[Ovmsdev] GPS Logs (TWIZY) -- Future Feature?
Mon Apr 8 14:06:25 HKT 2013
Nikki,
I think I found the bug, please use the attached new version instead.
I'll also test that one myself later on today.
PS: your posts are great to read! I also like your idea for a permanent
installation place of the OVMS, I still have mine in the glove box.
Am 07.04.2013 19:48, schrieb Michael Balzer:
> Nikki,
> I have added these fields to the RT-GPS-Log message:
> // current power (W)
> // power usage sum (Wh)
> // recuperation sum (Wh)
> // distance driven (m)
> Be aware that the "current power" is really the power use of the exact
> moment the message is sent, no average. This reacts to any bump in the
> road or wind gust. So the sums will normally be more useful, but will
> need deriving the section differences in a post processing step.
> New firmware image attached. So if you activate GPS streaming you'll
> get updates every 5 seconds, which should already give a very detailed
> view of the power usage (if GPS position can be acquired fast and
> precise enough).
> I had a strange effect (read: possible bug) on the first test run:
> distance would start at 6546 meters (should be 0). That could have
> been because I was very fast with flashing so maybe the SRAM init was
> skipped... but maybe it's a real bug. If it's a bug it will also
> affect the power usage statistics, resulting in too low Wh/km figures.
> Please tell me if you still see a similar fault if you wait 2-3
> minutes from flashing to reinstalling.
> Thanks,
> Am 07.04.2013 16:36, schrieb Mark Webb-Johnson:
>> Instantaneous power should be available in most cars. It is certainly
>> there in the roadster (because we spoof it to show speed as a digital
>> speedo).
>> It would not be hard to add it to the model and to the location
>> streaming feature when an App is connected.
>> On 6 Apr, 2013, at 10:39 PM, Michael Balzer <dexter at expeedo.de
>>> ...btw, it would be quite easy to send power usage updates within
>>> the streaming update mode, just adds some traffic. So you would get
>>> 5 second sections in GPS and power usage, easier to correlate. But
>>> still the power usages would be far easier to process when being
>>> included in the GPS messages.
>>> Am 06.04.2013 16:29, schrieb Michael Balzer:
>>>> Nikki, Mark,
>>>> I decided against adding the current power to the GPS log because
>>>> that's something not defined in the general virtual car model, all
>>>> other cars lack this feature, and I wanted to make the GPS log
>>>> function fit for inclusion in the framework first.
>>>> I currently send the power usage log (RT-PWR-UsageStats) once per
>>>> minute. You can correlate that to the GPS log to get the power
>>>> usage of minute long sections, but that's a lot of manual work and
>>>> not very detailed (e.g. for hills).
>>>> Btw: using the power collection feature, you can also measure
>>>> certain route parts: easiest way is to turn the Twizy on just
>>>> before driving the section, then turn the Twizy off and check the
>>>> power stats message. But a combined GPS track would of course be
>>>> far better and more accurate.
>>>> Mark, you mentioned a "kWh used" value with the driving log
>>>> function, so I guess we can think about adding the power usage to
>>>> the standard car model?
>>>> But I'm not sure yet if the way I currently collect power usages is
>>>> suitable and sufficient as a standard. As I wrote in the docs,
>>>> that's work in progress... any thoughts on this?
>>>> Regards,
>>>> Michael
>>>> Am 06.04.2013 15:39, schrieb Nikki Gordon-Bloomfield:
>>>>> Hi folks,
>>>>> Just got the server.pl running and the client_app.pl running on my
>>>>> Ubuntu box at home. And I've pulled down the GPS Logs for the Twizy.
>>>>> One thing that's missing, which I'd love to see in the future, is
>>>>> an instantaneous power reading. This would enable us to not only
>>>>> plot the course, but figure out where the most demanding part of a
>>>>> trip is based on power drainage.
>>>>> Anyone else think it's a good idea?
>>>>> http://about.me/aminorjourney/bio
>>>>> email: nikki at littleCollie.com
>>>>> tel: +44 7901 553308
>>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/e85d4ef4/attachment-0001.html>
Type: text/x-hex
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/e85d4ef4/attachment-0001.bin>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/e85d4ef4/attachment-0001.vcf>
