No subject
Sun May 6 08:57:18 HKT 2012
nt, and implement something properly when we know it is feasible.
The problem is that we need CAN bus dumps while OnStar / KeyFob pre-heat an=
d remote start/stop is commanded. For that, we need someone with a Volt in =
the USA and CAN-USB logger to help us try to find the commands.
On 16 Feb, 2013, at 7:56 AM, Rens Meijer <r.meijer at atlantis-it.nl> wrote:
Hello, =A0Last week I received the OVMS V2 module to monitor my Ampera. I a=
lready had an OVMS V1 module to monitor the Tesla Roadster, so it works nic=
ely from 1 app. =A0In winter I like the remote start/stop function of the A=
mpera to pre-heat the car.I found this Youtube that in the US it is possibl=
e with the OnStar system to remote start/stop the car. See at 2.21 in the m=
ovie.http://www.youtube.com/watch?v=3DIOJMVbQnNIU&sns=3DemHas somebody alre=
ady made a CAN bus log during the remote start/stop by using the remote con=
trol? If you are able to find the sequence, how easy would it be to configu=
re the current home buttons in the app to implement the start/stop function=
?I would like to hear your thoughts on this? =A0Best Regards, =A0Rens=A0=A0=
OvmsDev mailing list
OvmsDev at lists.teslaclub.hk
-----Inline Attachment Follows-----
---1387227393-1288175653-1361560393=:29878
Content-Type: text/html; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printable
<table cellspacing=3D"0" cellpadding=3D"0" border=3D"0" ><tr><td valign=3D"=
top" style=3D"font: inherit;">Hello Folks,<br>I just captured CAN data duri=
ng onstar commands for remote start/stop lock/unlock.<br>Below are my notes=
. Where should I send the log file?<br>Regards,<br>Richard<br>San Die=
go<br>2013 Volt #119292<br><br>Fri Feb 22, 2013 10am PST<br>VIN: 1g1re6e49d=
u119292<br><br>Car plugged in, locked, finished charging (green led blinkin=
g)<br><br>walk up to car<br>fob - unlock<br>open passenger door - get in<br=
>close passenger door.<br>10:41<br>start android onstar app<br>request stat=
us update (push refresh icon on app) <br>10:43 - app shows doing refresh<br=
>see CAN activity<br>10:44 app finally updates - 120V battery fully charged=
36 mile ev range 152 fuel range Oil life remaining 86% odo 3955 mile=
s<br>10:45 can updates stop<br>onstart remote door lock<br>1052 - sent lock=
cmd<br>1052 locked - lots of can<br>1053 remote start sent. failed a=
s
key in vehicle 1054<br>1054 remote unlock 1054 done<br>1055 leave via pass=
enger door, close it.<br>keyfob lock 1055<br>leave key out of range of the =
car<br>1055 remote start req <br>1056 app says "cabin temp being set for op=
timal comfort"<br>lots of CAN<br>Dash still off, but orange engine light is=
on.<br>1057 send cancel engine start.<br>1057 - engine light off - app say=
s done<br><br><br>-rw-r--r-- 1 root root 17471412 2013-02-22 10:59 volt_130=
222_1_CAN_log.txt<br>Fri Feb 22, 2013 10am PST<br>VIN: 1g1re6e49du119292<br=
><br><br>Car plugged in, locked, finished charging (green led blinking)<br>=
<br>walk up to car<br>fob - unlock<br>open passenger door - get in<br>close=
passenger door.<br>10:41<br>start android onstar app<br>request status upd=
ate (push refresh icon on app) <br>10:43 - app shows doing refresh<br>see C=
AN activity<br>10:44 app finally updates - 120V battery fully charged 36 mi=
miles<br>10:45 can updates stop<br>onstart remote door lock<br>1052 - sent=
lock cmd<br>1052 locked - lots of can<br>1053 remote start sent. fai=
led as key in vehicle 1054<br>1054 remote unlock 1054 done<br>1055 leave vi=
a passenger door, close it.<br>keyfob lock 1055<br>leave key out of range o=
