[Ovmsdev] Release Firmware
Nikki Gordon-Bloomfield nikki at littlecollie.com
Sun Apr 14 23:07:41 HKT 2013
Does this incorporate the twizy fork?
Sent from my iPhone
On 14 Apr 2013, at 15:29, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> I've just built from latest sources, v2.3.1. This is a release candidate, and I have 24 hours to test before i need to send it to China.
> It is in my car now, and seems ok. I'll do more testing tomorrow.
> I'd be grateful if others could grab it and put it in their cars to ensure there are no major problems.
> On 13 Apr, 2013, at 10:04 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>> All seems ok.
>> I've committed and pushed my changes (just the stp_ltf_h() function, and change to report cac as 999.99 to server).
>> I've just flashed and it will go in my car tomorrow.
>> Regards, Mark
>> On 13 Apr, 2013, at 2:51 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Mark,
>>> I just checked in my latest changes.
>>> In net.c I added the pending send check also to the new net_notify_errorcode send, I think that should be correct, but please have a look.
>>> I saw the new stp_f() function, but I don't understand it's purpose yet. What's the difference to my stp_l2f() function?
>>> Btw: l2f = "long to float" -- I think "_f" should be reserved for an stp call with a real float type parameter, if we once really need one.
>>> Am 12.04.2013 20:16, schrieb Michael Balzer:
>>>> Nikki,
>>>> yes, see attachment.
>>>> I could not make out any possible source of that strange error I had yesterday (completely garbled data).
>>>> I made a clean build with a freshly started MPLAB and got no errors up to now.
>>>> May have been something completely different, not related to my last changes.
>>>> Regards,
>>>> Michael
>>>> Am 12.04.2013 17:01, schrieb Nikki Gordon-Bloomfield:
>>>>> Michael,
>>>>> Any new firmware for me to test this weekend?
>>>>> Nikki.
>>>>> On 11 Apr 2013, at 18:33, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>> I think I was a bit too fast on this, Nikki, don't use that version, it seems to have some new bug causing frequent crashes... :-(
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 11.04.2013 19:22, schrieb Michael Balzer:
>>>>>>> Mark, Nikki,
>>>>>>> I'm currently trying to fix a last bug with the power statistics (the distance counter still went wrong), and I'm trying to get the 12V A/D conversion to work without these strange "peaks" by raising the automatic acquisition time. I will finish testing this ASAP or                   tell you in time before sunday.
>>>>>>> Nikki, I attached the latest version in case you'd like to test as well.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 11.04.2013 16:41, schrieb Mark Webb-Johnson:
>>>>>>>> China is bugging me for final                     firmware for the next batch of hardware. I need to get them this early next week.
>>>>>>>> I've committed what I need for the Tesla Roadster (and framework). Last outstanding small change to make is to send CAC as 999.99, rather than the current 99999, using Tom's new library function.
>>>>>>>> Michael B & J: can you check Twizzy and Volt/Ampera, to see if everything is ok with current                     firmware or there is anything you need changed?
>>>>>>>> I plan to cut release candidate for 2.3.1 on Sunday.
>>>>>>>> Regards, Mark.
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.teslaclub.hk
>>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>>>>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>>>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>>>> <dexter.vcf>_______________________________________________
>>> <dexter.vcf>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130414/e79574fe/attachment.htm>
