[Ovmsdev] Open Vehicle 3.2.1 (20131211) is now available
Wed Dec 11 20:18:19 HKT 2013
Avesh,
Welcome.
> Is entire project focussed on electric cars(Roadster $ Leaf) or there are chances that your solution can be used for other cars too .
We do focus on electric cars, but there is nothing in the project really specific to them. I have recently made quite a few changes to the generic OBDII driver to introduce a generic polling mechanism, and that vehicle support should be quite reasonable when that code is released (still a work-in-progress today).
My concern with generic OBDII though is the 12V battery. OVMS does not currently implement a sleep mode, and it is not so easy in the current architecture and hardware, so power drain may be a concern for cars with small batteries.
> I wish to contribute and test with others cars using standard OBD11 and probably getting more data that simple OBD. But the query is will your app or server require changes . Since you have codes available online can we make changes to adjust server/app for various other cars.
Everything we have is in the project HEAD now. I suggest you look at my new vehicle.{h,c} and vehicle_obdii.c code to see how it works. You can see that it should be fairly easy to extend. Have a look at it, and then come back to us with any questions / suggestions you have.
On 11 Dec, 2013, at 8:09 pm, Avesh Chauhan <aveshcool at gmail.com> wrote:
> Dear Mark,
> I have just started following your blog and entire project. Is entire project focussed on electric cars(Roadster $ Leaf) or there are chances that your solution can be used for other cars too .
> Awaiting your reply and guidance.
> Avesh
> On Wed, Dec 11, 2013 at 5:21 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Robert,
> This is an update to the Android App (not in-car firmware). I’m still working on the Leaf support (but have been ill with flu for the past week). Should have a build for you guys any day now.
> On 11 Dec, 2013, at 5:55 pm, Robert Sharpe <robert.sharpe at evergreen-consulting.co.uk> wrote:
>> Hi Mark,
>> Can you confirm if this build supports the Leaf?
>> Just to confirm that both Nikki (I assume) and I are standing ready to help Leaf testing once firmware is available.
>> Look forward to helping out.
>> Also, I now have an OBD2 and Leafspy so maybe able to take traces if required.
>> Rob
>> ---- On Wed, 11 Dec 2013 10:25:02 +0100 Mark Webb-Johnson<mark at webb-johnson.net> wrote ----
>> A good day.
>> OVMS Android App v3.2.1 is now released to beta test. You can get it from testflightapp:
>> http://www.testflightapp.com/install/c514a82bf4936634cbd1f76536c74c67-ODMxNzcwMg/
>> We’re using TestFlightApp for both iOS and Android Apps, so it would be helpful if you could register there. If you do, you’ll get notified of new builds as and when they are released.
>> As with the iOS App, we’ve had sponsorship and support from Zero Carbon World for this:
>> Charging station integration and information provided by Zero Carbon World (http://www.zerocarbonworld.org/open-charge-map) and the Open Charge Map project (www.openchargemap.org).
>> Let me have feedback / problems via testflightapp or here. It is a beta #1 build, but is functionally complete. The only known issue is a 20 second delay when a new car is setup (or the first time the app is run), for charge station data to be downloaded.
>>> Open Vehicle
>>> Version 3.2.1 (20131211)
>>> (open this email on your Android 2.3+ Device and click the install button)
>>> What's New
>>> v3.2.1 OVMS for Android, with Open Charge Map integration - beta #1
>>> * 67dd173 Disable two-finger rotation gesture for map
>>> * 79b70dd Dont show undefined number of charging points as "null"
>>> * f813df7 Revise clustering factors, to improve usability choices
>>> * d1786ca Tidy up layout of setting dialog
>>> * d37d9c7 OCM integration, rough draft
>>> Details
>>> Platform: Android
>>> Version: 3.2.1 (20131211)
>>> Team: Open Vehicles
>>> Release Date: December 11, 2013
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20131211/dfff793b/attachment.html>
