[Ovmsdev] Any Telco engineers?
felix bonnier
felixtb at me.com
Tue Mar 20 00:38:06 HKT 2012
mark,
I will send you some further ideas on the UI which I think still needs some cleaning up, now that I actually have a working unit and can play with all the functions it has been a lot easier to immerse myself in the layout and depth of the app and it's settings
best
/fb
Sent from my iPad somewhere in our beautiful universe.......
On 19 Mar, 2012, at 22:25, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Any Telco engineers here?
> I've been working on the iOS App code to convert the GSM signal strength indicator that comes back from the car into a 5 bar display and dBm value. There doesn't seem to be a standard for this, so I picked the iPhone 4.0.1 levels, as the reportedly the same as AT&T now use and at least I can compare with my iPhone.
> Code looks like this:
> // car_gsmlevel comes back from the car as the output of AT+CSQ
> // It is reportedly in the range 0..31, 99.
> int car_gsmlevel = [ovmsAppDelegate myRef].car_gsmlevel;
> // Calculate dBm from AT+CSQ signal level
> int car_gsmdbm = 0;
> if (car_gsmlevel <= 31)
> car_gsmdbm = -113 + (car_gsmlevel*2);
> // Tell the user about the dBm
> m_gsm.text = [NSString stringWithFormat:@"%d dBm",car_gsmdbm];
> // Calculate the signal bars 0..5
> int car_signalbars = 0;
> if ((car_gsmdbm < -121)||(car_gsmdbm >= 0))
> car_signalbars = 0;
> else if (car_gsmdbm < -107)
> car_signalbars = 1;
> else if (car_gsmdbm < -98)
> car_signalbars = 2;
> else if (car_gsmdbm < -87)
> car_signalbars = 3;
> else if (car_gsmdbm < -76)
> car_signalbars = 4;
> else
> car_signalbars = 5;
> Does that look ok, or can anyone with experience of this suggest anything better?
> I've got a testflightapp build ready with this, and should be able to release tomorrow morning (my time). Just waiting for some device ids / testflightapp recruits to come in from interested developers who have eMailed me offering to help.
> P.S. The last 20120318 testflightapp build looks good. Crashes for the past 24 hours have gone to zero and things seem more stable.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120320/4b76ceea/attachment.htm>
