[Ovmsdev] Problems with Ampera setup…
Matt Beard OVMS
smvo at mxf.org.uk
Sun Aug 4 19:22:01 HKT 2013
Beware....
The OVMS I recently bought had the internal GPRS switch set to "disable"
when it arrived - took me ages to figure out why I had SMS but no GPRS.
Also, I think that the UK setting for the GeoSIM is not the same as the US
(global) - I think it is "Prime", but not 100% sure.
Matt
On 4 August 2013 08:29, Nikki Gordon-Bloomfield <nikki at littlecollie.com>wrote:
> Hi Mark,
> I'm going to forward this to the guy I was helping -- he's left now, so is
> on vacation down south. Hopefully, he can do all of the instructions that
> you've listed.
> Cheers,
> Nikki.
> On 4 Aug 2013, at 04:02, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Nikki,
> Stuff I ask for (assuming SMS works):
> 1] Copy-and-paste results for:
> MODULE?
> SERVER?
> GPRS?
> DIAG
> 2] Triple-check all passwords and usernames.
> 3] Make sure App can connect (albeit getting a red flashing icon, but not
> gray) with the same server username and password as entered into the module
> and shown in the above SMS output.
> 4] Make sure there is at least US$6 on the data plan.
> 5] Make sure GeoSIM is activated and on the global profile.
> 99.9% of the time it is either [2] or [4].
> If none of that works, send in the above to support at openvehicles.comalong with the vehicle ID and
> www.openvehicles.com user ID.
> On 4 Aug, 2013, at 3:15 AM, Nikki Gordon-Bloomfield <
> nikki at littlecollie.com> wrote:
> Hi folks,
> I'm helping an Ampera owner connect his OVMS for the first time using
> global sim. We confirmed that we could get data working on an iPhone 2g
> before putting it in OVMS module, but while we can get everything via SMS,
> there's no luck with IP.
> GPRS? gives two different errors now. First time it was Not Connected
> (0x0024) The second time, it was 0x0023.
> Any ideas?
> Nikki.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130804/04c445bc/attachment.html>