f the car<br>1055 remote start req <br>1056 app says "cabin temp being set =
for optimal comfort"<br>lots of CAN<br>Dash still off, but orange engine li=
ght is on.<br>1057 send cancel engine start.<br>1057 - engine light off - a=
pp says done<br><br><br>-rw-r--r-- 1 root root 17471412 2013-02-22 10:59 vo=
lt_130222_1_CAN_log.txt<br>gzip volt_130222_1_CAN_log.txt <br>tattler:~# ta=
il volt_130222_1_CAN_log.txt <br>10:58:02.055852 S. id=3D0x000001c4 dat=3D0=
xca:0x62:0xc1:0x10:0x04:0x00:0x03:0xfe<br>10:58:02.057282 S. id=3D0x000001c=
5 dat=3D0x2c:0x03:0x2c:0x03:0x2e:0x01<br>10:58:02.058671 S. id=3D0x000001f4=
dat=3D0x00:0x00:0x00:0x00:0x00:0x00<br>10:58:02.060073 S. id=3D0x00000287
dat=3D0xc1:0x00<br>10:58:02.062044 S. id=3D0x000002c3 dat=3D0x06:0x5b:0x06=
:0xa0:0x06:0xa0:0xca:0x00<br>10:58:02.062468 S. id=3D0x000000bc dat=3D0x37:=
0x00:0x00:0x40:0x00:0x00:0x00:0x00<br>10:58:02.062785 S. id=3D0x000000aa da=
t=3D0x2c:0x03:0x2c:0x03:0x04:0x53:0xfb:0x00<br>10:58:02.063088 S. id=3D0x00=
0000c9 dat=3D0x00:0x00:0x00:0x27:0x00:0x10:0x08:0x00<br>10:58:02.063392 S. =
id=3D0x000001ed dat=3D0x01:0x90:0x00:0x00:0x00:0x00:0x18:0x01<br>10:58:02.0=
63691 S. id=3D0x000001ef dat=3D0x00:0x00:0x00:0x00<br>gzip volt_130222_1_CA=
N_log.txt <br>-rw-r--r-- 1 root root 1888643 2013-02-22 10:59 volt_130222_1=
_CAN_log.txt.gz<br><br><br><br>--- On <b>Sat, 2/16/13, Mark Webb-Johnson <i=
><mark at webb-johnson.net></i></b> wrote:<br><blockquote style=3D"borde=
r-left: 2px solid rgb(16, 16, 255); margin-left: 5px; padding-left: 5px;"><=
br>From: Mark Webb-Johnson <mark at webb-johnson.net><br>Subject: Re: [O=
vmsdev] Ampera remote start/stop function<br>To: "OVMS Developers"
<ovmsdev at lists.teslaclub.hk><br>Date: Saturday, February 16, 2013, 1=
2:03 AM<br><br><div id=3D"yiv41297325"><base><div>Rens,<div><br></div><div>=
The car-side technical discussion is going on here:</div><div><br></div><di=
v><blockquote style=3D"margin:0 0 0 40px;border:none;padding:0px;"><a rel=
=3D"nofollow" target=3D"_blank" href=3D"http://gm-volt.com/forum/showthread=
.php?12958-CAN-bus-reading-remote-viewing-of-charge-state">http://gm-volt.c=
om/forum/showthread.php?12958-CAN-bus-reading-remote-viewing-of-charge-stat=
e</a></blockquote></div><div><br></div><div>We're after pretty much the sam=
e things as the DashDaq people, so there is a lot of overlap.</div><div><br=
></div><div>From the App, it is no problem. We can use HomeLink for testing=
at the moment, and implement something properly when we know it is feasibl=
e.</div><div><br></div><div>The problem is that we need CAN bus dumps while=
OnStar / KeyFob pre-heat and remote start/stop is commanded. For that, we =
need
someone with a Volt in the USA and CAN-USB logger to help us try to find t=
he commands.</div><div><br></div><div>Regards, Mark.</div><div><br><div><di=
v>On 16 Feb, 2013, at 7:56 AM, Rens Meijer <<a rel=3D"nofollow" ymailto=
=3D"mailto:r.meijer at atlantis-it.nl" target=3D"_blank" href=3D"/mc/compose?t=
o=3Dr.meijer at atlantis-it.nl">r.meijer at atlantis-it.nl</a>> wrote:</div><b=
r class=3D"yiv41297325Apple-interchange-newline"><blockquote type=3D"cite">=
<div style=3D"font-family:Helvetica;font-size:medium;font-style:normal;font=
-variant:normal;font-weight:normal;letter-spacing:normal;line-height:normal=
;orphans:2;text-indent:0px;text-transform:none;white-space:normal;widows:2;=
word-spacing:0px;" lang=3D"EN-US"><div class=3D"yiv41297325WordSection1" st=
yle=3D""><div style=3D"margin:0cm 36pt 0.0001pt 0cm;font-size:11pt;font-fam=
ily:Calibri, sans-serif;">Hello,</div><div style=3D"margin:0cm 36pt 0.0001p=
