[Ovmsdev] Seeking ideas for 'range' representation
Matt Beard
matt at beard.tv
Tue Apr 16 22:23:46 HKT 2013
Looking good.
Is there any way to indicate what type of chargers are in a collected blob?
Perhaps with the outer ring colour? If I see that I have 4 possible 7kW
chargers in range, and a rapid charger that I may just reach... it would
help to know that the group of 4 chargers in one blob on a slightly
different route also includes a rapid charger.
Matt
On 16 April 2013 14:32, Kevin Sharpe ZCW
<kevin.sharpe at zerocarbonworld.org>wrote:
> Just a brief update to show progress is being made with the OCM
> integration :-)
> Kevin Sharpe | Founder & Patron
> Tel: +44 122 566 7544 ext: 800 | Skype: zerocarbonworld
> kevin.sharpe at zerocarbonworld.org <kevin.sharpe at zerocarbonworld.org>|
> www.zerocarbonworld.org | twitter.com/zerocarbonworld<http://twitter.com/ZCWcharlie>
> Zero Carbon World is a UK Registered Charity #1141347
> Date: Wednesday, 6 March 2013 08:41
> Subject: Re: [Ovmsdev] Seeking ideas for 'range' representation
> Nikolay,
> Seems a very similar approach:
> But, we would only show chargepoints in range.
> Regarding using OCM, quite frankly they are sponsoring this work and I'm
> happy to accept. Their database is pretty extensive and global and their
> 'open' philosophy suits as well. The entire OVMS project (apps, server, car
> module software and hardware) is open source, and on github - so it is free
> for anyone to do with as they want.
> Regarding the use of intents and reversing this so that the other apps
> do the displays, while I agree that technically that is an elegant
> solution, it is really beyond the scope of what we can control. We can pull
> free and open databases of information into OVMS, but we can't make other
> systems to pull data from or otherwise integrate with our intents. We could
> try persuasion, but I don't have high hopes to get 20+ vendors to accept
> our approach. Technically, on iOS, this is also a nightmare - applications
> are sandboxed and inter-app communication is almost impossible (and
> promptly shut down by Apple whenever possible). The only thing iOS has is
> the URL scheme.
> In fact, essentially the same situation as OpenChargeMap in general.
> They can have a completely open database that anyone can contribute to and
> download. But, they can't force people to use it.
> I would love a generic framework, but that is really beyond the
> resources we have at the moment. Even then it would be a nightmare to
> remove duplicates if more than one source was plugged in.
> {soapbox}The whole situation with proprietary charge location databases
> is a nightmare, and very detrimental to the EV movement. If the charging
> stations can be used by anyone, why can't their location? I really hope
> that databases like OpenChargeMap can go some way to forcing the openness
> of this.{/soapbox}
> On 6 Mar, 2013, at 2:59 PM, Nikolay Shishkov wrote:
> Some examples:
> Here is an example of a range calculation and visualization I made:
> https://play.google.com/store/apps/details?id=com.nikpix.LeafRangeCalc
> And here is the integration of openchargemap I wrote in my previous e-mail:
> https://play.google.com/store/apps/details?id=com.applications.lawsystems.leafcontrol
> Here is a screenshot of the range visualization:
> https://lh4.ggpht.com/D4dD0xdgJI8CEMAwhPa0sPp9zzsNf_j4SQksFTfZlowVdj9YfU6EFhqSzpxLf-NauQCm
> Nikolay
> ________________________________
> From: Nikolay Shishkov <nshishkov at yahoo.com>
> Sent: Wednesday, March 6, 2013 7:53 AM
> Mark,
> Display of range can be done in a similar way openchargemap was integrated
> in one of the nissan leaf apps out there - some of their guys can probably
> show you. I think it was concentric circles.
> Integration of a particular database of charging stations is a mistake -
> there are at least 20 such out there. On android this could be done much
> more elegantly by intents - we can have a "visualize range on map" intent
> (with parameters like - max range, kWh available, weight of car,
> efficiency) and have different apps implement that intent and create
> visualization based on the input data. This would be similar in the way the
> contacts app in your android phone can dial a phone number with the phone
> app via dialing intent.
> I am not sure how would this best be done in the IOS world.
> Note that I am partial - I am the founder of www.uppladdning.nu a
> database/mapping on charging sites solution for the nordic region and have
> had some dealings with the openchargemap before.
> Nikolay
> Sent: Wednesday, March 6, 2013 2:12 AM
> Felix,
> Yes, I agree. This is really not something that can ever be 100% - we just
> want something to represent roughly what is possible and to limit the
> charge stations that we show.
> A nice thing about circles is that it easy to visually estimate 50% (or
> whatever), so I think the user can do this themselves.
> Perhaps the existing outer estimated-to-ideal circle at 50% transparency,
> then an inner estimated-to-N%estimated circle at 25% transparency? Or is
> that too complex?
> We're also planning to have a feature of show-route-to-charging-station,
> for a particular selected charging station, and that will be google maps /
> whatever so will show real distance by road.
> On 6 Mar, 2013, at 9:03 AM, felix bonnier wrote:
> Hi Mark,
> The only thing with this is, obviously roads are not straight so a
> radius will never show a correct estimate. I think the range estimate
> would have to
> be only a percentage of the two values so that the range circle would be
> more realistic….. Maybe 60% of the values given by the car or something to
> that effect. Otherwise you will never make it to the next charge point……….
> what do you think?
> felix b.
> On Mar 6, 2013, at 8:46 AM, Mark Webb-Johnson <mark at webb-johnson.net>
> wrote:
> Working with the guys at zerocarbonworld / openchargemap on the
> integration of Open Charge Map to the OVMS Apps, we are trying to find a
> way to represent range graphically.
> The first idea was a circle, centered around the car, with the inner
> edge of the circle being estimated range and the outer edge ideal range (or
> vice versa if you are coming down the mountains on a _long_ mountain road).
> Plugging in the values for my car today,
> assuming I was somewhere in the centre of the UK, it would look something
> like this:
> <PastedGraphic-4.png>
> The idea is to represent the range, and then plot the charge points
> within (and perhaps also slightly outside) that range.
> That is just one idea. What do people think? Any other suggestions?
> P.S. Work on the Apps for this has already started, so I would
> appreciate a quick reply. Nothing too extensive - just ideas.Thanks.
> OvmsDev mailing
> list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130416/43139e4b/attachment-0001.html>
Name: not available
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130416/43139e4b/attachment-0002.png>
Name: not available
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130416/43139e4b/attachment-0003.png>
