[Ovmsdev] Open Vehicle 3.2.1 (20131211) is now available
Wed Dec 11 19:49:39 HKT 2013
I’ve just confirmed your join (it seems to require that). Can you try again - you should have got an eMail with the link.
On 11 Dec, 2013, at 7:47 pm, Rolf Welde Skeie <rwskeie at gmail.com> wrote:
> Hmm, after using the last two links you sent I'm now a member of the "Open Vehicles" and "Android Testers" teams, but there are no apps available.?.. (tried both compatible and noncompatible).
> More tricks up your sleeve? :)
> Regards
>  Rolf
> On 12/11/2013 12:40 PM, Mark Webb-Johnson wrote:
>> Sorry, still getting used to the new Android testflightapp. This link
>> may be better:
>>    http://tflig.ht/v8INxA
>> On 11 Dec, 2013, at 7:32 pm, Mark Webb-Johnson <mark at webb-johnson.net
>> <mailto:mark at webb-johnson.net>> wrote:
>>> For those not already in testflightapp, the following recruitment URL
>>> should let you sign-up:
>>>    http://tflig.ht/18Bho0d
>>> On 11 Dec, 2013, at 5:25 pm, Mark Webb-Johnson <mark at webb-johnson.net
>>>> A good day.
>>>> OVMS Android App v3.2.1 is now released to beta test. You can get it
>>>> from testflightapp:
>>>>    http://www.testflightapp.com/install/c514a82bf4936634cbd1f76536c74c67-ODMxNzcwMg/
>>>> We’re using TestFlightApp for both iOS and Android Apps, so it would
>>>> be helpful if you could register there. If you do, you’ll get
>>>> notified of new builds as and when they are released.
>>>> As with the iOS App, we’ve had sponsorship and support from Zero
>>>> Carbon World for this:
>>>>    Charging station integration and information provided by Zero
>>>>    Carbon World (http://www.zerocarbonworld.org/open-charge-map) and
>>>>    the Open Charge Map project (www.openchargemap.org
>>>>    <http://www.openchargemap.org/>).
>>>> Let me have feedback / problems via testflightapp or here. It is a
>>>> beta #1 build, but is functionally complete. The only known issue is
>>>> a 20 second delay when a new car is setup (or the first time the app
>>>> is run), for charge station data to be downloaded.
>>>> Regards, Mark.
>>>>> TestFlight » Beta Testing On The Fly
>>>>> 	*Open Vehicle*
>>>>> Version 3.2.1 (20131211) 	INSTALL
>>>>> <http://email.n.testflightapp.com/c/YnVpbGRfaWQ9ODMxNzcwMiZkPTViYSZpPTIwMTMxMjExMDkwMDExLjk2My42OTQxMiU0MHdvcmtlcjYuYXMudGVzdGZsaWdodGFwcC5jb20maD1kNDViMGRlN2U0ZjA5Zjk3ODhiN2FjOTQ5NWQ1ZDMxMyZsPWh0dHAlM0ElMkYlMkZ0ZXN0ZmxpZ2h0YXBwLmNvbSUyRmluc3RhbGwlMkZjNTE0YTgyYmY0OTM2NjM0Y2JkMWY3NjUzNmM3NGM2Ny1PRE14Tnpjd01nJTJGJnI9bWFyayU0MHdlYmItam9obnNvbi5uZXQ>
>>>>> (open this email on your Android 2.3+ Device and click the install
>>>>> button)
>>>>> *What's New*
>>>>> v3.2.1 OVMS for Android, with Open Charge Map integration - beta #1
>>>>> * 67dd173 Disable two-finger rotation gesture for map
>>>>> * 79b70dd Dont show undefined number of charging points as "null"
>>>>> * f813df7 Revise clustering factors, to improve usability choices
>>>>> * d1786ca Tidy up layout of setting dialog
>>>>> * d37d9c7 OCM integration, rough draft
>>>>> *Details*
>>>>> *Platform:* 	Android
>>>>> *Version:* 	3.2.1 (20131211)
>>>>> *Team:* 	Open Vehicles
>>>>> *Release Date:* 	December 11, 2013
>>>>> *Size:* 	13.4 MB
>>>> OvmsDev mailing list
> Rolf Welde Skeie
> Solåsen 27, 5223 Nesttun, Norway
> +47 92403016 / rwskeie at gmail.com
