[Ovmsdev] GPS Logs (TWIZY) -- Future Feature?
Sat Apr 6 22:29:30 HKT 2013
Nikki, Mark,
I decided against adding the current power to the GPS log because that's
something not defined in the general virtual car model, all other cars
lack this feature, and I wanted to make the GPS log function fit for
inclusion in the framework first.
I currently send the power usage log (RT-PWR-UsageStats) once per
minute. You can correlate that to the GPS log to get the power usage of
minute long sections, but that's a lot of manual work and not very
detailed (e.g. for hills).
Btw: using the power collection feature, you can also measure certain
route parts: easiest way is to turn the Twizy on just before driving the
section, then turn the Twizy off and check the power stats message. But
a combined GPS track would of course be far better and more accurate.
Mark, you mentioned a "kWh used" value with the driving log function, so
I guess we can think about adding the power usage to the standard car model?
But I'm not sure yet if the way I currently collect power usages is
suitable and sufficient as a standard. As I wrote in the docs, that's
work in progress... any thoughts on this?
Am 06.04.2013 15:39, schrieb Nikki Gordon-Bloomfield:
> Hi folks,
> Just got the server.pl running and the client_app.pl running on my
> Ubuntu box at home. And I've pulled down the GPS Logs for the Twizy.
> One thing that's missing, which I'd love to see in the future, is an
> instantaneous power reading. This would enable us to not only plot the
> course, but figure out where the most demanding part of a trip is
> based on power drainage.
> Anyone else think it's a good idea?
> http://about.me/aminorjourney/bio
> email: nikki at littleCollie.com
> tel: +44 7901 553308
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130406/ab55c441/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130406/ab55c441/attachment.vcf>
