[Ovmsdev] v2.2.5
Tue Apr 2 20:52:32 HKT 2013
Tom,
After 24 hours in my car, it has been 156.94 through 2 charges and 2 drives. I'm not sure how Tesla calculates this, but it seems very stable.
It was also 156.99 just three weeks ago - Car doesn't like sitting idle while I'm sick :-(
There are some app changes being made at the moment - once those are done, I'll get it added to the Info screen on the Apps.
On 2 Apr, 2013, at 1:16 AM, Tom Saxton <tom at idleloop.com> wrote:
> I'm so looking forward to being able to easily get the CAC value!
> In our Roadster, the CAC seems to update when the SOC settles, which is
> typically about 10 minutes after a charge or drive, although sometimes it
> takes longer. So it would be perfect to query the CAC:
> - 30 minutes after a charge
> - 30 minutes after the car is turned off
> - when the car is turned on within 30 minutes of a charge or turn off
> If you don't want to mess with that complexity, (a) and (b) are pretty
> effective. Based on what I've observed, I would expect (b) and the following
> (c) to always return the same result for a Roadster, bu it would be
> interesting to confirm that.
>    Tom
> on 4/1/13 3:59 AM, Mark Webb-Johnson wrote:
>> This is now in my car, and running well.
>> For CAC, I had:
>> rx msg S 66,K,222,0,charging,standard,206,200,56,0,100,0,5,1,0,0,0,-1,0
>> then, I started a charge, and now get:
>> rx msg S 66,K,223,0,charging,standard,206,200,56,0,100,0,5,1,0,0,0,-1,15694
>> That's what I would expect - the code will poll for latest CAC whenever (a) a
>> charge starts, (b) the car is turned on, or (c) the car is turned off.
>> On 1 Apr, 2013, at 5:30 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> Back from the brinkŠ Good grief, there is some nasty stuff coming out of
>>> China now.
>>> I managed to spend some time on OVMS firmware today, and built v2.2.5. Change
>>> log is:
>>> 2013-04-01 2.2.5       Firmware 2.2.5
>>>                       ### Fixes for charge notification logic on VA
>>>                       ### Show charge, trunk and alarm notifications in DIAG
>>> mode
>>>                       ### Speed, parking, and general tidy-ups for VA
>>>                       ### Switch ambient temperature to PID 0x801f for VA
>>>                       ### Auto-calibration for 12V line reading
>>>                       ### Twizy version 2.6.1 - power line plug-in detection
>>>                       ### Add car_doors5 for rear doors, frunk and 12v
>>> charging
>>>                       ### 12v alert by MSG protocol fix
>>>                       ### Rework of 12V reference logic
>>>                           - Filters out single peaks / misreadings
>>>                           - Sends "OK" alerts if voltage level restores w/o
>>> charging
>>>                           - 15 minutes calmdown before taking new ref
>>> voltage
>>>                           - No alerts while car is on
>>>                       ### ESS SOC DIAG (for TR)
>>>                       ### Initial support for CAC in TR and TZ modules
>>>                       ### Experimental Tazzari (TZ) module
>>>                       ### Experimental Nissan Leaf (NL) module
>>> All is in github.
>>> I haven't run it in my car yet, but it tests out fine on the bench. It is
>>> going into my car in a few minutes time.
>>> Major changes are the experimental support for Tazzari, some bug fixes and
>>> 12V work on Twizzy, and support for CAC readings in Tazzari and Tesla
>>> Roadster (including protocol extensions to report back to apps).
>>> P.S. I haven't had time to make anything good for 1st April this year
>>> (although I did consider an experimental module for Hummer support). Anyway,
>>> please consider any bugs in this version just an April fools joke.
