[Ovmsdev] Release Firmware
Mon Apr 15 20:46:52 HKT 2013
Kevin,
> WARNING – I had a VDS "communications fault" followed by "service request" on the VDS this morning (11am).
That is not good. You had a short on one of the CAN bus wires. Most likely a loose connection on the OVMS cable. I suggest you check the cable and make sure no stray wires.
> Now the OVMS hardware is cycling as follows;
> (1) Green & Red leds lit for ~ 10 seconds
> (2) Green led flashes 6 times (repeated 3 times)
> (3) Green led flashed 4 times (repeated 7 times)
State 4 (which is the best you got to) is NET_LED_NETAPNOK - half way through initialising GPRS. It couldn't complete the GPRS initialisation successfully, so reset and tried again.
This could be a problem with the GSM antenna - I suggest you double-check it is correctly attached and try to push the black antenna cable further into the gold plug (in case it has been pulled out).
On 15 Apr, 2013, at 6:16 PM, Kevin Sharpe ZCW <kevin.sharpe at zerocarbonworld.org> wrote:
> I was cycling through the VDS trying to wake up the ODO and trip as suggested below.
> Repeat 1 to 3…
> I'll try a short drive to see if the OVMS recovers.
> 		Kevin Sharpe | Founder & Patron
> Tel: +44 122 566 7544 ext: 800 | Skype: zerocarbonworld
> kevin.sharpe at zerocarbonworld.org | www.zerocarbonworld.org | twitter.com/zerocarbonworld
> Zero Carbon World is a UK Registered Charity #1141347
> Date: Monday, 15 April 2013 07:03
> Subject: Re: [Ovmsdev] Release Firmware
> Kevin,
> This is strange, and worrying...
> I checked the logs for your car - it seems that your car has never reported odometer or trip != 0. Even with older firmware v2.2.2 it was always reporting 0 for both odometer and trip. I looked further back, and find the last record with a non-zero odometer reading seems to be  back in January (that was firmware v1.3.5, but the odometer reported was 0 even with that firmware a day later).
> Seems to be that you and I are the only Tesla Roadsters on tmc server that are running v2.3.1 yet (not surprising, as only pre-released yesterday), but a bunch are running v2.2.6 (the previous release) and all those show odometer correctly. I don't think this is anything to do with new firmware - instead it seems to be specific to your car.
> What is the actual odometer and trip reading in your car at the moment? Anything unusual about it (e.g. old vehicle firmware, etc)?
> Can you try cycling through the VDS screens next time you go for a drive? Just keep pressing the right-arrow button on the VDS until you cycle back to the main battery screen.
> On 15 Apr, 2013, at 1:34 PM, Kevin Sharpe ZCW wrote:
>> Hi Mark,
>> Thanks for the CAC explanation.
>> I can confirm I do not see ODO change from 0.0 (see attached screen shot). Indeed, I have never seen ODO change and had assumed it was only working on the very latest firmware.
>> I tried resetting the module using the app command and power cycling the hardware.
>> All the best
>> Kevin
>> On 15 Apr 2013, at 01:50, "Mark Webb-Johnson" <mark at webb-johnson.net> wrote:
>>> Kevin,
>>> Thanks for the help testing.
>>> CAC is retrieved (a) car is turned on, (b) car is turned off, (c) charge is started - so your experience is expected.
>>> The odometer 0 miles is worrying. Is that still the case, or working now?
>>> On 15 Apr, 2013, at 3:50 AM, Kevin Sharpe ZCW wrote:
>>>> Ignore my comment regarding CAC which I see now the car is on charge :-)
>>>> From: Kevin Sharpe <kevin.sharpe at zerocarbonworld.org>
>>>> Date: Sunday, 14 April 2013 18:32
>>>> To: "ovmsdev at lists.teslaclub.hk" <ovmsdev at lists.teslaclub.hk>
>>>> Subject: [Ovmsdev] FW: Release Firmware
>>>> Email sent again without the car photo (which exceeded the 1Mbyte file attachment limit)…
>>>> Date: Sunday, 14 April 2013 18:28
>>>> Just to add a little more to Nikki's report…
>>>> I've seen some odd behaviour with SOC… if you see the attached photo's you'll see STAT report SOC as 46% and then 50% even though the commands were sent within a minute of one another (approximately). You'll also see the app and car displayed 52% and 92m at the same time.
>>>> I also note that the ODO reports 0.0 mil and I see no CAC in response to a STAT command. Is this expected behaviour with this firmware?
>>>> Firmware version reported in the app is 2.3.1/TR/V2
>>>> All the best,
>>>> From: Nikki Gordon-Bloomfield <nikki at littlecollie.com>
>>>> Date: Sunday, 14 April 2013 17:24
>>>> Just a head up:
>>>> I flashed my Twizy firmware and it immediately started working.
>>>> I flashed Kevin's firmware on his Roadster, and it took about 10 minutes to start working.
>>>> Not sure why -- but thought you'd all appreciate the report. :)
>>>> I've got a 35 mile round-trip tonight to Bath, and about 120 miles of work-related travel this week in the Twizy, so plenty of time to test it!
