[Ovmsdev] i-Miev/C-Zero/iOn
Nikki Gordon-Bloomfield
nikki at littlecollie.com
Mon Apr 29 14:25:19 HKT 2013
In addition, there's this forum -- http://myimiev.com/forum/viewtopic.php?p=4409 -- which details some of the CAN bus stuff.
And some pre-existing work: http://myimiev.com/forum/viewtopic.php?p=4817
Nikki.
On 29 Apr 2013, at 07:20, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Thomas,
> Earlier this year, Matt Beard mentioned he was interested in doing i-Miev support, but I'm not sure of his status. He is on this list, so should see this. There are also several OVMS users who have that car in their stable, so the requirement is definitely there.
> It is probably worth firstly doing a quick feasibility check, to see what level of OVMS support is possible:
> Firstly, What are the specs for the CAN bus? What baud rate is it, and what is the connector? There are just three messages that are key to feasibility:
> SOC - battery state of charge - car_SOC
> Car On/Off (ignition switch, or Park/Drive gear lever) - car_doors1 [bit7]
> Car Charging (true or false) - car_doors1 [bit 4]
> If those three are available, and readable by the OVMS hardware, then the project is most likely feasible. There are lots of other parameters (range, temperature, odometer, speed, vin, tpms, etc) that are nice to have, but are either optional (nice-to-have) or can generally be derived from these three key messages - so long as they can be found. For example, on the Volt/Ampera we don't know the detailed charge messages, but do know whether the car is charging or not - we can assume charge interrupted if the charge finishes before 95% complete. Similarly, if the range of the car is XXkm, we can estimate the current range based on XX * SOC%. If the car has no GPS details on the CAN bus, then we can use the GPS in the OVMS module itself.
> What vehicle two-character abbreviation do you think is suitable: IM or MI? Examples are RT (Renault Twizy), VA (Volt/Ampera), TR (Tesla Roadster).
> If you can let me have the can bus specs and information on the above 3 messages, I will create you a stub vehicle implementation.
> P.S. With reference to the development guide (https://raw.github.com/markwj/Open-Vehicle-Monitoring-System/master/docs/OVMS_Development.pdf), these are the current set of parameters that OVMS supports.
> Vehicle Module Development Checklists
> You can use these checklists to know what vehicle parameters the OVMS system supports, and how you can map a specific vehicle to these.
> Parameter
> Purpose
> Vehicle Support Notes
> Vehicle Identification
> car_type
> Vehicle type identified
> car_vin
> Vehicle VIN
> Parameter
> Purpose
> GPS Status
> Vehicle GPS
> Does the vehicle have a built-in GPS? If so, complete the following.
> car_gpslock
> Set to record GPS lock
> car_stale_gps
> Denotes GPS data staleness
> car_latitude
> Latitude of the vehicle
> car_longitude
> Longitude of the vehicle
> car_direction
> Direction of the vehicle
> car_altitude
> Altitude of the vehicle
> Parameter
> Purpose
> Tire Pressure Monitoring System
> TPMS
> Does the vehicle have a TPMS? If so, complete the following.
> car_stale_tpms
> Denotes TPMS data staleness
> car_tpms_t
> The temperatures of each wheel
> car_tpms_p
> The pressures of each wheel
> Parameter
> Purpose
> Driving Status
> car_doors1 [bit7]
> Set if the car ignition is ON
> car_speed
> The speed of the vehicle
> car_trip
> The vehicle trip counter
> car_odometer
> The vehicle odometer
> Parameter
> Purpose
> Vehicle Environment
> car_stale_ambient
> Ambient temperature staleness
> car_ambient_temp
> Ambient temperature
> car_stale_temps
> Other Temperature staleness
> car_tpem
> Temperature of the PEM
> car_tmotor
> Temperature of the MOTOR
> car_tbattery
> Temperature of the BATTERY
> car_doors1 [bit 0]
> Set if front left door OPEN
> car_doors1 [bit 1]
> Set if front right door OPEN
> car_doors2 [bit 6]
> Set if bonnet is OPEN
> car_doors2 [bit 7]
> Set if trunk is OPEN
> car_doors1 [bit 2]
> Set if charge port is OPEN
> car_doors1 [bit 6]
> Set if handbrake is ON
> car_doors2 [bit 5]
> Set if headlights ON
> car_doors3 [bit 1]
> Set if vehicle is AWAKE (or if not supported just follow ignition)
> car_doors2 [bit 4]
> Set if valet mode is ENABLED
> car_doors2 [bit 3]
> Set if vehicle is LOCKED
> car_lockstate
> 4=locked, 5=unlocked (deprecated)
> car_doors4 [bit 2]
> Set if alarm SOUNDING
> car_time
> Time (in seconds)
> car_parktime
> Time (seconds) vehicle parked
> Parameter
> Purpose
> Battery Status
> car_SOC
> State of charge percentage
> car_idealrange
> Ideal range
> car_estrange
> Estimated range
> Parameter
> Purpose
> Charging Status
> car_doors1 [bit 3]
> Set if pilot signal ON
> car_doors1 [bit 4]
> Set if vehicle CHARGING
> car_linevoltage
> Line voltage while charging
> car_chargecurrent
> Line current while charging
> car_chargemode
> Vehicle Mode
> car_chargestate
> Charging state
> car_chargesubstate
> Charging sub-state
> car_chargelimit
> Charge current limit
> car_chargeduration
> Charge duration (minutes)
> car_chargekwh
> Charge kWh put into battery
> car_stale_timer
> Charge timer staleness
> car_timermode
> Charge timer mode
> car_timerstart
> Charge timer schedule
> On 29 Apr, 2013, at 1:56 PM, Thomas Bergo wrote:
>> Hi
>> As a owner of a i-Miev I'm interested in OVMS support for the i-Miev/C-Zero/iOn EV.
>> Has anyone looked into supporting those EV?
>> I'm planing to start looking into adding support for those EV. And asking for help to add a vehicle plug-in module stub for those cars, so that naming and so on is correct.
>> Best regards
>> Thomas B
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130429/55b79438/attachment-0001.html>
