[Ovmsdev] Merging in Twizy and Volt/Ampera work
Sun Nov 4 20:37:50 HKT 2012
Am 04.11.2012 04:11, schrieb Mark Webb-Johnson:
> A while ago, Michael Balzer suggested to me that it would be best to
> have one firmware supporting all cars.
That wasn't me. The idea sounds good, but...
- car platforms to be supported will increase steadily now, there are
lots to come in the next years
- even cars with decent builtin online monitoring systems lack some
functionality for nerds like us
- there will be a need for custom product configuration per car anyway,
as cabling and antenna configuration will be different
ROM space is plenty, I'm more concerned about the RAM usage. Can those
car specific #pragma udata globals easily be replaced by a dynamic
object to be allocated on module init?
Also, not only the CAN module may need car specific adaption. I've not
yet completely read into the server protocol (btw: I can only read up to
line 201 of docs/OVMS_Protocol.doc using UTF-16 -- rest is garbled), but
got the impression it contains some common and some Tesla specific data.
If we have to integrate specific data from every model supported, the
data stream can become quite fat. So it seems to be necessary to
implement some dynamic data / protocol configuration model as well? I.e.
divide into a common set of properties available on most car models plus
a dynamic car special feature property set.
Example: one of my next ideas is a cell monitor to get a history of the
cell voltage levels, so I can detect and alert about cell failures
early. The Twizy has 14 cell packs (14S 2P we think) and we've got their
voltages on CAN. Even for the small Twizy pack + data compression this
will need some RAM (or server traffic + App support). The Tesla has an
11S 9S 69P configuration (?), so that would need much more history RAM +
possibly another data layout -- if the voltages are on CAN at all.
Another example I already stumbled on: the car_doors1 flag 0x04 (charge
port open) is currently used by net_sms_stat(), if it's not set, it
assumes "not charging". So even some standard functions rely on Tesla
specific data.
So, maybe the data and protocol models need to be generalized first? Or
am I missing something?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121104/f53f5832/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121104/f53f5832/attachment-0002.vcf>
