[Ovmsdev] v2.2.6
Nikki Gordon-Bloomfield nikki at littlecollie.com
Wed Apr 3 21:29:40 HKT 2013
Haha!
Michael. I am in the south west. We have some great hills here. I will have to capture the 60 mph downhill section for CANBus analysis!
On 3 Apr 2013, at 14:25, Michael Balzer <dexter at expeedo.de> wrote:
> Nikki,
> no, that's too far below average... just kidding ;)
> FYI: my usage averages at only 90 miles/week, top average in the german forum has been around 300 miles/week. I read about a german pizza delivery service using several Twizys each now around 15.000 miles -- they needed to replace their brake discs... recuperation is not strong enough for pizza boys it seems ;)
> Thanks!
> Am 03.04.2013 15:03, schrieb Nikki Gordon-Bloomfield:
>> Michael, Mark.
>> I'm going to be doing about 150 miles a week in my Twizy from next week. Does this count as being a thorough enough test? ;)
>> Nikki.
>> On 3 Apr 2013, at 13:49, Michael Balzer <dexter at expeedo.de> wrote:
>>> Mark,
>>> I once looked up the stack issue and found it as being reserved outside the variable RAM, so basically we can get to zero. I think your memory map linker option also confirmed this. I and the other german users have had this config in our Twizys for many months now without any problems.
>>> A special config is an option if there is a problem, but that means Twizy OVMS users will need to flash their modules if they want full functionality. I think we should deliver factory OVMS with full functionality if possible.
>>> Also, as all battery monitor ram usage is in the overlay section, the other car modules should not be affected (and can use that space for their own purposes later on).
>>> How about an extended test from all developers using the full featured firmware to see if there are really any problems with this -- I don't think so.
>>> Am 03.04.2013 14:19, schrieb Mark Webb-Johnson:
>>>> Michael,
>>>> I just checked, and that OVMS_TWIZY_BATTMON takes ram from 426 bytes free to 208. A little bit scary, given that I am about to add the trip logging functions. I'm really not sure what happens with the stack, and if it is counted in those 208 bytes. Can we get to zero?
>>>> But, I see this as a useful function for Twizy owners.
>>>> How about I create a new firmware config V2_FullTwizy that includes just the Twizy module but also OVMS_TWIZY_BATTMON?
>>>> Regards, Mark.
>>>> On 3 Apr, 2013, at 5:54 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>> Nikki,
>>>>> for the Twizy: I think the V2 "developer version" still does not include the battery monitor -- I had to add the compiler switch again after my last local merge.
>>>>> If you compile yourself, check the configuration for the OVMS_TWIZY_BATTMON define.
>>>>> Or let me know if you need a precompiled image.
>>>>> Regards,
>>>>> Michael
>>>>> Am 02.04.2013 22:08, schrieb Nikki Gordon-Bloomfield:
>>>>>> I'll be updating it tomorrow!
>>>>>> Sent from my iPhone
>>>>>> On 2 Apr 2013, at 20:35, Tom Saxton <tom at idleloop.com> wrote:
>>>>>>> Links to the v2.2.6 firmware are now up on my firmware download page:
>>>>>>> http://www.idleloop.com/tesla/ovms/
>>>>>>> The release notes link points to the entry for v2.2.5, which is probably
>>>>>>> close enough.
>>>>>>>    Tom
>>>>>>> on 4/2/13 5:48 AM, Mark Webb-Johnson wrote:
>>>>>>>> I was getting 12v alerts in my roadster. I don't think the new logic is
>>>>>>>> compatible with the roadster battery behaviour.
>>>>>>>> Anyway, I've rolled v2.2.6 with the following changes:
>>>>>>>> 2013-04-02 2.2.6       Firmware 2.2.6
>>>>>>>>                       ## Volt Ampera fixes (from Michael)
>>>>>>>>                       ## Support net_fnbits NET_FN_12VMONITOR and
>>>>>>>> NET_FN_SOCMONITOR to allow vehicle module to control what is monitored
>>>>>>>> I brought in the Volt Ampera fixes pending from Michael (some changes to the
>>>>>>>> source of SOC).
