[Ovmsdev] Open Vehicle 3.2.1 (20131211) is now available
Avesh Chauhan
aveshcool at gmail.com
Wed Dec 11 20:09:57 HKT 2013
Dear Mark,
I have just started following your blog and entire project. Is entire
project focussed on electric cars(Roadster $ Leaf) or there are chances
that your solution can be used for other cars too .
I wish to contribute and test with others cars using standard OBD11 and
probably getting more data that simple OBD. But the query is will your app
or server require changes . Since you have codes available online can we
make changes to adjust server/app for various other cars.
Awaiting your reply and guidance.
Avesh
On Wed, Dec 11, 2013 at 5:21 PM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
> Robert,
> This is an update to the Android App (not in-car firmware). I’m still
> working on the Leaf support (but have been ill with flu for the past week).
> Should have a build for you guys any day now.
> On 11 Dec, 2013, at 5:55 pm, Robert Sharpe <
> robert.sharpe at evergreen-consulting.co.uk> wrote:
> Hi Mark,
> Can you confirm if this build supports the Leaf?
> Just to confirm that both Nikki (I assume) and I are standing ready to
> help Leaf testing once firmware is available.
> Look forward to helping out.
> Also, I now have an OBD2 and Leafspy so maybe able to take traces if
> required.
> Rob
> ---- On Wed, 11 Dec 2013 10:25:02 +0100 *Mark
> Webb-Johnson<mark at webb-johnson.net <mark at webb-johnson.net>>* wrote ----
> A good day.
> OVMS Android App v3.2.1 is now released to beta test. You can get it from
> testflightapp:
> http://www.testflightapp.com/install/c514a82bf4936634cbd1f76536c74c67-ODMxNzcwMg/
> We’re using TestFlightApp for both iOS and Android Apps, so it would be
> helpful if you could register there. If you do, you’ll get notified of new
> builds as and when they are released.
> As with the iOS App, we’ve had sponsorship and support from Zero Carbon
> World for this:
> Charging station integration and information provided by Zero Carbon World
> (http://www.zerocarbonworld.org/open-charge-map) and the Open Charge Map
> project (www.openchargemap.org).
> Let me have feedback / problems via testflightapp or here. It is a beta #1
> build, but is functionally complete. The only known issue is a 20 second
> delay when a new car is setup (or the first time the app is run), for
> charge station data to be downloaded.
> *Open Vehicle*
> Version 3.2.1 (20131211) [image: INSTALL]<http://email.n.testflightapp.com/c/YnVpbGRfaWQ9ODMxNzcwMiZkPTViYSZpPTIwMTMxMjExMDkwMDExLjk2My42OTQxMiU0MHdvcmtlcjYuYXMudGVzdGZsaWdodGFwcC5jb20maD1kNDViMGRlN2U0ZjA5Zjk3ODhiN2FjOTQ5NWQ1ZDMxMyZsPWh0dHAlM0ElMkYlMkZ0ZXN0ZmxpZ2h0YXBwLmNvbSUyRmluc3RhbGwlMkZjNTE0YTgyYmY0OTM2NjM0Y2JkMWY3NjUzNmM3NGM2Ny1PRE14Tnpjd01nJTJGJnI9bWFyayU0MHdlYmItam9obnNvbi5uZXQ> (open
> this email on your Android 2.3+ Device and click the install button)
> *What's New*
> v3.2.1 OVMS for Android, with Open Charge Map integration - beta #1
> * 67dd173 Disable two-finger rotation gesture for map
> * 79b70dd Dont show undefined number of charging points as "null"
> * f813df7 Revise clustering factors, to improve usability choices
> * d1786ca Tidy up layout of setting dialog
> * d37d9c7 OCM integration, rough draft
> *Details*
> *Platform:* Android
> *Version:* 3.2.1 (20131211)
> *Team:* Open Vehicles
> *Release Date:* December 11, 2013
> *Size:* 13.4 MB
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131211/70ad4d33/attachment.htm>
