[Ovmsdev] Feature request: secured charging
Wed Sep 12 17:02:31 HKT 2012
I don't think anyone has found the 'trigger the alarm' function (if it exists), but there was some talk of being able to make the car beep-beep-beep if you send the lock/unlock codes quickly.
After the current firmware code changes are completed, I plan to have a look to see if I can find the 'alarm sounding' (for Michael's request). I'll have a play with this at the same time.
On 12 Sep, 2012, at 3:42 PM, Dominik Westner wrote:
> Hi,
> I was wondering if it would be possible to trigger the car alarm for 10s if charging is interrupted while the car is locked.
> I live right in the middle of Munich and don't have a garage where I can charge (really hard to find) close by.
> However I have some public charging stations very close to my home which I am regularly using. Unfortunately charging will be interrupted almost every second time now, because some people disconnect the cable. It is very annoying and I don't understand why people would do that. But it happens more and more. And it is also likely that it is the same people doing it.
> My hope is that some people would be scared away if the alarm goes off and not doing it the next time again.
> Thanks
> Dominik
