[Ovmsdev] Module stops working after couple of days
Sonny
foxium at gmail.com
Thu Mar 1 19:28:52 HKT 2012
Wido,
Green off is definitely strange. I suggest you to try reflashing the
firmware to rule out a bad flash.
If it still drops out, try sending STAT via SMS. If it responds, then we
can narrow it down to a GPRS problem.
Sonny
On Mar 1, 2012 5:14 PM, "Wido den Hollander" <wido at widodh.nl> wrote:
> Hi,
> About a week ago I was able to install the module and get my own server up
> and running. Everything seemed to work fine from the beginning, but after
> about 36 hours the module died.
> First I thought my prepaid SIM-card had ran out of credits, but that was
> not the case.
> A manual reboot of the module was needed and it started working again.
> Yesterday I opened the app and saw "Last update 8 hours ago"
> Again, a reboot of the module was enough.
> I checked the LED's and the first time GREEN was solid ON and RED was
> flashing slowly, that is normal.
> The second time the GREEN LED was off and only the RED one was blinking.
> I don't think it's a problem of GSM reception, the module even worked
> without the antenna while lying on the floor of the car.
> GSM reception is however very good here in the neighborhood, no high
> buildings and it's a very dense network.
> It's also weird that the module doesn't come back online. If it was a
> short disruption it could be a connection problem, but being offline for 8
> hours is long.
> Has anyone seen this behavior?
> Thanks,
> Wido
> ______________________________**_________________
> http://lists.teslaclub.hk/**mailman/listinfo/ovmsdev<http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120301/5185e951/attachment.html>
