[Ovmsdev] Cool down
Bennett Leeds
bennettleeds at gmail.com
Thu Jun 28 11:14:56 HKT 2012
I've been doing 220volt 15 amp charging to cool the battery. Like Tom, I
manually stop it when the battery temp reaches 80F. Like Mark, I found that
low amp charges didn't cool the battery as much - I'll speculate that Tesla
probably sees the low amperage and figures that it can't waste as much
juice cooling the battery, and that a slow charge won't really heat it up
much.
Have you thought about parameters for the CoolDown function?
- Desired End Temperature
- Amperage to Use
- Maximum length of time to run
Also, have you considered an "Auto" feature, where when OVMS sees the car
is plugged-in but not charging and that the battery temp is high,
automatically kicks on to cool it? The max run time parameter is kind of a
safety feature to avoid running too long at high prices.
- Bennett
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120627/cdc2d27e/attachment.htm>
