[Ovmsdev] Merging in Twizy and Volt/Ampera work
Tue Nov 20 02:40:50 HKT 2012
Mark,
Am 19.11.2012 14:34, schrieb Mark Webb-Johnson:
>> ...plus a new common code for "ALERT", if you agree on routing the net_msg_alert() function through the dispatcher as well to allow vehicle control over this.
> Can you explain more what you require here?
I would like to change the text for charge alerts to the App the same
way I did with the SMS alerts, especially to get the SOC min/max and
odometer.
So I would basically overload net_msg_alert() with my vehicle specific
version. That will require either a specific hook for just this
function, or -- my suggestion -- the introduction of a msg command
"ALERT", so the existing cmd overloading framework can simply be used. I
tend to the cmd solution because that's nice in line with the SMS way. I
know the command now would not be needed by the Apps, but it wouldn't
hurt either.
So instead of calling net_msg_alert() directly (which happens only at
one place now), we would call net_msg_cmd_do() with i.e.
net_msg_cmd_code=NET_CMD_ALERT and let the net and vehicle dispatchers
decide which alert function to execute. May sound a bit complicated
first, but would IMO also provide clean and clear extendability for
maybe other future notifications sent from the module to the App.
I can prepare a Twizy implementation of this if you like to have a look
at the application side first.
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121119/f58a6876/attachment-0002.vcf>
