[Ovmsdev] i-Miev/C-Zero/iOn
Mon Apr 29 16:42:39 HKT 2013
One thought: there is _one_ way to do this. The old OVMS v1 hardware PIC board is just a small piggy-back board designed to fit on top of the modem. Without the modem, it has a TTL-level serial port available. Put it through a TTL-RS232 converter circuit (many available as plug-in modules), or a TTL-USB converter (again, modules available like this one from sparkfun). Then, roll-your-own software (not hard - just rip out everything from base ovms project, set a mask to pickup all can traffic, then output as ascii to serial port).
If anyone wants to try this, just pay postage (a couple of bucks) as the boards are lying around as warranty spares.
On 29 Apr, 2013, at 3:12 PM, Mark Webb-Johnson wrote:
> Matt,
> It has everything needed to _capture_, but limited storage and no serial port (ok, it has one, but it is connected to the modem).
> There is a sneaky way of doing it (turn on modem echo, then output the logs to the modem and capture the echo-back on the DIAG port), but that is limited in speed and very kludgy.
> On 29 Apr, 2013, at 3:09 PM, Matt Beard wrote:
>> I would hope that there is a way to use OVMS hardware for CAN logging. It seems pointless to need a separate CAN logger when the OVMS hardware has everything needed to log the bus.
>> Matt
>> On Monday, April 29, 2013, Nikki Gordon-Bloomfield wrote:
>> HI Matt, Thomas,
>> I'd suggest at least one of you will need some form of CAN logger. Either a purpose-built device, or something that you can connect to a serial or USB port to pull date from your car?
>> See the roadster logs in GitHub ;)
>> I'd also recommend your read the development doc here: https://github.com/markwj/Open-Vehicle-Monitoring-System/blob/master/docs/OVMS_Development.pdf :)
>> Nikki.
>> On 29 Apr 2013, at 07:22, Matt Beard <matt at beard.tv> wrote:
>>> Hi, I have a C-Zero and would like OVMS support. I am currently considering buying a unit and would be able to help with development if/when I get one.
>>> Matt Beard
>>> On Monday, April 29, 2013, Thomas Bergo wrote:
>>> Hi
>>> As a owner of a i-Miev I'm interested in OVMS support for the i-Miev/C-Zero/iOn EV.
>>> Has anyone looked into supporting those EV?
>>> I'm planing to start looking into adding support for those EV. And asking for help to add a vehicle plug-in module stub for those cars, so that naming and so on is correct.
>>> Best regards
>>> Thomas B
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130429/8a7d0b73/attachment.htm>
