76321000000011
02923  00060 : [61 01] 43600 [0d]
02979  00116 : [61 02]  [0d]
02981  00118 : [61 02] >
03021  00039 : [62 02] O
03023  00041 : [62 02] K [0d]  [0d] >
03040  00017 : [63 02] O
03044  00020 : [63 02] K [0d]  [0d] >
03061  00017 : [64 02] O
03064  00020 : [64 02] K [0d]  [0d] >
03162  00096 : [65 02] 7
03164  00099 : [65 02] 65037F
03167  00102 : [65 02] 2112 [0d]
03189  00123 : [65 02]  [0d]
03191  00126 : [65 02] >
03230  00037 : [66 02] 7
03232  00039 : [66 02] 6
03235  00042 : [66 02] 5100B6110000000
03238  00045 : [66 02] 00 [0d]
03241  00049 : [66 02] 7652100000
03245  00053 : [66 02] 00000FFFF [0d]
03309  00116 : [66 02]  [0d] >
00024  00025 : [16 02] OK [0d]  [0d] >
00065  00039 : [17 02] O
00067  00041 : [17 02] K [0d]  [0d] >
00106  00038 : [18 02] O
00110  00043 : [18 02] K [0d]  [0d] >
00156  00044 : [19 02] 1
00158  00046 : [19 02] 3.0V [0d]  [0d] >
00208  00049 : [20 02] 7
00211  00052 : [20 02] BB10296
00213  00053 : [20 02] 101FFFFE4DD [0d]
00240  00081 : [20 01] 7BB210288FFFFDF80FF [0d]
00243  00084 : [20 02] 7
00252  00093 : [20 02] BB22F
00257  00101 : [20 02] FFFFF07102AF8 [0d]
00263  00104 : [20 03] 7BB2395CF32C
00265  00105 : [20 03] 4038E00 [0d]
00329  00170 : [20 04] 7
00332  00173 : [20 04] BB
00334  00174 : [20 04] 245C1C6D000B6B4
00336  00176 : [20 04] 6 [0d]
00338  00179 : [20 05] 7
00340  00181 : [20 05] BB2500
00342  00182 : [20 05] 08A121800001 [0d]
00391  00231 : [20 06]  [0d]
00400  00240 : [20 06] >
00442  00042 : [21 06] 7
00447  00046 : [21 06] BB101061
00449  00048 : [21 06] 0402680A02 [0d]
00451  00050 : [21 01] 7BB21690A02680A0267 [0d]
00482  00081 : [21 02] 7
00490  00089 : [21 02] BB220A
00492  00091 : [21 02] 0A00FFFFFFFF [0d]
00541  00140 : [21 03]  [0d]
00546  00145 : [21 03] >
00572  00025 : [22 03] 7
00577  00030 : [22 03] BB1
00580  00034 : [22 03] 01A610604000000 [0d]
00584  00037 : [22 01] 7
00597  00051 : [22 01] BB2100000000000
00599  00053 : [22 01] 000 [0d]
00627  00080 : [22 02] 7
00630  00084 : [22 02] BB220002000000000
00638  00092 : [22 02] 1 [0d]
00662  00116 : [22 03] 7
00758  00211 : [22 03] BB2307000200
00760  00213 : [22 03] 0000FF [0d]
00771  00224 : [22 04]  [0d]
00773  00226 : [22 04] >
00824  00050 : [23 04] 7
00830  00057 : [23 04] BB10C661020F
00833  00059 : [23 04] A60F96 [0d] 7B
00835  00061 : [23 01] B210F9E0F9F0F9A0F [0d]
00863  00089 : [23 02] 7
00876  00103 : [23 02] BB
00880  00106 : [23 02] 229A0F9D0F9E0F9
00882  00108 : [23 02] E [0d]
00890  00116 : [23 03] 7
00894  00122 : [23 03] BB230F9
00898  00124 : [23 03] E0F9E0F960F [0d]
00923  00149 : [23 04] 7
00927  00154 : [23 04] BB249E0F9A0F9A0F9
00929  00156 : [23 04] 6 [0d]
00961  00187 : [23 05] 7
00965  00191 : [23 05] BB250F9A0F9A0F9D0F [0d]
00972  00198 : [23 06] 7
00977  00204 : [23 06] BB269B0F980F98
00980  00207 : [23 06] 0F98 [0d]
01012  00239 : [23 07] 7
01015  00242 : [23 07] BB270F9A0F9D0F980F [0d]
01051  00278 : [23 08] 7
01053  00280 : [23 08] BB28980F9A0F9A0F9B [0d]
01062  00288 : [23 09] 7
01184  00410 : [23 09] BB2
01187  00413 : [23 09] 90F9E0F9B0F9A0F
