[Ovmsdev] Twizy
Sun Nov 11 07:50:54 HKT 2012
For the record: I now have connected GND to both 4+5 on the OBD2 plug,
works as well.
Am 10.11.2012 19:57, schrieb mikeljo at me.com:
> Hi,
> i use this pinout:
> Primary Data Link Connector- (DLC) X84 *Under drivers side of IP
> Pin 1 is Low Speed GMLAN (SWCAN ~33.3kbps) - Body Electrical Services
> Only Pin 2-3 Unused
> Pin 4 chassis ground (for scan tool)
> Pin 5 data reference ground
> Pins 6(+) & 14 (-) High Speed GMLAN- Primary Powertrain Bus (DWCAN
> ~500 kbps) Pins 7-11 Unused
> Pins 12(+) & 13(-) High Speed GMLAN- Chassis Expansion Bus (DWCAN ~500
> kbps) Pin 15 Unused
> Pin 16 B+ (for scan tool power)
> OBDIISub-DSignal
> 169+12V
> 46+3GND-Chassis
> 67CAN_H
> 142CAN_L
> I connect 6 and 3 at the Sub-D side together.
> So it looks like we can use the same Cable (for the Primary Can Bus in
> the Volt). >> Fasttech?
> Bye
> Am 10.11.2012 um 06:47 schrieb Mark Webb-Johnson
> <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>> Yes, chassis GND vs signal GND, but can is differential, so no GND
>> needed for the signal. We only need GND for 12V power. For vehicles,
>> I think chassis GND is ok.
>> I think Volt bus we are using is on the same pins:
>> http://www.evtools.info/ChevyVoltOBD2CAN.html
>> Maybe 1 cable can do both?
>> Regards, Mark
>> On 10 Nov, 2012, at 12:18 PM, Michael Balzer <dexter at expeedo.de
>>> Mark,
>>> yes, that's chassis ground -- shouldn't it be? I interpreted the
>>> OVMS GND as the ground for the supply voltage (12V), as the CAN bus
>>> has its dedicated "low" line.
>>> I just looked up some OBD2 sites: 4+5 normally are the same. One
>>> page says an OBD2 cable should have identical potential on 4 and 5
>>> to ensure proper function. Another OBD2 cable I bought connects
>>> them, so maybe for a general product GND should connect both, but I
>>> don't think there's a difference on the car side... normally.
>>> But I've also seen some info on non standard OBD2 plugs, also for
>>> some GM and Opel cars, having other signals where the CAN bus should
>>> be, so I'm also interested in your pinout, Michael J.
>>> Am 10.11.2012 04:23, schrieb Mark Webb-Johnson:
>>>> Michael,
>>>> One question: you have GND on pin #4 (odb). I have that shown as
>>>> chassis ground, not signal ground. Is that correct?
>>>> Michael J: is that the same connector and pins as you are using for
>>>> the Volt?
>>>> Regards, Mark
>>>> On 10 Nov, 2012, at 2:16 AM, Michael Balzer <dexter at expeedo.de
>>>>> Mark,
>>>>> great to hear about user activity :-)
>>>>> 1) I just created an OVMS to OBD2 cable image and checked it in:
>>>>> https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/a7c3a3e8f12d7759b896bb75c8e570ebc10ec11a
>>>>> As OBD2 is standard incl. CAN pinout, this should be valid for any
>>>>> OBD2 port, so could be added to the FastTech OVMS product line.
>>>>> It's not a standard cable, or at least none I know of.
>>>>> 2) No known way up to now. I also think the Twizy would not
>>>>> respond to the port, as the whole CAN bus is quiet when the car is
>>>>> off and not charging. Plus, because the charger draws some 30-35 W
>>>>> for many hours after charging has completed, many drivers use
>>>>> auto-power-off sockets.
>>>>> 3) I'll forward your specification to the german Twizy forum.
>>>>> Regards,
>>>>> Michael
>>>>> Am 09.11.2012 15:23, schrieb Mark Webb-Johnson:
>>>>>> Twizy support seems to be coming along nicely, thanks to the
>>>>>> amazing work Michael is doing. Some good functionality there already.
>>>>>> I'm starting to see some Twizy users register on openvehicles.com
>>>>>> <http://openvehicles.com/>. Perhaps the word is getting out?
>>>>>> Some questions / requests:
>>>>>> 1. Michael: Can you let me have the details on the cable pinouts
>>>>>> and parts you are using at the moment? Is it a standard
>>>>>> cable, or are you having to make something up?
>>>>>> 2. How is charge control on the Twizy done? Is there any way of
>>>>>> stopping or starting (topup) a charge from within the car, or
>>>>>> is it just controlled by plugging? Any chance of can bus
>>>>>> control of this?
>>>>>> 3. Can anyone help with the car images for the Twizy? There are
>>>>>> lots of nice images available, but they need to be
>>>>>> photoshopped to the right dimensions and transparent
>>>>>> background png.
>>>>>> Regards, Mark.
>>>>>> OvmsDev mailing list
>>>>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal
>>>>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
>>>>> <dexter.vcf>
>>> <dexter.vcf>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121111/a91b6c6e/attachment-0001.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121111/a91b6c6e/attachment-0001.vcf>
