[Ovmsdev] More sophisticated hardware
Wed Apr 10 02:30:35 HKT 2013
Am 09.04.2013 12:14, schrieb Nikki Gordon-Bloomfield:
> Using the Bluetooth serial connection, it should be possible for users
> to implement a GUI with existing smart phone technology.
Oh I forgot: yes! That's the idea behind adding Bluetooth to the
Twizplay, they could omit the LCD and use an App as the display device.
That's really a good option I think! Would also keep cost down.
> For Twizy owners that's an added bonus. There are no door locks, and
> getting in is as simple as reaching inside and pulling the door handle.
...that's why most Twizplay owners currently use a special quick lock
mount just for the Twizplay -- so you need both a mount for the display
and one for your mobile phone... bad.
> Moving forward, I think it'd be great if someone in the self-build
> community (You may have to work with someone else) could produce a raw
> "battery pack to OVMS" module, which enables those with converted or
> custom EVs to use the OVMS system using a standard set of protocols
> and Can messaging -- or perhaps direct using an add-on IO device?
That would make the OVMS an option for Ebike and Escooter drivers as
well. I've got one of these:
http://www.emco-elektroroller.de/elektroroller/novum.html
...just a simple chinese scooter, it doesn't have any data port, and
it's only display is an analog voltage meter for the overall battery
voltage -- you have to guess the SOC based on how deep the voltage drops
under load.
The most simple solution would be to provide two analog I/O ports to
feed pack voltage and current (measured as voltage difference on a
shunt) into the OVMS. The A/D conversion should be fast enough to
provide at least 10 ms resolution, so we can implement an Ah counter in
software. Also some digital I/O ports should be available to measure the
distance driven (by a reed sensor mounted to a tyre) and maybe record
some other system status.
So, basically the same as available solutions like the "Cycle Analyst"
or the "WattsUp" do, but with the added OVMS coolness.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130409/4a8dc91d/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130409/4a8dc91d/attachment-0002.vcf>
