[Ovmsdev] Car firmware v1.2.7
William Petefish
william.petefish at gmail.com
Mon May 28 07:25:07 HKT 2012
The homelink works. I've done the testing of the other commands too. They
work.
William
On Sun, May 27, 2012 at 7:58 AM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
> Inching towards the v1.3.0 release, I've just committed to github v1.2.7
> of the car firmware for OVMS.
> Changelog since v1.2.2 is:
> 2012-05-27 1.2.7 Preliminary firmware 1.2.7
> Bug fix for off-by-one-can-byte bug in roadster id
> from VIN
> Add homelink and charge timer support, plus misc
> fixes
> Only send non-empty params to PARAMS? sms command
> Remove need to RESET after can write change
> Only NETINIT (not SOFTRESET) after a parameter
> change
> Re-label parameters internally to match new
> user-friendly names
> Re-work of sms command handlers to be table driven
> - saving 6% of flash
> Use the 6% of flash we saved to implement a bunch
> of SMS commands
> REGISTER? Report
> on registered phone
> REGISTER <modulepass>
> Register caller phone
> PASS? Report
> on module password
> PASS <modulepass> Set
> new module password
> GPS?/GPS [<modulepass>] Report
> GPS location
> STAT?/STAT [<modulepass>] Report
> status
> PARAMS? [<modulepass>] Report
> on parameters
> PARAMS <param2> <param3> .. <paramN> Set
> parameters
> MODULE? [<modulepass>] Report
> on module parameters
> MODULE <vehicleid> <units> <notifies> Set
> module parameters
> GPRS? [<modulepass>] Report
> on GPRS parameters and status
> GPRS <gprsapn> <gprsuser> <gprspass> Set
> GPRS parameters
> SERVER? [<modulepass>] Report
> on server parameters
> SERVER <serverip> <serverpass> <paranoid> Set
> server parameters
> DIAG?/DIAG [<modulepass>]
> Technical diagnostics
> FEATURES? [<modulepass>] Report
> on features configured
> FEATURE <feature> <value> Set
> specified feature value
> HOMELINK <button>
> Activate homelink 0, 1 or 2
> LOCK <pin> Lock
> car (with specified pin)
> UNLOCK <pin> Unlock
> VALET <pin>
> Activate valet mode (with specified pin)
> UNVALET <pin>
> Deactivate valet mode (with specified pin)
> CHARGEMODE <mode> <current> Set
> charge mode (sta, sto, ran, per) and current
> CHARGESTART [<modulepass>] Start
> charge immediately
> CHARGESTOP [<modulepass>] Stop
> charge immediately
> VERSION [<modulepass>] Report
> module firmware version
> RESET [<modulepass>] Reset
> module
> 2012-05-11 1.2.5 Preliminary firmware 1.2.5
> LED re-work
> Support multiple vehicle configurations -
> TeslaRoadster and VoltAmpera
> NET driver tidy-ups
> Auto-support Tesla Roadster v1.5 cars
> Issue #38 - Prevent user from locking car if car is
> ON
> Issue #39 - Alert (SMS/PUSH) if trunk is opened
> while in valet mode
> I've managed to do this with very little impact to firmware size.
> Major user-visible extensions in this firmware include:
> - A huge number of new SMS commands.
> - Support for simplified setup steps (working on with Bennett).
> - New status and error LED arrangement.
> - New diagnostic SMS commands.
> - Various minor bug-fixes and improvements.
> - Homelink support (firmware both SMS and app protocol support - app
> support will follow).
> - Charge timer support (firmware and app protocol support - app and
> sms support will follow).
> This is a major re-work of the SMS sub-system. We now have 27 commands and
> similar functionality to the GPRS smartphone apps. In particular, charge
> start/stop and mode setting is now available.
> I've also added in the homelink commands (courtesy of Fuzzylogic's CAN
> decoding skills).
> I've tested this on the bench, and it seems to work. I've also put it in
> my car 10 minutes ago, and got a network connection. That is pretty much
> the extent of my testing, so consider this pre-beta and definitely NOT for
> end-users.
> I haven't completely tested the setup of a module from scratch with these
> new REGISTER, PASS, MODULE, SERVER, GPRS commands - I hope Bennett, or
> someone else, will help with that.
> I haven't tested homelink support. I hope someone will try that (using SMS
> "HOMELINK 0" command) and let me know if it works.
> This is now pretty feature complete for the v1.3.0 firmware. I need to do
> the CHARGETIMER SMS commands, and want to re-work the social group messages
> to allow streaming of group location messages (if enabled). So, please test
> this as you can, and let me know any problems you find.
> Again, please don't put this on end-user cars yet. There has been a lot go
> into this and I need a week or so of inevitable bug fixing before it is
> ready for wider testing. There hasn't been much changes to the net
> subsystem since 1.2.5, and that seem stable, so I think it is fine to put
> in developer's cars.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120527/800a15df/attachment-0001.html>