>>>>>>>> I also added NET_FN_12VMONITOR and NET_FN_SOCMONITOR to net_fnbits, to allow
>>>>>>>> the vehicle modules to turn on/off those monitoring. I changed the vehicle
>>>>>>>> modules appropriately (in particular 12VMONITOR is off in the Tesla Roadster,
>>>>>>>> and SOCMONITOR is off in the Volt/Ampera).
>>>>>>>> Now testing this v2.2.6 in my car, but it will likely be 24 hours before I
>>>>>>>> know if it is behaving better.
>>>>>>>> Regards, Mark.
>>>>>>>> On 1 Apr, 2013, at 6:59 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>>>>>>> This is now in my car, and running well.
>>>>>>>>> For CAC, I had:
>>>>>>>>> rx msg S 66,K,222,0,charging,standard,206,200,56,0,100,0,5,1,0,0,0,-1,0
>>>>>>>>> then, I started a charge, and now get:
>>>>>>>>> rx msg S 66,K,223,0,charging,standard,206,200,56,0,100,0,5,1,0,0,0,-1,15694
>>>>>>>>> That's what I would expect - the code will poll for latest CAC whenever (a) a
>>>>>>>>> charge starts, (b) the car is turned on, or (c) the car is turned off.
>>>>>>>>> Regards, Mark.
>>>>>>>>> On 1 Apr, 2013, at 5:30 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>>>>>>>> Back from the brinkŠ Good grief, there is some nasty stuff coming out of
>>>>>>>>>> China now.
>>>>>>>>>> I managed to spend some time on OVMS firmware today, and built v2.2.5.
>>>>>>>>>> Change log is:
>>>>>>>>>> 2013-04-01 2.2.5       Firmware 2.2.5
>>>>>>>>>>                       ### Fixes for charge notification logic on VA
>>>>>>>>>>                       ### Show charge, trunk and alarm notifications in
>>>>>>>>>> DIAG mode
>>>>>>>>>>                       ### Speed, parking, and general tidy-ups for VA
>>>>>>>>>>                       ### Switch ambient temperature to PID 0x801f for VA
>>>>>>>>>>                       ### Auto-calibration for 12V line reading
>>>>>>>>>>                       ### Twizy version 2.6.1 - power line plug-in
>>>>>>>>>> detection
>>>>>>>>>>                       ### Add car_doors5 for rear doors, frunk and 12v
>>>>>>>>>> charging
>>>>>>>>>>                       ### 12v alert by MSG protocol fix
>>>>>>>>>>                       ### Rework of 12V reference logic
>>>>>>>>>>                           - Filters out single peaks / misreadings
>>>>>>>>>>                           - Sends "OK" alerts if voltage level restores w/o
>>>>>>>>>> charging
>>>>>>>>>>                           - 15 minutes calmdown before taking new ref
>>>>>>>>>> voltage
>>>>>>>>>>                           - No alerts while car is on
>>>>>>>>>>                       ### ESS SOC DIAG (for TR)
>>>>>>>>>>                       ### Initial support for CAC in TR and TZ modules
>>>>>>>>>>                       ### Experimental Tazzari (TZ) module
>>>>>>>>>>                       ### Experimental Nissan Leaf (NL) module
>>>>>>>>>> All is in github.
>>>>>>>>>> I haven't run it in my car yet, but it tests out fine on the bench. It is
>>>>>>>>>> going into my car in a few minutes time.
>>>>>>>>>> Major changes are the experimental support for Tazzari, some bug fixes and
>>>>>>>>>> 12V work on Twizzy, and support for CAC readings in Tazzari and Tesla
>>>>>>>>>> Roadster (including protocol extensions to report back to apps).
>>>>>>>>>> Regards, Mark.
>>>>>>>>>> P.S. I haven't had time to make anything good for 1st April this year
>>>>>>>>>> (although I did consider an experimental module for Hummer support). Anyway,
>>>>>>>>>> please consider any bugs in this version just an April fools joke.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>> OvmsDev at lists.teslaclub.hk
>>>>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>>>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>>> <dexter.vcf>_______________________________________________
