[Ovmsdev] Sharing Data Publicly - Public Charges
Christopher Cook
christopher.cook at webprofusion.com
Thu Dec 12 14:24:21 HKT 2013
Hi Mark,
Yes, that sounds right in terms of what we (OCM) would want to present to the user (and currently do).
OCM can take care of the import into OCM if OVMS makes an API available into the more fine-grained charging status data, rather than needing to push from OVMS. We would probably add something to OCM to display this aggregated info as a single anonymous summary of stats, rather than showing individual charging events. I could well imagine systems such as plugshare/recargo would be interested in the data (more from a commercial perspective).
In OCM we attempt to classify charging success/failure in check-ins by having a table of common statuses, with mixed success:
ID Title IsPositive IsAutomatedCheckin
0 Did Not Visit Location NULL 0
10 Charged Successfully 1 0
15 Charged Successfully (Automated Checkin) 1 1
20 Failed to Charge (Equipment Not Operational) 0 0
22 Failed to Charge (Equipment Not Fully Installed) 0 0
25 Failed to Charge (Equipment Problem) 0 0
30 Failed to Charge (Equipment Not Compatible) 0 0
40 Failed to Charge (Required Other Access Card/Fob etc.) 0 0
50 Failed to Charge (No Charging Equipment Present) 0 0
100 Charging Spot In Use (Other EV Parked) 1 0
110 Charging Spot In Use (Non-EV Parked) 0 0
120 Charging Spot Not Accessible (Access locked or site closed) 0 0
130 Charging Spot Not Found (Inadequate or Incorrect Details) 0 0
140 Equipment & Location Confirmed Correct 1 0
200 Other (Negative/Bad) 0 0
210 Other (Positive/Good) 1 0
Other reference data (connectors etc) can be seen via the API: http://api.openchargemap.io/v2/referencedata/
We do support the concept of an anonymous checkin via HTTP Post of a JSON formatted message to the OCM API but I think we'd probably require an API key for those submissions going forward (we don't currently). This theoretically allows other apps/systems to post comments/checkins directly from their own UI.
Chris
________________________________
Sent: 12 December 2013 05:54
To: Christopher Cook
Cc: OVMS Developers
Subject: Re: [Ovmsdev] Sharing Data Publicly - Public Charges
Chris,
