[Ovmsdev] Car firmware v1.2.7
Sat Jun 9 01:49:13 HKT 2012
I had the same problem trying to build last week. Mark gave me a list of
things to check, then life happened and I just got back to it.
I'm using MPLAB X v1.10 and mcc18 v3.40.
I chose TR_Production for the build settings, confirmed that mcc18
optimizations are set to "Enable all" and did a "Clean and Build" (not
"Clean and Build for Debugging").
I still get the linker error, same as before.
I get the same result for the TR_Experimental build.
Wondering if I had done something to mess up my sources, I deleted the
entire OVMS project directory, did a fresh git clone, and repeated the
steps. Same result.
    Tom
PS: You can copy from the build output window and paste into a text file.
This yields a much smaller email attachment and it doesn't crop off the end
of the build commands.
on 6/8/12 10:07 AM, 911carrera4 wrote:
> Hi guys
> Unfortunately  I have a problem with the compilation of the firmaware files
> 1.2.7. I'm using MPLAB X DIE 1.00
> Please see enclosed picture.
> I can't compile the project and also the use of the hex-file for flashing is
> impossible.
> Does this sound familiar to anyone?
> The previously released firmware versions worked out fine.
> Greetings, Piotr
> Von: ovmsdev-bounces at lists.teslaclub.hk
> [mailto:ovmsdev-bounces at lists.teslaclub.hk] Im Auftrag von Mark Ramakers
> Gesendet: Freitag, 8. Juni 2012 17:31
> An: OVMS Developers
> Betreff: Re: [Ovmsdev] Car firmware v1.2.7
> Do I need to redirect the car module to this server, the App is pointing to
> this server below..
> Date: vrijdag 8 juni 2012 17:24
> Subject: Re: [Ovmsdev] Car firmware v1.2.7
> Are you sure app is on correct server? tmc.openvehicles.com
> <http://tmc.openvehicles.com/>  in Setting App.
> On 8 Jun, 2012, at 11:18 PM, Mark Ramakers <MRamakers at talpa.tv> wrote:
> Anyone experiencing non working iPhone App after update ? All car settings
> are working, SMS is working, GPRS lights on, settings in App are right ?
> Both on iPhone and iPad, apps do not seem to get connected to the car ?
> Mark Ramakers
> CFO
> Talpa Holding N.V.
> Zevenend 45 - 1251 RL Laren
> P.O. Box 154 - 1250 AD Laren
> The Netherlands
> T +31 35 53 33 553
> E MRamakers at talpa.tv
> W http://www.talpa.tv
> Chamber of commerce registration number 32083875
> Talpa Holding is part of the Talpa Group
> The information contained in this communication is confidential and may be
> legally privileged. It is intended solely for the use of the individual or
> entity to whom it is addressed and others authorised to receive it. If you
> are not the intended recipient you are hereby notified that any disclosure,
> copying, distribution or taking any action in relation to the contents of
> this information is strictly prohibited and may be unlawful. Neither the
> sender nor the represented institution are liable for the correct and
> complete transmission of the contents of an e-mail, or for its timely
> receipt.