t 0cm;font-size:11pt;font-family:Calibri, sans-serif;"> </div><div st=
0.0001pt 0cm;font-size:11pt;font-family:Calibri, sans-serif;">Last week I =
received the OVMS V2 module to monitor my Ampera. I already had an OVMS V1 =
module to monitor the Tesla Roadster, so it works nicely from 1 app.</div><=
div style=3D"margin:0cm 36pt 0.0001pt 0cm;font-size:11pt;font-family:Calibr=
i, sans-serif;"> </div><div style=3D"margin:0cm 36pt 0.0001pt 0cm;fon=
t-size:11pt;font-family:Calibri, sans-serif;">In winter I like the remote s=
tart/stop function of the Ampera to pre-heat the car.</div><div style=3D"ma=
rgin:0cm 36pt 0.0001pt 0cm;font-size:11pt;font-family:Calibri, sans-serif;"=
>I found this Youtube that in the US it is possible with the OnStar system =
to remote start/stop the car. See at 2.21 in the movie.</div><div style=3D"=
margin:0cm 36pt 0.0001pt 0cm;font-size:11pt;font-family:Calibri, sans-serif=
;"><a rel=3D"nofollow" target=3D"_blank" href=3D"http://www.youtube.com/wat=
ch?v=3DIOJMVbQnNIU&sns=3Dem"
style=3D"color:purple;text-decoration:underline;">http://www.youtube.com/w=
atch?v=3DIOJMVbQnNIU&sns=3Dem</a><span style=3D"color:rgb(31, 73, 125);=
"></span></div><div style=3D"margin:0cm 72pt 0.0001pt 0cm;font-size:11pt;fo=
nt-family:Calibri, sans-serif;">Has somebody already made a CAN bus log dur=
ing the remote start/stop by using the remote control? If you are able to f=
ind the sequence, how easy would it be to configure the current home button=
s in the app to implement the start/stop function?</div><div style=3D"margi=
n:0cm 36pt 0.0001pt 0cm;font-size:11pt;font-family:Calibri, sans-serif;">I =
would like to hear your thoughts on this?</div><div style=3D"margin:0cm 36p=
t 0.0001pt 0cm;font-size:11pt;font-family:Calibri, sans-serif;"> </di=
v><div style=3D"margin:0cm 36pt 0.0001pt 0cm;font-size:11pt;font-family:Cal=
ibri, sans-serif;">Best Regards,</div><div style=3D"margin:0cm 0cm 0.0001pt=
;font-size:11pt;font-family:Calibri, sans-serif;"> </div><div style=
=3D"margin:0cm
0cm 0.0001pt;font-size:11pt;font-family:Calibri, sans-serif;">Rens</div><d=
iv style=3D"margin:0cm 0cm 0.0001pt;font-size:12pt;font-family:'Times New R=
oman', serif;"><span style=3D"font-size:11pt;font-family:Calibri, sans-seri=
f;color:rgb(31, 73, 125);"> </span></div><div style=3D"margin:0cm 0cm =
0.0001pt;font-size:12pt;font-family:'Times New Roman', serif;"><span style=
=3D"font-size:11pt;font-family:Calibri, sans-serif;color:rgb(31, 73, 125);"=
> </span></div></div>_______________________________________________<b=
r>OvmsDev mailing list<br><a rel=3D"nofollow" ymailto=3D"mailto:OvmsDev at lis=
ts.teslaclub.hk" target=3D"_blank" href=3D"/mc/compose?to=3DOvmsDev at lists.t=
eslaclub.hk" style=3D"color:purple;text-decoration:underline;">OvmsDev at list=
s.teslaclub.hk</a><br><a rel=3D"nofollow" target=3D"_blank" href=3D"http://=
lists.teslaclub.hk/mailman/listinfo/ovmsdev"
style=3D"color:purple;text-decoration:underline;">http://lists.teslaclub.h=
k/mailman/listinfo/ovmsdev</a><br></div></blockquote></div><br></div></div>=
</div><br>-----Inline Attachment Follows-----<br><br><div class=3D"plainMai=
l">_______________________________________________<br>OvmsDev mailing list<=
br><a ymailto=3D"mailto:OvmsDev at lists.teslaclub.hk" href=3D"/mc/compose?to=
=3DOvmsDev at lists.teslaclub.hk">OvmsDev at lists.teslaclub.hk</a><br><a href=3D=
"http://lists.teslaclub.hk/mailman/listinfo/ovmsdev" target=3D"_blank">http=
://lists.teslaclub.hk/mailman/listinfo/ovmsdev</a><br></div></blockquote></=
td></tr></table>
---1387227393-1288175653-1361560393=:29878--
