[Ovmsdev] i-Miev/C-Zero/iOn
Mon Apr 29 14:20:54 HKT 2013
Thomas,
Earlier this year, Matt Beard mentioned he was interested in doing i-Miev support, but I'm not sure of his status. He is on this list, so should see this. There are also several OVMS users who have that car in their stable, so the requirement is definitely there.
It is probably worth firstly doing a quick feasibility check, to see what level of OVMS support is possible:
Firstly, What are the specs for the CAN bus? What baud rate is it, and what is the connector? There are  just three messages that are key to feasibility:
SOC - battery state of charge - car_SOC
Car On/Off (ignition switch, or Park/Drive gear lever) - car_doors1 [bit7]
Car Charging (true or false) - car_doors1 [bit 4]
If those three are available, and readable by the OVMS hardware, then the project is most likely feasible. There are lots of other parameters (range, temperature, odometer, speed, vin, tpms, etc) that are nice to have, but are either optional (nice-to-have) or can generally be derived from these three key messages - so long as they can be found. For example, on the Volt/Ampera we don't know the detailed charge messages, but do know whether the car is charging or not - we can assume charge interrupted if the charge finishes before 95% complete. Similarly, if the range of the car is XXkm, we can estimate the current range based on XX * SOC%. If the car has no GPS details on the CAN bus, then we can use the GPS in the OVMS module itself.
What vehicle two-character abbreviation do you think is suitable: IM or MI? Examples are RT (Renault Twizy), VA (Volt/Ampera), TR (Tesla Roadster).
If you can let me have the can bus specs and information on the above 3 messages, I will create you a stub vehicle implementation.
P.S. With reference to the development guide (https://raw.github.com/markwj/Open-Vehicle-Monitoring-System/master/docs/OVMS_Development.pdf), these are the current set of parameters that OVMS supports.
Vehicle Module Development Checklists
You can use these checklists to know what vehicle parameters the OVMS system supports, and how you can map a specific vehicle to these.
Parameter
Purpose
Vehicle Support Notes
Vehicle Identification
car_type
Vehicle type identified
car_vin
Vehicle VIN
Parameter
Purpose
GPS Status
Vehicle GPS
Does the vehicle have a built-in GPS? If so, complete the following.
car_gpslock
Set to record GPS lock
car_stale_gps
Denotes GPS data staleness
car_latitude
Latitude of the vehicle
car_longitude
Longitude of the vehicle
car_direction
Direction of the vehicle
car_altitude
Altitude of the vehicle
Parameter
Purpose
Tire Pressure Monitoring System
TPMS
Does the vehicle have a TPMS? If so, complete the following.
car_stale_tpms
Denotes TPMS data staleness
car_tpms_t
The temperatures of each wheel
car_tpms_p
The pressures of each wheel
Parameter
Purpose
Driving Status
car_doors1 [bit7]
Set if the car ignition is ON
car_speed
The speed of the vehicle
car_trip
The vehicle trip counter
car_odometer
The vehicle odometer
Parameter
Purpose
Vehicle Environment
car_stale_ambient
Ambient temperature staleness
car_ambient_temp
Ambient temperature
car_stale_temps
Other Temperature staleness
car_tpem
Temperature of the PEM
car_tmotor
Temperature of the MOTOR
car_tbattery
Temperature of the BATTERY
car_doors1 [bit 0]
Set if front left door OPEN
car_doors1 [bit 1]
Set if front right door OPEN
car_doors2 [bit 6]
Set if bonnet is OPEN
car_doors2 [bit 7]
Set if trunk is OPEN
car_doors1 [bit 2]
Set if charge port is OPEN
car_doors1 [bit 6]
Set if handbrake is ON
car_doors2 [bit 5]
Set if headlights ON
car_doors3 [bit 1]
Set if vehicle is AWAKE (or if not supported just follow ignition)
car_doors2 [bit 4]
Set if valet mode is ENABLED
car_doors2 [bit 3]
Set if vehicle is LOCKED
car_lockstate
4=locked, 5=unlocked (deprecated)
car_doors4 [bit 2]
Set if alarm SOUNDING
car_time
Time (in seconds)
car_parktime
Time (seconds) vehicle parked
Parameter
Purpose
Battery Status
car_SOC
State of charge percentage
car_idealrange
Ideal range
car_estrange
Estimated range
Parameter
Purpose
Charging Status
car_doors1 [bit 3]
Set if pilot signal ON
car_doors1 [bit 4]
Set if vehicle CHARGING
car_linevoltage
Line voltage while charging
car_chargecurrent
Line current while charging
car_chargemode
Vehicle Mode
car_chargestate
Charging state
car_chargesubstate
Charging sub-state
car_chargelimit
Charge current limit
car_chargeduration
Charge duration (minutes)
car_chargekwh
Charge kWh put into battery
car_stale_timer
Charge timer staleness
car_timermode
Charge timer mode
car_timerstart
Charge timer schedule
On 29 Apr, 2013, at 1:56 PM, Thomas Bergo wrote:
> Hi
> As a owner of a i-Miev I'm interested in OVMS support for the i-Miev/C-Zero/iOn EV.
> Has anyone looked into supporting those EV?
> I'm planing to start looking into adding support for those EV. And asking for help to add a vehicle plug-in module stub for those cars, so that naming and so on is correct.
> Best regards
> Thomas B
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130429/d3f044f7/attachment.htm>
