[Ovmsdev] Car firmware v1.2.7
Mark Ramakers
MRamakers at talpa.tv
Sat Jun 9 00:15:53 HKT 2012
Thnx, willdo and report
Verstuurd vanaf mijn Iphone
Op 8 jun. 2012 om 18:08 heeft "Mark Webb-Johnson" <mark at webb-johnson.net<mailto:mark at webb-johnson.net>> het volgende geschreven:
Mark,
Seems very messed up.
At the moment, your car 'T819' is connected to www.openvehicles.com<http://www.openvehicles.com> (202.52.43.80/202.52.42.80).
Your apps are connected to tmc.openvehicles.com<http://tmc.openvehicles.com> and are showing:
2012-06-08 11:16:10.746043 -0400 info main: #827 - - rx MP-A 0 BD5u+iZ/VddXPclov/Hg98 3K2tV7qLFUpSK3VEAaMdGA== T819
2012-06-08 11:16:10.746973 -0400 error main: #827 T819 error - Incorrect client authentication - aborting connection
which looks like you have the wrong password in the app.
I suggest you switch the car to 64.111.70.40 and then double-check the password in the apps.
On 8 Jun, 2012, at 11:36 PM, Mark Ramakers wrote:
STAT is giving me charging status, PARAMS is not responding……
From: Mark Webb-Johnson <mark at webb-johnson.net<mailto:mark at webb-johnson.net>>
Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk<mailto:ovmsdev at lists.teslaclub.hk>>
Date: vrijdag 8 juni 2012 17:34
Subject: Re: [Ovmsdev] Car firmware v1.2.7
What does PARAMS? SMS command show? All ok?
Server should be the ip address of tmc.openvehicles.com<http://tmc.openvehicles.com/>.
On 8 Jun, 2012, at 11:31 PM, Mark Ramakers <MRamakers at talpa.tv<mailto:MRamakers at talpa.tv>> wrote:
Do I need to redirect the car module to this server, the App is pointing to this server below….
Date: vrijdag 8 juni 2012 17:24
Are you sure app is on correct server? tmc.openvehicles.com<http://tmc.openvehicles.com/> in Setting App.
On 8 Jun, 2012, at 11:18 PM, Mark Ramakers <MRamakers at talpa.tv<mailto:MRamakers at talpa.tv>> wrote:
Anyone experiencing non working iPhone App after update ? All car settings
are working, SMS is working, GPRS lights on, settings in App are right ?
Both on iPhone and iPad, apps do not seem to get connected to the car ?
Mark Ramakers
CFO
Talpa Holding N.V.
Zevenend 45 - 1251 RL Laren
P.O. Box 154 - 1250 AD Laren
The Netherlands
T +31 35 53 33 553
E MRamakers at talpa.tv<mailto:MRamakers at talpa.tv>
W http://www.talpa.tv<http://www.talpa.tv/>
Chamber of commerce registration number 32083875
Talpa Holding is part of the Talpa Group
The information contained in this communication is confidential and may be legally privileged. It is intended solely for the use of the individual or entity to whom it is addressed and others authorised to receive it. If you are not the intended recipient you are hereby notified that any disclosure, copying, distribution or taking any action in relation to the contents of this information is strictly prohibited and may be unlawful. Neither the sender nor the represented institution are liable for the correct and complete transmission of the contents of an e-mail, or for its timely receipt.
OvmsDev mailing list
OvmsDev at lists.teslaclub.hk<mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120608/b9652869/attachment.htm>
