[Ovmsdev] GPS Logs (TWIZY) -- Future Feature?
Nikki Gordon-Bloomfield
nikki at littlecollie.com
Tue Apr 9 00:06:17 HKT 2013
Hi Michael,
Confirmed CAN bus happily connected (ODB2), and that modules are firmly affixed with good signal.
Attached is the BattPack.CSV file, along with the other four logs. . Notice that there's a big gap where it stopped reporting and then I reconnected it (That's what the reboots are in the logs: when I reconnected the system after firmware installation and when I reconnected to reboot it)
Given that it completely died for the best part of my trip, I'm tempted to suggest that it was a firmware bug.
In addition, my Twizy now reports a range in the hundreds of miles! Congratulations, you broke the laws of physics (Or we've shifted to the right one too many!)
Nikki.
On 8 Apr 2013, at 16:14, Nikki Gordon-Bloomfield <nikki at littlecollie.com> wrote:
> Ok! I'll check when I get home!
> Sent from my iPhone
> On 8 Apr 2013, at 16:09, Michael Balzer <dexter at expeedo.de> wrote:
>> ...or an antenna / GSM problem, logs are sent on GSM connect also.
>> Am 08.04.2013 17:02, schrieb Michael Balzer:
>>> Nikki,
>>> that rather looks like some problem with your OBD2 connector (12V power supply), as the logs show only first boots instead of resets/crashes.
>>> Can you check that?
>>> I have no problem running the last version I sent.
>>> Thanks,
>>> Am 08.04.2013 16:32, schrieb Nikki Gordon-Bloomfield:
>>>> Michael,
>>>> Here's my debug log. Any use?
>>>> Nikki.
>>>> OvmsDev mailing list
>> <dexter.vcf>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/31903f07/attachment-0005.html>
Type: text/csv
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/31903f07/attachment-0004.bin>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/31903f07/attachment-0006.html>
Type: text/csv
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/31903f07/attachment-0005.bin>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/31903f07/attachment-0007.html>
Type: text/csv
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/31903f07/attachment-0006.bin>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/31903f07/attachment-0008.html>
Type: text/csv
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/31903f07/attachment-0007.bin>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/31903f07/attachment-0009.html>
