[Ovmsdev] Tazzari Pictures for the App
Mon Apr 8 09:36:00 HKT 2013
Patrick,
Here are some notes from before:
> For new vehicles, to get the images into the apps, we need images in a similar size, orientation and layout.
> The images are:
> 1] The car front-angle view. 654x302 pixels, high quality PNG format. One for each colour to be supported. The background must be transparent.
> If you have problems with aspect ratio, try to keep the width the same, and leave space on the top/bottom.
> 2] The car xray view, 304x606 pixels, high quality PNG format. One for each colour to be supported. The background must be transparent.
> You should try to keep the wheels in approximately the same position as the attached picture (in particular if your vehicle supports TPMS). If you have problems with aspect ratio, try to keep the height the same, and leave space on the sides.
> 3] Car map images. 96x96 pixels, medium quality PNG format. One for each colour to be supported. Car must be pointing upwards (north). The background must be transparent.
> 4] Name of vehicle type
> We also need the official name and model of the vehicle type (eg. Tesla Roadster, Nissan Leaf, Volt Ampera, etc).
> 5] File naming
> The files should be named as follows:
> car_<type>_<colour>.png (for the car front-angle view)
> ol_car_<type>_<colour>.png (for the car X-ray view)
> map_car_<type>_<colour>.png (for the car map image)
> The <type> is the vehicle type (e.g.; roadster, ampere, twizy, etc). The <colour> is the official colour name (e.g.; thundergray, crystalred, lithiumwhite, electricblue, etc).
> Once we have artwork in the correct format, putting it in the apps is trivial. The primary problem is finding artwork of appropriate quality and style, with a transparent background.
I'll have a look to see what is available for Tazzari.
On 6 Apr, 2013, at 3:00 AM, Patrick Kapsch wrote:
> Hi Guys,
> attached you find a picture which could be used to integrate the Tazzari Zero into the range of cars in the App. It isn't anywhere near high-res but a decent size which is usable for now.
> Patrick
> <IMG_2286.PNG><tazzari-zero001_enl.jpg>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/792d736e/attachment-0001.html>
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/792d736e/attachment-0003.png>
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/792d736e/attachment-0004.png>
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130408/792d736e/attachment-0005.png>
