[Ovmsdev] Open Vehicle 3.2.1 (20131211) is now available
Rolf Welde Skeie rwskeie at gmail.com
Wed Dec 11 19:47:04 HKT 2013
Hmm, after using the last two links you sent I'm now a member of the
"Open Vehicles" and "Android Testers" teams, but there are no apps
available.?.. (tried both compatible and noncompatible).
More tricks up your sleeve? :)
Regards
   Rolf
On 12/11/2013 12:40 PM, Mark Webb-Johnson wrote:
> Sorry, still getting used to the new Android testflightapp. This link
> may be better:
>     http://tflig.ht/v8INxA
> On 11 Dec, 2013, at 7:32 pm, Mark Webb-Johnson <mark at webb-johnson.net
> <mailto:mark at webb-johnson.net>> wrote:
>> For those not already in testflightapp, the following recruitment URL
>> should let you sign-up:
>>     http://tflig.ht/18Bho0d
>> On 11 Dec, 2013, at 5:25 pm, Mark Webb-Johnson <mark at webb-johnson.net
>>> A good day.
>>> OVMS Android App v3.2.1 is now released to beta test. You can get it
>>> from testflightapp:
>>>     http://www.testflightapp.com/install/c514a82bf4936634cbd1f76536c74c67-ODMxNzcwMg/
>>> We’re using TestFlightApp for both iOS and Android Apps, so it would
>>> be helpful if you could register there. If you do, you’ll get
>>> notified of new builds as and when they are released.
>>> As with the iOS App, we’ve had sponsorship and support from Zero
>>> Carbon World for this:
>>>     Charging station integration and information provided by Zero
>>>     Carbon World (http://www.zerocarbonworld.org/open-charge-map) and
>>>     the Open Charge Map project (www.openchargemap.org
>>>     <http://www.openchargemap.org/>).
>>> Let me have feedback / problems via testflightapp or here. It is a
>>> beta #1 build, but is functionally complete. The only known issue is
>>> a 20 second delay when a new car is setup (or the first time the app
>>> is run), for charge station data to be downloaded.
>>>> TestFlight » Beta Testing On The Fly
>>>> 	*Open Vehicle*
>>>> Version 3.2.1 (20131211) 	INSTALL
>>>> <http://email.n.testflightapp.com/c/YnVpbGRfaWQ9ODMxNzcwMiZkPTViYSZpPTIwMTMxMjExMDkwMDExLjk2My42OTQxMiU0MHdvcmtlcjYuYXMudGVzdGZsaWdodGFwcC5jb20maD1kNDViMGRlN2U0ZjA5Zjk3ODhiN2FjOTQ5NWQ1ZDMxMyZsPWh0dHAlM0ElMkYlMkZ0ZXN0ZmxpZ2h0YXBwLmNvbSUyRmluc3RhbGwlMkZjNTE0YTgyYmY0OTM2NjM0Y2JkMWY3NjUzNmM3NGM2Ny1PRE14Tnpjd01nJTJGJnI9bWFyayU0MHdlYmItam9obnNvbi5uZXQ>
>>>> (open this email on your Android 2.3+ Device and click the install
>>>> button)
>>>> *What's New*
>>>> v3.2.1 OVMS for Android, with Open Charge Map integration - beta #1
>>>> * 67dd173 Disable two-finger rotation gesture for map
>>>> * 79b70dd Dont show undefined number of charging points as "null"
>>>> * f813df7 Revise clustering factors, to improve usability choices
>>>> * d1786ca Tidy up layout of setting dialog
>>>> * d37d9c7 OCM integration, rough draft
>>>> *Details*
>>>> *Platform:* 	Android
>>>> *Version:* 	3.2.1 (20131211)
>>>> *Team:* 	Open Vehicles
>>>> *Release Date:* 	December 11, 2013
>>>> *Size:* 	13.4 MB
Rolf Welde Skeie
Solåsen 27, 5223 Nesttun, Norway
+47 92403016 / rwskeie at gmail.com
