[Ovmsdev] v2.5.2
Thu Aug 29 05:17:02 HKT 2013
Well, I guess that means it's time to order a V2 OVMSŠ
I'm looking forward to all the new features!
	Tom
On 8/27/13 7:05 AM, "Mark Webb-Johnson" <mark at webb-johnson.net> wrote:
>I've just pushed to github the code for v2.5.2. This includes a workable
>ACC module, as well as a bunch of bug fixes. It also includes a
>re-working of the cooldown feature in the Tesla Roadster, based on many a
>hot evening spent in my car with a CAN USB adaptor and laptop.
>For the Tesla Roadster, I managed to find two new id#100 messages related
>to HVAC - 0x87 and 0x9A. This is now used by the cooldown feature to
>track HVAC usage and try to make it work better.
>	HVAC
>		HVAC message 0x87 and 0x9A are enabled with:
>			102 06 D0 07 00 00 80 00 08
>		and disabled with:
>			102 06 10 27 00 10 00 00 00
>	HVAC#1
>		B1=0x87
>		B2=Toutside (outside temperature, celcius)
>		B3=Tmaxbrick (ESS temperature, celcius)
>		B4=Tcoolant (coolant temperature, celcius)
>		B5=Requested cooling %
>		B6=Received cooling %
>		B7= LSB \ Compressor RPM
>		B8= MSB /
>	HVAC#2
>		B1=0x9A
>                B2=?
>                B3=?
>                B4=?
>                B5=?
>                B6=? [ seems to be refrigerent pressure (scaled with ~/4)
>but not certain ]
>                B7=TcabinOutlet (celcius)
>                B8=? [ seems to be outside temperature (celcius) ]
>The build configs are restructured, as previously announced.
>Currently, I haven't been able to fit either LOGGING or ACC in the V1
>module firmware - it is just too big. I'll keep working on this, as it
>would be good to get at least ACC in that firmware.
>One caveat: this is largely untested and probably very buggy - which is
>why I haven't done binary builds yet. I'll test and debug over the next
>couple of days and then release binaries when I've got something working
>well.
>Regards, Mark.
>_______________________________________________
>OvmsDev mailing list
>OvmsDev at lists.teslaclub.hk
>http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
