[Ovmsdev] Vehicle Images
Sun Nov 4 11:30:42 HKT 2012
For new vehicles, to get the images into the apps, we need images in a similar size, orientation and layout.
The images are:
1] The car front-angle view. 654x302 pixels, high quality PNG format. One for each colour to be supported. The background must be transparent.
If you have problems with aspect ratio, try to keep the width the same, and leave space on the top/bottom.
2] The car xray view, 304x606 pixels, high quality PNG format. One for each colour to be supported. The background must be transparent.
You should try to keep the wheels in approximately the same position as the attached picture (in particular if your vehicle supports TPMS). If you have problems with aspect ratio, try to keep the height the same, and leave space on the sides.
3] Car map images. 96x96 pixels, medium quality PNG format. One for each colour to be supported. Car must be pointing upwards (north). The background must be transparent.
4] Name of vehicle type
We also need the official name and model of the vehicle type (eg. Tesla Roadster, Nissan Leaf, Volt Ampera, etc).
5] File naming
The files should be named as follows:
The <type> is the vehicle type (e.g.; roadster, ampere, twizy, etc). The <colour> is the official colour name (e.g.; thundergray, crystalred, lithiumwhite, electricblue, etc).
Once we have artwork in the correct format, putting it in the apps is trivial. The primary problem is finding artwork of appropriate quality and style, with a transparent background.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121104/40bdf819/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121104/40bdf819/attachment-0006.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121104/40bdf819/attachment-0007.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121104/40bdf819/attachment-0008.png>
