[Ovmsdev] Problems with Ampera setup…
Nikki Gordon-Bloomfield nikki at littlecollie.com
Sun Aug 4 15:29:23 HKT 2013
Hi Mark,
I'm going to forward this to the guy I was helping -- he's left now, so is on vacation down south. Hopefully, he can do all of the instructions that you've listed.
Cheers,
Nikki.
On 4 Aug 2013, at 04:02, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Nikki,
> Stuff I ask for (assuming SMS works):
> 1] Copy-and-paste results for:
> MODULE?
> SERVER?
> GPRS?
> DIAG
> 2] Triple-check all passwords and usernames.
> 3] Make sure App can connect (albeit getting a red flashing icon, but not gray) with the same server username and password as entered into the module and shown in the above SMS output.
> 4] Make sure there is at least US$6 on the data plan.
> 5] Make sure GeoSIM is activated and on the global profile.
> 99.9% of the time it is either [2] or [4].
> If none of that works, send in the above to support at openvehicles.com along with the vehicle ID and www.openvehicles.com user ID.
> On 4 Aug, 2013, at 3:15 AM, Nikki Gordon-Bloomfield <nikki at littlecollie.com> wrote:
>> Hi folks,
>> I'm helping an Ampera owner connect his OVMS for the first time using global sim. We confirmed that we could get data working on an iPhone 2g before putting it in OVMS module, but while we can get everything via SMS, there's no luck with IP.
>> GPRS? gives two different errors now. First time it was Not Connected (0x0024) The second time, it was 0x0023.
>> Any ideas?
>> Nikki.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130804/299aa3c1/attachment.htm>
