[Ovmsdev] Relay through diag port.
Tue Apr 2 21:05:07 HKT 2013
Tricky. It is just a tap into the modem comms.
But, there is an expansion connector on the board itself.
The part labelled "HEADER 9X2" is a standard layout for expansion plugs, or holes are there to directly solder to the board. The I/O is 5v digital on those pins, and there are quite a few spare I/O pins that you can use.
There is also GND, +12V and +5V if you need power.
If you have a use for this, it would be quite simple to control some of these pins on/off on command (similar to the way home link works).
Type: application/pdf
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130402/bb8dd94c/attachment-0004.pdf>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130402/bb8dd94c/attachment-0005.pdf>
On 2 Apr, 2013, at 8:56 PM, Nikki Gordon-Bloomfield <nikki at littlecollie.com> wrote:
> Guys,
> Is there any scope for enabling IO from the diagnostic port to operate an relay, either directly or through some opto-isolators?
> Nikki.
