[Ovmsdev] Another Preview for the new iOS App
Mon May 7 09:55:07 HKT 2012
Felix,
> just a couple of questions. where and how is the timed charge supported??
Currently, I've added support to the App to show the charging is delayed by timer. It shows in the plug graphic with a switch slid to the left and the words "TIMED CHARGE". Sliding the switch to the right will start the charge immediately (overriding the timer delay). It looks almost identical to the normal "SLIDE TO CHARGE" mechanism, just with different wording.
I want to add support to the car module for (a) sending current charge delay mode (charge on plugin or charge on timer) and time, and (b) support changing the mode from the App. But, that is going to require a firmware change to the car firmware which I'm doing in the current set of updates. So, full App support will come later. I think in the App, this can go on the current battery-tap screen that sets current limit and mode.
> also was wondering if you are planning on looking at the on off switches etc for ease of use of the functions such as CAN write mode etc,  that we had discussed or you will leave that for now....?
Yes, I want to do this. That is almost the last thing pending on this version, before we should be good to release.
The other minor thing is the graphic for the car with groups. I'm going to add a global "Settings" control to allow opt-out of sending the chosen car image name up to the server for distribution to people who subscribe to the groups. It will default on, but can be disabled. If on, the app will tell the server (when logging in) what car color choice has been made by the user, and the server will send that information along with the group messages. This will allow us to display the correct car colors on the groups map. Not too big a change, but needs to be co-ordinated with the Android release.
On 7 May, 2012, at 3:15 AM, felix bonnier wrote:
> mark,
> first THANKS it looks great.
> just a couple of questions. where and how is the timed charge supported??  also was wondering if you are planning on looking at the on off switches etc for ease of use of the functions such as CAN write mode etc,  that we had discussed or you will leave that for now....?
> thanks again for all your hard work
> felix b.
> Sent from somewhere in our beautiful universe.
> On 6 May, 2012, at 21:27, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>> I've just released to testflightapp another preview of the upcoming 1.2.5 iOS App. This is build 20120506.
>> Testflightapp testers registered for the OVMS project can get it in the usual place.
>> We're getting close now. The basics are working and the last thing to do is the configuration features/parameters/advanced screens.
>> <Icon.png>
>> Open Vehicle 1.2.5 (20120506)
>> Team: Open Vehicles
>> What's New:
>> v1.2.5 preview (20120506)
>> - Retina vehicle images
>> - Current weather situation indicator
>> - Location vehicle animations
>> - Location lock-to-my-car feature
>> - Location Groups support (preliminary)
>> - UI revamp
>> - App version shown in vehicle info display
>> - Move Control button to car detail screen
>> - Move Info button to car selection screen
>> - Move GSM signal bars to car selection screen
>> - Show car direction on location map
>> - Support display and control of a timer-delayed charge
>> - Use pump status for temp stale
>> - Charge port animations
>> - Stale indicators for ambient, pem, motor, battery and toms
>> - Various minor bug-fixes and stability enhancements
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120507/34f4fa13/attachment.htm>
