[Ovmsdev] Celcius vs Fahrenheit, Kilometers vs Miles
Wed May 9 10:47:10 HKT 2012
Felix,
What about the choice? Should we use what is configured in the car, or what is configured on the phone?
For example, a car configured to use Miles, but shown on a phone configured as metric.
On 9 May, 2012, at 8:20 AM, felix bonnier wrote:
> To My knowledge both are used in europe so you can leave the pressure in PSI but someone else might think differently........
> Sent from my iPad somewhere in our beautiful universe.......
> On 9 May, 2012, at 8:16, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>> In the car module, and protocol, there is a setting for Miles vs Kilometers and all the distance based measurements (speed, ideal and estimated ranges) are sent from the module in those units.
>> The protocol states that temperatures (pem, motor, battery, ambient and tpms) should be sent in celcius, and tpms pressures in PSI - and that is what is currently done.
>> We don't currently convert these to user-suitable units in the iOS App. We leave them in celcius and psi.
>> Doing the conversion in the App is certainly possible, but my question is how to control this and what to do?
>> Options I see:
>> Use the Miles/Kilometer value coming from the car.
>> Use the iOS NSLocale system to read user preferences from the device itself, and convert _everything_ to that.
>> Use the iOS NSLocale system to read user preferences from the device itself, and convert just temperatures/pressures to that.
>> I've left out [4] "have individual settings in the app for each of temperatures, distance and pressure" as it is overly complicated.
>> We could convert temperatures from celcius to fahrenheit (using Tf = (9/5)*Tc+32).
>> We could convert pressures from PSI to kPa (using Pkpa = Ppsi * 6.895).
>> For tire pressures, what is currently used in Europe? I still see PSI used here in Hong Kong, even thought we use Kilometers for distance, but do we need to convert this to something else? I notice the roadster still shows pressures in PSI even though the car is metric and shows kilometers. Is it OK to leave this in PSI?
>> What do US cars show for ambient and tpms temperatures on the in-car VDS? Celcius / Fahrenheit?
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120509/1d04d4bf/attachment.html>
