[Ovmsdev] Merging in Twizy and Volt/Ampera work
Mon Nov 19 21:34:00 HKT 2012
Michael,
> I'll first need cmd codes for...
> DEBUG
> RANGE
> CA
> For vehicle specific cmds you wrote earlier we could just use arbitrary codes 200+, can I still do so or do you want to directly assign standard codes for some of them?
I think we can say everything in the range 200-255 is private, per vehicle module. Allocate them as you require.
> ...plus a new common code for "ALERT", if you agree on routing the net_msg_alert() function through the dispatcher as well to allow vehicle control over this.
Can you explain more what you require here?
On 19 Nov, 2012, at 3:32 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Am 18.11.2012 13:38, schrieb Mark Webb-Johnson:
>> I've just pushed my last set of changes. It seems ok from my end now. The code runs and sms commands function as expected. I've added a capabilities message that is sent car->server->apps and will be useful to tailor the app functions to what the car can do.
> As everything so far seems to be working pretty well, I'll next add the msg cmd handlers for my commands, to see how that fits.
> DEBUG
> RANGE
> CA
> ...if some cmd later becomes standard, we can just add that code to the dispatcher switch:
>     case 7: // standard cmd: DEBUG
>     case 200: // obsolete specific cmd: DEBUG
>         do_alert(...);
> ...at least if the arguments match the standard :-)
