[Ovmsdev] GPS Logs (TWIZY) -- Future Feature?
Sun Apr 7 22:36:54 HKT 2013
Instantaneous power should be available in most cars. It is certainly there in the roadster (because we spoof it to show speed as a digital speedo).
It would not be hard to add it to the model and to the location streaming feature when an App is connected.
On 6 Apr, 2013, at 10:39 PM, Michael Balzer <dexter at expeedo.de> wrote:
> ...btw, it would be quite easy to send power usage updates within the streaming update mode, just adds some traffic. So you would get 5 second sections in GPS and power usage, easier to correlate. But still the power usages would be far easier to process when being included in the GPS messages.
> Am 06.04.2013 16:29, schrieb Michael Balzer:
>> Nikki, Mark,
>> I decided against adding the current power to the GPS log because that's something not defined in the general virtual car model, all other cars lack this feature, and I wanted to make the GPS log function fit for inclusion in the framework first.
>> I currently send the power usage log (RT-PWR-UsageStats) once per minute. You can correlate that to the GPS log to get the power usage of minute long sections, but that's a lot of manual work and not very detailed (e.g. for hills).
>> Btw: using the power collection feature, you can also measure certain route parts: easiest way is to turn the Twizy on just before driving the section, then turn the Twizy off and check the power stats message. But a combined GPS track would of course be far better and more accurate.
>> Mark, you mentioned a "kWh used" value with the driving log function, so I guess we can think about adding the power usage to the standard car model?
>> But I'm not sure yet if the way I currently collect power usages is suitable and sufficient as a standard. As I wrote in the docs, that's work in progress... any thoughts on this?
>> Am 06.04.2013 15:39, schrieb Nikki Gordon-Bloomfield:
>>> Hi folks,
>>> Just got the server.pl running and the client_app.pl running on my Ubuntu box at home. And I've pulled down the GPS Logs for the Twizy.
>>> One thing that's missing, which I'd love to see in the future, is an instantaneous power reading. This would enable us to not only plot the course, but figure out where the most demanding part of a trip is based on power drainage.
>>> Anyone else think it's a good idea?
>>> http://about.me/aminorjourney/bio
>>> email: nikki at littleCollie.com
>>> tel: +44 7901 553308
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130407/ebcfaeff/attachment.html>