01189  00415 : [23 09]  [0d] 7BB2A9A0F9A0F9B0F9E [0d] 7BB2B0F9A0F9A0F9B0F [0d] 7BB2C9E0F9A0F9E0F96 [0d]
01213  00439 : [23 13] 7
01215  00442 : [23 13] BB2D0F9
01231  00463 : [23 13] A0F9A0F9E0F [0d]
01239  00465 : [23 14] 7
01241  00467 : [23 14] BB2E9A0FA2
01258  00484 : [23 14] 0F9E0F98 [0d]
01268  00495 : [23 15] 7
01275  00501 : [23 15] BB2F0F9F
01279  00505 : [23 15] 0F9E0F9A0F [0d]
01281  00508 : [23 16] 7
01299  00525 : [23 16] BB209E0F9
01309  00535 : [23 16] A0F9E0F9D [0d]
01321  00547 : [23 17] 7
01324  00550 : [23 17] BB21
01326  00552 : [23 17] 0F9D0F9A0F9A0F [0d]
01343  00569 : [23 18] 7
01345  00571 : [23 18] BB2296
01354  00580 : [23 18] 0F9A0F9A0F9E [0d]
01373  00600 : [23 19] 7
01376  00602 : [23 19] B
01380  00606 : [23 19] B230F9E0F9A0F9B
01382  00608 : [23 19] 0F [0d]
01413  00640 : [23 20] 7
01419  00646 : [23 20] BB24960F9B0F9F0F96
01421  00648 : [23 20]  [0d]
01503  00730 : [23 21] 7
01511  00738 : [23 21] BB250FA00F960
01513  00740 : [23 21] F9B0F [0d] 7BB26960F9A0F9A0F9A [0d] 7BB270F9B0F960F9B0F [0d]
01528  00756 : [23 24] 7
01532  00759 : [23 24] BB28920F9A0FA
01542  00769 : [23 24] 20F9D [0d]
01563  00790 : [23 25] 7
01567  00793 : [23 25] BB290F9D0F9E0F9B0F [0d]
01572  00798 : [23 26] 7
01579  00805 : [23 26] BB2A9A0F9
01582  00808 : [23 26] F0F9C0F9A [0d]
01622  00849 : [23 27] 7
01625  00852 : [23 27] BB2B0F9D0F9A
01628  00855 : [23 27] 0F9E95 [0d]
01632  00858 : [23 28] 7
01634  00861 : [23 28] BB2CC79
01638  00864 : [23 28] 5DBFFFFFFFF [0d]
01697  00924 : [23 29]  [0d]
01700  00926 : [23 29] >
01740  00039 : [24 29] O
01742  00041 : [24 29] K [0d]  [0d] >
01787  00045 : [25 29] 7
01795  00053 : [25 29] 9A0250C0 [0d]
01834  00091 : [25 29]  [0d]
01836  00093 : [25 29] >
01876  00040 : [26 29] 7
01883  00047 : [26 29] 9A0762124E00BB0065 [0d]
01938  00101 : [26 29]  [0d]
02020  00188 : [26 29] >
02073  00047 : [27 29] 7
02077  00051 : [27 29] 9A0762115D65326500 [0d]
02135  00108 : [27 29]  [0d]
02138  00111 : [27 29] >
02185  00046 : [28 29] 7
02188  00049 : [28 29] 9A0562132A1060 [0d]
02246  00108 : [28 29]  [0d]
02249  00110 : [28 29] >
02287  00038 : [29 29] 7
02290  00041 : [29 29] 9A076
02293  00043 : [29 29] 2125500000000 [0d]
02349  00099 : [29 29]  [0d]
02351  00101 : [29 29] >
02390  00038 : [30 29] 7
02393  00041 : [30 29] 9A056213048
02395  00043 : [30 29] 0BA [0d]
02451  00099 : [30 29]  [0d]
02453  00101 : [30 29] >
02497  00043 : [31 29] 7
02502  00049 : [31 29] 9A076212340
02505  00051 : [31 29] 0000A0A [0d]
02560  00106 : [31 29]  [0d]
02563  00109 : [31 29] >
02603  00039 : [32 29] 7
02607  00044 : [32 29] 9A
02610  00046 : [32 29] 07621203005CFFF
02612  00049 : [32 29] F [0d]
02755  00191 : [32 29]  [0d]
02766  00203 : [32 29] >
02783  00015 : [33 29]  Connected 33 29
02974  00207 : [33 29] 7
02976  00209 : [33 29] 9A07621205
02978  00210 : [33 29] 0C40FFFF [0d]
02987  00219 : [33 29]  Connected 33 29
03117  00349 : [33 29]  Connected 33 29
03119  00351 : [33 29]  [0d]
03170  00402 : [33 29] >
03299  00129 : [45 29] O
03304  00133 : [45 29] K [0d]  [0d] >
03312  00008 : [46 29]  Connected 46 29
03345  00041 : [46 29] 7
03348  00043 : [46 29] 9305
