[Ovmsdev] i-Miev/C-Zero/iOn
Matt Beard
matt at beard.tv
Mon Apr 29 15:09:59 HKT 2013
I would hope that there is a way to use OVMS hardware for CAN logging. It
seems pointless to need a separate CAN logger when the OVMS hardware has
everything needed to log the bus.
Matt
On Monday, April 29, 2013, Nikki Gordon-Bloomfield wrote:
> HI Matt, Thomas,
> I'd suggest at least one of you will need some form of CAN logger. Either
> a purpose-built device, or something that you can connect to a serial or
> USB port to pull date from your car?
> See the roadster logs in GitHub ;)
> I'd also recommend your read the development doc here:
> https://github.com/markwj/Open-Vehicle-Monitoring-System/blob/master/docs/OVMS_Development.pdf:)
> Nikki.
> On 29 Apr 2013, at 07:22, Matt Beard <matt at beard.tv <javascript:_e({},
> 'cvml', 'matt at beard.tv');>> wrote:
> Hi, I have a C-Zero and would like OVMS support. I am currently
> considering buying a unit and would be able to help with development
> if/when I get one.
> Matt Beard
> On Monday, April 29, 2013, Thomas Bergo wrote:
>> Hi
>> As a owner of a i-Miev I'm interested in OVMS support for the
>> i-Miev/C-Zero/iOn EV.
>> Has anyone looked into supporting those EV?
>> I'm planing to start looking into adding support for those EV. And asking
>> for help to add a vehicle plug-in module stub for those cars, so
>> that naming and so on is correct.
>> Best regards
>> Thomas B
> OvmsDev at lists.teslaclub.hk <javascript:_e({}, 'cvml',
> 'OvmsDev at lists.teslaclub.hk');>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130429/9d4cd875/attachment.html>
