[Ovmsdev] PICkit 2 on V2 OVMS
Wed Dec 4 12:18:13 HKT 2013
Just to follow up on this side-thread...
I am able to problem a V2 board with a PICkit 2 programmer. I doesn't work
from the USB port on the front of my Mac Pro, but it does work from the Mac
Pro when plugged into a powered USB hub or directly from my MacBook Air.
   Tom
Reply-To:  OVMS Developers <ovmsdev at lists.teslaclub.hk>
Date:  Tuesday, October 22, 2013 at 9:34 PM
Subject:  Re: [Ovmsdev] OVMS Leaf Support
I use a PICKIT2 and have had no issues programming the V2 board. Maybe you
have a faulty unit, or your USB port can't supply the required power.
Matt
On Wednesday, October 23, 2013, Mark Webb-Johnson  wrote:
> Tom,
> Strange. I checked a few PICKIT2 I have, and they all work. For my original
> testing, I tried two eBay clones, two fasttech ones, and two little Malaysian
> thumb-drive sized ones - all were ok.
> The OVMS board does have a fairly large modem, which complicates things. Maybe
> just not enough power?
> Can you try to press the little modem power button on the motherboard, to shut
> down the modem? See if that makes a difference.
> On 23 Oct, 2013, at 5:29 am, Tom Saxton <tom at idleloop.com> wrote:
>> I'm not able to program the V2 board with the PICkit2 unless the board
>> plugged into the car to get 12V power, so I'd recommend the PICKit3, which
>> I'm assuming doesn't have this issue.
>> I need to either build a cable to power the OVMS from a power supply or order
>> the PICKit3 from Fasttech. For now, my laptop is living in the Roadster's
>> passenger seat while I've been doing some work on the charge time predictor.
>>    Tom
>> From:  Mark Webb-Johnson <mark at webb-johnson.net>
>> Date:  Monday, October 21, 2013 11:42 PM
>> Rob,
>> If you are not developing code then a PICKIT2 is easier.
>> The original is here:
>>> http://www.amazon.co.uk/Microchip-PG164120-Programmer-Pickit-2/dp/B0040ZRGCQ
>>> /ref=sr_1_4?s=electronics&ie=UTF8&qid=1382423740&sr=1-4&keywords=pickit2
>> but as it is 'open source', there are lots of much cheaper clones. For
>> example:
>>> http://www.fasttech.com/products/0/10000018/1002200-pickit-2-compatible-prog
>>> rammerdebugger
>> Personally, I'd go with the clone.
>> On 22 Oct, 2013, at 2:32 pm, Robert Sharpe
>> <robert.sharpe at evergreen-consulting.co.uk> wrote:
>>> Hi Mark,
>>> Wow great work.
>>> For me my current status is
>>>> Good and frequent access to a Nissan Leaf - YES
>>>> RS232-to-USB adaptor and laptop (or laptop with RS232 port)  - YES
>>>> OVMS v2 Module - Accepted Kevin's offer of h/w waiting for delivery
>>>> OVMS v2 OBD-II cable - Accepted Kevin's offer of h/w waiting for delivery
>>>> PICKIT2 or PICKIT3 programmer - Will order one today (any suggestions to a
>>>> good source?)
>>> Rob
>>> ---- On Tue, 22 Oct 2013 02:11:52 +0100 Mark
>>> Webb-Johnson<mark at webb-johnson.net> wrote ----
>>>> OK, here's an update...
>>>> I went through the logs we captured, and had a look at Leaf Spy. I even
>>>> purchased a copy of Leaf Spy Pro (even though I don't have a Leaf) just as
>>>> a donation to say thank you to Turbo3 for pushing this approach and working
>>>> out so much of the mechanics of it.
>>>> I spent an evening reading thro
OvmsDev at lists.teslaclub.hk
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131203/c767b7c9/attachment.htm>
