[Ovmsdev] OVMS Not Responding
Mon May 7 10:17:33 HKT 2012
Tom,
DId you get to see the status of lights at the time of the problem? I'm guessing alternating green-red?
Mark.
On 7 May, 2012, at 2:14 AM, Tom Saxton wrote:
> Rebooting the module got it working again.
> Tom
> on 5/5/12 5:57 PM, Mark Webb-Johnson wrote:
>> Tom,
>> The TMC server shows the last connection from your car was 2012-05-03 17:29
>> (whatever time zone the TMC server is in - EDT?).
>> This is one of the reasons I want to do those flashing lights diagnostics
>> codes. The only way of knowing what it is doing at the moment is to plug in
>> RS232 to the modem and see the comms there (but that cant be done with the
>> modem in the box).
>> I suggest you check the flashing lights and see what they are currently
>> showing. Other than that, try to reboot the module.
>> On 6 May, 2012, at 12:50 AM, Tom Saxton wrote:
>>> Our Roadster has been parked for 9 days (since 4/26). When I open the OVMS
>>> iPhone app, I see on the Battery screen a flashing antenna in the upper
>>> right with a red ball at the top and red text below that says "43 hours". In
>>> the upper left it says "P 8 days".
>>> When I finished the most recent drive, the SOC was 88%, 168 ideal. This
>>> morning when I looked at the car it read 83% and 158 ideal. Then I started a
>>> charge. The OVMS app shows 84% and 160 ideal, so it's probably a couple of
>>> days old.
>>> I get no response when sending an SMS message.
>>> So I figured the OVMS box had lost contact, and needed to reboot, but just
>>> for fun, I logged into AT&T to see when it stopped sending data. It hasn't!
>>> It's been sending data every day for the past month, including 5 burts today
>>> from 1KB to 19 KB.
>>> The most recent activity I saw was when it forwarded a spam text to me on
>>> 4/29.
>>> Any thoughts on what's going on, or anything I should do before I reboot it?
>>> Tom