03350  00045 : [46 29] 6212100000 [0d]
03407  00103 : [46 29]  [0d]
03418  00113 : [46 29]  Connected 46 29
03431  00126 : [46 29] >
03473  00042 : [47 29] 7
03476  00044 : [47 29] 9305
03478  00046 : [47 29] 6212300118 [0d]
03513  00081 : [47 29]  Connected 47 29
03642  00210 : [47 29]  Connected 47 29
03738  00306 : [47 29]  [0d]
03746  00315 : [47 29]  Connected 47 29
03749  00318 : [47 29] >
03769  00018 : [58 29] O
03773  00022 : [58 29] K [0d]  [0d] >
03812  00039 : [59 29] O
03815  00042 : [59 29] K [0d]
03817  00043 : [59 29]  [0d] >
03847  00029 : [60 29]  Connected 60 29
03863  00045 : [60 29] O
03865  00047 : [60 29] K [0d]  [0d] >
03913  00046 : [61 29] 7
03918  00051 : [61 29] 631
03920  00053 : [61 29] 082610100000000
03922  00055 : [61 29]  [0d] 7632100000001143600 [0d]
03947  00080 : [61 02]  Connected 61 02
03977  00110 : [61 02]  [0d]
04015  00148 : [61 02] >
04048  00033 : [62 02]  Connected 62 02
04062  00046 : [62 02] O
04075  00060 : [62 02] K [0d]  [0d] >
04115  00038 : [63 02] O
04117  00040 : [63 02] K [0d]  [0d] >
04150  00032 : [64 02]  Connected 64 02
04173  00056 : [64 02] O
04197  00079 : [64 02] K [0d]
04199  00081 : [64 02]  [0d] >
04247  00047 : [65 02]  Connected 65 02
04302  00102 : [65 02] 7
04315  00116 : [65 02] 65037F2112 [0d]
04322  00123 : [65 02]  [0d]
04325  00125 : [65 02] >
04347  00021 : [66 02]  Connected 66 02
04365  00040 : [66 02] 7
04368  00042 : [66 02] 6510
04371  00045 : [66 02] 0B611000000000 [0d]
04375  00050 : [66 02] 7
04377  00051 : [66 02] 65210000000000F
04381  00055 : [66 02] FFF [0d]
04440  00114 : [66 02]  [0d]
04442  00116 : [66 02] >
00008  00008 : [16 02]  Connected 16 02
00026  00026 : [16 02] O
00032  00033 : [16 02] K [0d]  [0d] >
00072  00038 : [17 02] O
00073  00040 : [17 02] K [0d]
00075  00042 : [17 02]  [0d] >
00106  00029 : [18 02]  Connected 18 02
00122  00046 : [18 02] O
00125  00048 : [18 02] K [0d]  [0d] >
00173  00047 : [19 02] 1
00175  00048 : [19 02] 3.
00177  00050 : [19 02] 0V [0d]  [0d] >
00206  00029 : [20 02]  Connected 20 02
00301  00123 : [20 02]  Connected 20 02
00399  00221 : [20 02] 7
00439  00261 : [20 02] BB10
00441  00263 : [20 02] 296101FFFFE4DD [0d]
00449  00272 : [20 01]  Connected 20 01
00465  00288 : [20 01] 7BB210288FFFFEEA5FF [0d]
00472  00295 : [20 02] 7
00474  00297 : [20 02] BB22FF
00476  00298 : [20 02] FFFF07102AF8 [0d]
00479  00302 : [20 03] 7
00481  00303 : [20 03] BB2395CE
00483  00305 : [20 03] 32FA038500 [0d]
00486  00308 : [20 04] 7
00488  00310 : [20 04] BB24
00490  00312 : [20 04] 5C1C6D000B6ACD [0d]
00492  00315 : [20 05] 7
00494  00316 : [20 05] BB25
00496  00318 : [20 05] 0008A121800005 [0d]
00499  00322 : [20 06]  [0d]
00502  00324 : [20 06] >
00542  00040 : [21 06] 7
00545  00042 : [21 06] BB1010
00546  00044 : [21 06] 6104
00555  00052 : [21 06]  Connected 21 06
00557  00054 : [21 06] 02680A02 [0d] 7BB21680A02680A0267 [0d]
00584  00082 : [21 02] 7
00586  00083 : [21 02] BB220A0A
00588  00085 : [21 02] 00FFFFFFFF [0d]
00645  00143 : [21 03]  [0d]
00652  00150 : [21 03]  Connected 21 03
00655  00152 : [21 03] >
00788  00132 : [22 03] 7