>>>> http://about.me/aminorjourney/bio
>>>> email: nikki at littleCollie.com
>>>> tel: +44 7901 553308
>>>> On 14 Apr 2013, at 17:04, Michael Balzer <dexter at expeedo.de> wrote:
>>>>> I've had GPS streaming enabled during the last days, and neither GPS nor GSM connectivity are good at the moment. May be related, as streaming means more data communication. But still that should not lead to RAM corruption.
>>>>> Am 14.04.2013 17:54, schrieb Michael Balzer:
>>>>>> Mark,
>>>>>> I've got the last but one version in my car, just lacking the new VEHICLE commands.
>>>>>> I've got two open issues, the minor one being to raise the 12V auto acquisition time even more, as the faults have become better but it's not yet perfect. I'm trying 20 TAD now, as we don't need to be fast on that A/D conversion.
>>>>>> But a major issue might have turned up: I've just had the second RAM corruption within three days. Effect:
>>>>>> MP-0 c32,0,106,119,*-OVM-DebugCrash,2013-04-14 14:06:40,0,2.2.7/RT2.6.4/V2,0,0000,20
>>>>>> MP-0 c32,0,107,119,*-OVM-DebugCrash,2013-04-14 14:25:13,0,2.2.7/RT2.6.4/V2,80,0020,61
>>>>>> As there is no checkpoint 61, this means at least the debug variables have been overwritten, was the same with the first occurence (but other values).
>>>>>> As the module behaves weird afterwards I suppose more variables have been corrupted.
>>>>>> I've looked through the last changes several times, I'm pretty sure none could have introduced this kind of bug... if I'm the only one experiencing this, maybe I've got some hardware issue as well?
>>>>>> I'll continue checking the source for possible buffer overruns...
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 14.04.2013 16:29, schrieb Mark Webb-Johnson:
>>>>>>> I've just built from latest sources, v2.3.1. This is a release candidate, and I have 24 hours to test before i need to send it to China.
>>>>>>> It is in my car now, and seems ok. I'll do more testing tomorrow.
>>>>>>> I'd be grateful if others could grab it and put it in their cars to ensure there are no major problems.
>>>>>>> Regards, Mark.
>>>>>>> On 13 Apr, 2013, at 10:04 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>>>>>> All seems ok.
>>>>>>>> I've committed and pushed my changes (just the stp_ltf_h() function, and change to report cac as 999.99 to server).
>>>>>>>> I've just flashed and it will go in my car tomorrow.
>>>>>>>> Regards, Mark
>>>>>>>> On 13 Apr, 2013, at 2:51 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>>>>> Mark,
>>>>>>>>> I just checked in my latest changes.
>>>>>>>>> In net.c I added the pending send check also to the new net_notify_errorcode send, I think that should be correct, but please have a look.
>>>>>>>>> I saw the new stp_f() function, but I don't understand it's purpose yet. What's the difference to my stp_l2f() function?
>>>>>>>>> Btw: l2f = "long to float" -- I think "_f" should be reserved for an stp call with a real float type parameter, if we once really need one.
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>>> Am 12.04.2013 20:16, schrieb Michael Balzer:
>>>>>>>>>> Nikki,
>>>>>>>>>> yes, see attachment.
>>>>>>>>>> I could not make out any possible source of that strange error I had yesterday (completely garbled data).
>>>>>>>>>> I made a clean build with a freshly started MPLAB and got no errors up to now.
>>>>>>>>>> May have been something completely different, not related to my last changes.
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 12.04.2013 17:01, schrieb Nikki Gordon-Bloomfield:
>>>>>>>>>>> Michael,
>>>>>>>>>>> Any new firmware for me to test this weekend?
>>>>>>>>>>> Nikki.
>>>>>>>>>>> On 11 Apr 2013, at 18:33, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>>>>>>>> I think I was a bit too fast on this, Nikki, don't use that version, it seems to have some new bug causing frequent crashes... :-(
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Michael
>>>>>>>>>>>> Am 11.04.2013 19:22, schrieb Michael Balzer:
>>>>>>>>>>>>> Mark, Nikki,
>>>>>>>>>>>>> I'm currently trying to fix a last bug with the power statistics (the distance counter still went wrong), and I'm trying to get the 12V A/D conversion to work without these strange "peaks" by raising the automatic acquisition time. I will finish testing this ASAP or tell you in time before sunday.
>>>>>>>>>>>>> Nikki, I attached the latest version in case you'd like to test as well.
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Michael
>>>>>>>>>>>>> Am 11.04.2013 16:41, schrieb Mark Webb-Johnson:
>>>>>>>>>>>>>> China is bugging me for final firmware for the next batch of hardware. I need to get them this early next week.
>>>>>>>>>>>>>> I've committed what I need for the Tesla Roadster (and framework). Last outstanding small change to make is to send CAC as 999.99, rather than the current 99999, using Tom's new library function.
>>>>>>>>>>>>>> Michael B & J: can you check Twizzy and Volt/Ampera, to see if everything is ok with current firmware or there is anything you need changed?
>>>>>>>>>>>>>> I plan to cut release candidate for 2.3.1 on Sunday.
>>>>>>>>>>>>>> Regards, Mark.
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>>>>> OvmsDev at lists.teslaclub.hk
>>>>>>>>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>>>>>>>>>>>> OvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>>>>>>>>>>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>>>>>>>>>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>>>>>>>>>> <dexter.vcf>_______________________________________________
>>>>>>>>> <dexter.vcf>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130415/2023a9f6/attachment.htm>
