[Ovmsdev] NL t-mobile apn
Mark Ramakers
MRamakers at talpa.tv
Wed May 9 19:03:47 HKT 2012
APN: smartsites.t-mobile
Proxy: <not set="">
Port: <not set="">
Username: *
Password: *
Server: *
MMSC: http://t-mobilemms<http://t-mobilemms/>
MMS proxy: 010.010.010.011
MMS port: 8080
MCC: 204
MNC: 16
APN type: default
From: Mark Webb-Johnson <mark at webb-johnson.net<mailto:mark at webb-johnson.net>>
Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk<mailto:ovmsdev at lists.teslaclub.hk>>
Date: woensdag 9 mei 2012 12:43
To: "ovmsdev at lists.teslaclub.hk<mailto:ovmsdev at lists.teslaclub.hk>" <ovmsdev at lists.teslaclub.hk<mailto:ovmsdev at lists.teslaclub.hk>>
Subject: [Ovmsdev] NL t-mobile apn
Anyone know the correct apn, username and password for this?
Begin forwarded message:
Parameter command I used:
PARAMS K SMS,IP 64.111.70.40 http://pda.t-mobile.nl - - ...
Any idea what to check?
Mark Ramakers
CFO
Talpa Holding N.V.
Zevenend 45 - 1251 RL Laren
P.O. Box 154 - 1250 AD Laren
The Netherlands
T +31 35 53 33 553
E MRamakers at talpa.tv
W http://www.talpa.tv
Chamber of commerce registration number 32083875
Talpa Holding is part of the Talpa Group
The information contained in this communication is confidential and may be legally privileged. It is intended solely for the use of the individual or entity to whom it is addressed and others authorised to receive it. If you are not the intended recipient you are hereby notified that any disclosure, copying, distribution or taking any action in relation to the contents of this information is strictly prohibited and may be unlawful. Neither the sender nor the represented institution are liable for the correct and complete transmission of the contents of an e-mail, or for its timely receipt.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120509/e3a397ea/attachment.htm>
Name: not available
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120509/e3a397ea/attachment-0002.gif>