00790  00134 : [22 03] BB101A610604000000 [0d]
00807  00151 : [22 01]  Connected 22 01
00840  00184 : [22 01] 7BB2100000000000000 [0d]
00846  00191 : [22 02]  [0d]
00853  00197 : [22 02] >
00856  00002 : [23 02] 7
00871  00017 : [23 02] BB2200020000000001 [0d] 7BB23070002000000FF [0d]
02491  01637 : [23 04] BB250FA40F9
02492  01639 : [23 04] 7BB2F0F9F0F9E0F9A0F [0d]
02593  01739 : [23 04] 7
02595  01741 : [23 04] B
02597  01744 : [23 04] B2B0F9D0F9A0F9E
02600  01746 : [23 04] 7
02601  01748 : [23 04] 0F960F9B0F [0d]
02611  01757 : [23 04] F9A [0d]
02629  01776 : [23 04] BB249A
02633  01780 : [23 04] 0F9A0F9A0F96 [0d]
02639  01786 : [23 04]  [0d] 7BB230F9E0F9A0
02644  01791 : [23 04] 7
02646  01792 : [23 04] FFFFFFF [0d]
02651  01797 : [23 04] BB250F9A0
02653  01799 : [23 04]  [0d]
02658  01804 : [23 04] 7BB2D0F9A0F9A0F9E0F [0d]
02666  01813 : [23 05] F9A0F9D0F [0d]
02672  01818 : [23 05] 7
02674  01821 : [23 05] >
02756  00082 : [24 05] BB290F9
02758  00083 : [24 05] BB26
02765  00091 : [24 05] 7BB210F9D0F9A0F9A0F [0d] 7BB22960F
02782  00108 : [24 05]  Connected 24 05
02784  00110 : [24 05] 7BB2E9A0F9D0F9E0F98 [0d]
02830  00155 : [24 05] 8920F9A0FA20F9D
02851  00177 : [24 05] 7
02853  00178 : [24 05] 0F9B0F92 [0d]
02859  00184 : [24 05] 7
02860  00186 : [24 05] BB2C9E0F9
02862  00188 : [24 05] B
02864  00189 : [24 05] 9B0F980F980F98 [0d]
02874  00199 : [24 05] 7
02876  00201 : [24 05] 7
02877  00203 : [24 05] 95 [0d]
02886  00211 : [24 05]  Connected 24 05
02888  00213 : [24 05] 7
02890  00215 : [24 05] BB270F
02892  00217 : [24 05] 9A0F9D0F980F [0d]
02911  00236 : [24 06] B
02914  00239 : [24 06] F9A0F960F9A [0d]
02918  00243 : [24 06] 7
02919  00245 : [24 06] B
02921  00246 : [24 06] 7
02923  00248 : [24 06] D0F9E0F9A0F [0d]
02926  00252 : [24 06] B28980F9A0F9A0F
02929  00254 : [24 06] 96 [0d]
02932  00257 : [24 06] 7
02934  00259 : [24 06] BB24960F9B
02970  00297 : [24 06] A0F9A0F96 [0d]
02976  00301 : [24 06] F [0d]
02980  00305 : [24 06] BB290
02982  00307 : [24 06] 7
02983  00309 : [24 06] F9E0F9B0F9A0F [0d]
03040  00365 : [24 06]  Connected 24 06
03204  00529 : [24 06]  Connected 24 06
03308  00633 : [24 06]  Connected 24 06
03311  00636 : [24 06] BB26960
03312  00638 : [24 06] 7
03315  00640 : [24 06] 7
03316  00641 : [24 06] BB2A9A0F9A0F
03318  00643 : [24 06] 9B0F9E [0d]
03332  00657 : [24 06] B2B0F9A0F9A0F9B0
03334  00659 : [24 06] 7
03335  00661 : [24 06] BB10C661020
03338  00663 : [24 06]  [0d]
03341  00666 : [24 06] FA60F96 [0d] 7
03345  00671 : [24 06] F9B0F [0d]
03348  00673 : [24 06] 7
03350  00675 : [24 06] BB210F9E0F9B0F9A0F [0d]
03354  00679 : [24 07] B2A9A0F9F0F9C0
03356  00681 : [24 07] 7
03358  00683 : [24 07] BB270F9B
03360  00685 : [24 07] BB22
03361  00687 : [24 07] 9A0F9D0F9E0F9E [0d]
03364  00690 : [24 07] 9A0F9A0F9E
03366  00691 : [24 07] 7
03404  00729 : [24 07] 7
03406  00731 : [24 07] 60F960F [0d]
03412  00738 : [24 07]  Connected 24 07
03415  00740 : [24 07] BB230F9E
03417  00742 : [24 07] BB2
03419  00744 : [24 07] 0F9E0F960F [0d]
03422  00747 : [24 07] BB2CDB95BEF
03424  00749 : [24 07] 7
03425  00751 : [24 07] 7BB209E0F9A0F9D0F9D [0d]
