[Ovmsdev] Release Firmware
Sat Apr 13 22:04:17 HKT 2013
All seems ok.
I've committed and pushed my changes (just the stp_ltf_h() function, and change to report cac as 999.99 to server).
I've just flashed and it will go in my car tomorrow.
On 13 Apr, 2013, at 2:51 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> I just checked in my latest changes.
> In net.c I added the pending send check also to the new net_notify_errorcode send, I think that should be correct, but please have a look.
> I saw the new stp_f() function, but I don't understand it's purpose yet. What's the difference to my stp_l2f() function?
> Btw: l2f = "long to float" -- I think "_f" should be reserved for an stp call with a real float type parameter, if we once really need one.
> Am 12.04.2013 20:16, schrieb Michael Balzer:
>> Nikki,
>> yes, see attachment.
>> I could not make out any possible source of that strange error I had yesterday (completely garbled data).
>> I made a clean build with a freshly started MPLAB and got no errors up to now.
>> May have been something completely different, not related to my last changes.
>> Am 12.04.2013 17:01, schrieb Nikki Gordon-Bloomfield:
>>> Michael,
>>> Any new firmware for me to test this weekend?
>>> Nikki.
>>> On 11 Apr 2013, at 18:33, Michael Balzer <dexter at expeedo.de> wrote:
>>>> I think I was a bit too fast on this, Nikki, don't use that version, it seems to have some new bug causing frequent crashes... :-(
>>>> Regards,
>>>> Michael
>>>> Am 11.04.2013 19:22, schrieb Michael Balzer:
>>>>> Mark, Nikki,
>>>>> I'm currently trying to fix a last bug with the power statistics (the distance counter still went wrong), and I'm trying to get the 12V A/D conversion to work without these strange "peaks" by raising the automatic acquisition time. I will finish testing this ASAP or tell you in time before sunday.
>>>>> Nikki, I attached the latest version in case you'd like to test as well.
>>>>> Regards,
>>>>> Michael
>>>>> Am 11.04.2013 16:41, schrieb Mark Webb-Johnson:
>>>>>> China is bugging me for final firmware for the next batch of hardware. I need to get them this early next week.
>>>>>> I've committed what I need for the Tesla Roadster (and framework). Last outstanding small change to make is to send CAC as 999.99, rather than the current 99999, using Tom's new library function.
>>>>>> Michael B & J: can you check Twizzy and Volt/Ampera, to see if everything is ok with current firmware or there is anything you need changed?
>>>>>> I plan to cut release candidate for 2.3.1 on Sunday.
>>>>>> Regards, Mark.
>>>>>> OvmsDev mailing list
>>>> <dexter.vcf>_______________________________________________
> <dexter.vcf>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130413/3c7f84fb/attachment.htm>
