[Ovmsdev] v2.5.2
Thu Aug 29 09:10:25 HKT 2013
Tom,
I sent out a subsequent eMail last night - I managed to shoe-horn ACC into v1 firmware (at the expense of DIAG mode):
The good news is that by doing some juggling around, I've managed to shoe-horn ACC into the V1_Production code for v1 hardware modules.
We've got 3,614bytes of flash and 504bytes of RAM free to play with! The sad news is that this is at the expense of DIAG mode.
Anyway, if developers really need that, they can build a custom firmware for it anyway, so not too bad. I may be able to bring it
back for v1 hardware at a later stage, if we can reduce code-size elsewhere.
That said, the v2 hardware is so much better than v1 :-)
On 29 Aug, 2013, at 5:17 AM, Tom Saxton <tom at idleloop.com> wrote:
> Well, I guess that means it's time to order a V2 OVMSŠ
> I'm looking forward to all the new features!
> 	Tom
> On 8/27/13 7:05 AM, "Mark Webb-Johnson" <mark at webb-johnson.net> wrote:
>> I've just pushed to github the code for v2.5.2. This includes a workable
>> ACC module, as well as a bunch of bug fixes. It also includes a
>> re-working of the cooldown feature in the Tesla Roadster, based on many a
>> hot evening spent in my car with a CAN USB adaptor and laptop.
>> For the Tesla Roadster, I managed to find two new id#100 messages related
>> to HVAC - 0x87 and 0x9A. This is now used by the cooldown feature to
>> track HVAC usage and try to make it work better.
>> 	HVAC
>> 		HVAC message 0x87 and 0x9A are enabled with:
>> 			102 06 D0 07 00 00 80 00 08
>> 		and disabled with:
>> 			102 06 10 27 00 10 00 00 00
>> 	HVAC#1
>> 		B1=0x87
>> 		B2=Toutside (outside temperature, celcius)
>> 		B3=Tmaxbrick (ESS temperature, celcius)
>> 		B4=Tcoolant (coolant temperature, celcius)
>> 		B5=Requested cooling %
>> 		B6=Received cooling %
>> 		B7= LSB \ Compressor RPM
>> 		B8= MSB /
>> 	HVAC#2
>> 		B1=0x9A
>>               B2=?
>>               B3=?
>>               B4=?
>>               B5=?
>>               B6=? [ seems to be refrigerent pressure (scaled with ~/4)
>> but not certain ]
>>               B7=TcabinOutlet (celcius)
>>               B8=? [ seems to be outside temperature (celcius) ]
>> The build configs are restructured, as previously announced.
>> Currently, I haven't been able to fit either LOGGING or ACC in the V1
>> module firmware - it is just too big. I'll keep working on this, as it
>> would be good to get at least ACC in that firmware.
>> One caveat: this is largely untested and probably very buggy - which is
>> why I haven't done binary builds yet. I'll test and debug over the next
>> couple of days and then release binaries when I've got something working
>> well.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130829/093b6bfc/attachment.htm>
