[Ovmsdev] New features: sufficient charge alerts, ideal max range
Mon Nov 12 00:56:29 HKT 2012
Mark,
it doesn't seem the old Android App supports setting arbitrary features?
I currently have to use SMS to set them.
I need these configs to be persistent as the module does quite a lot of
resets at the moment, it seems especially if GPRS connectivity is bad.
I just had to take yet another persistent feature slot (13) in use to
store my last known range due to permanently losing my range
calculations during charge.
I tried to sort out why I get those resets and found the
// Temporary kludge to record in feature #10 the number of times
this happened
...but my value was not increased, even after I watched the module doing
a reset.
Is there another condition for an automatic reset? I found none...
I thought feature slots are especially meant for this kind of user
configuration. I could avoid using feature slots at all if a) the module
would only do a reset if absolutely needed (so I don't lose my local
configuration) and b) I can introduce a car specific command to set my
local configuration. Or is there another way?
Am 11.11.2012 13:35, schrieb Mark Webb-Johnson:
> Michael,
> I guess you need these as features, so they can be set from the App?
> If so, can they be put as experimental at the moment? Those won't survive a reboot, but are less impacting. I suggest 0x05, 0x06 and 0x07.
> For MAXRANGE, that is fine. Make it a permanent feature, 0x0D.
> On 11 Nov, 2012, at 7:42 AM, Michael Balzer <dexter at expeedo.de> wrote:
>> Mark,
>> I just checked in my latest Twizy updates:
>> https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/0a70e483baf182f4226d1a1afc8d0734c2fa48d9
>> These contain two extensions that could be generally useful:
>> 1) As the Twizy "ideal" range varies widely depending on your driving, geography and environment, I implemented a feature for that config.
>> 2) If I just need an intermediate charge for a certain SOC or range (to get home for example), I can now activate an alert for one or both values.
>> I used the next three free feature slots for these:
>> #define FEATURE_SUFFSOC 0x0A // Sufficient SOC feature
>> #define FEATURE_SUFFRANGE 0x0B // Sufficient range feature
>> #define FEATURE_MAXRANGE 0x0C // Maximum ideal range feature
>> I know, feature slots are getting full... what do you think?
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121111/c4f6574a/attachment.vcf>
